Old 04-02-2006, 04:05 PM   #1
UForgotten
UForgotten is on a distinguished road
UForgotten's Avatar
2007 AURA XR
Wrench HELP! S-Series Speaker Replacement gone horribly wrong...
Argh!!! This has to be the most frustrating thing I've dealt with in a while.
'98 SC2, speakers are blown, trying to replace them myself because I don't want to pay someone to do it. That was my first mistake.
I didn't find many posts with exact instructions but did find one that said to take the door apart. Check. The hardest part was getting the door handle off.
I noticed once I took the screws out of the door, however, that the window won't roll up and down anymore.
After getting the inner door handle off, I replaced the speaker no problem. That was the easiest part by far. It even fit back in the plastic bucket designed for the OEM speakers in the door frame.
NOW, the window won't roll down, and each time I try to put the door back together the door handle won't go back in properly.
So, what's the deal with the regulator? Does it cut off when screws are removed? I checked fuse/relay and the relay is hot in comparison with the other ones, so could there be a short? I'm at a loss here.
I've been wrestling with it for over 2 hours and I needed to take a break and get some pointers if anyone has a surefire trick to this! It has beaten me into submission.
Thanks in advance.
UForgotten is offline   Reply With Quote
Old 04-02-2006, 04:08 PM   #2
Default Re: HELP! S-Series Speaker Replacement gone horribly wrong...
Does the handle turn without the window going down, or is the handle siezed?
Old 04-02-2006, 04:10 PM   #3
UForgotten
UForgotten's Avatar
2007 AURA XR
These are power windows. The regulator refuses to engage from the switch. The other window still works fine because that door was unmolested.
The door handle still works fine, when I attach it to the connecting rods.
Since they are apparently different, This is on the driver's (left) door.
Old 04-02-2006, 04:43 PM   #4
scsomike
scsomike is on a distinguished road
did any of the connections get knocked loose (electrical). any screws into the wiring harness causing a short to ground?
'97 SL2, 5spd get around car.
scsomike is offline   Reply With Quote
Old 04-02-2006, 05:52 PM   #5
UForgotten
UForgotten's Avatar
2007 AURA XR
The only way for me to tell if there's a short is to rip the whole door apart again.
I didn't see a wiring harness separate from the wires running to the door lock.
I didn't want to remove all the plastic that had the inside of the door sealed.
Everything is put back together, the door handle, lock, and power lock work great again . The power window simply does not move. The switch works, and the relay works cos the other window is working and I tried swapping the relay, still no dice. I think you are right that somehow perhaps a connection was broken, but would the lights still dim when I hit the switch if the regulator wasn't getting the current?
The thing is, I don't know how or when the regulator could have been broken, as it was working before the door panel was removed, and I was careful not to disturb anything but the door lock and the speaker.
I guess I need more specific information. I was not able to disconnect the door handle's power connector, it's in there pretty good and I didn't see a release tab. There's got to be some sort of trick to this!
I am a beginner here, so I'm disappointed by all this on my first attempt.
On a lighter note, I replaced the rear deck speakers lickety split without incident.
So I've got a working driver door speaker, a non-working driver door window regulator, a blown right speaker cos I'm too afraid to tear apart the other door, and two working rear speakers. :sigh:
Old 04-02-2006, 05:59 PM   #6
UForgotten
UForgotten's Avatar
2007 AURA XR
No luck. The regulator is not working. Anyone else had this problem before? I'll keep searching but if someone has anything to add I'm always appreciative of the help.
Old 04-02-2006, 08:13 PM   #7
sunshn1972
sunshn1972 is on a distinguished road
sunshn1972's Avatar
I found that my power windows wouldn't work unless the button in the door was plugged in. Even if I tried to use the button between the front seats, it only worked if the door switch was plugged in. Sounds to me like the connector in the door isn't plugged in, or is shorted out.
You can take the outer door skin off and look at all the connections from that side. That way you can make sure everything is working before putting the outer skin back on. On mine, all I needed was a size 30 Torx bit to get the outer skin off.
This space intentionally left blank.
sunshn1972 is offline   Reply With Quote
Old 04-02-2006, 08:19 PM   #8
UForgotten
UForgotten's Avatar
2007 AURA XR
I got fed up with it and took both sides of the door off to see what was going on. The regulator is indeed getting voltage, I can hear it click when I actuate the switch, it is very hot, it's just not moving. It's acting like it has siezed up. I'm wondering how removing the inner door panel (and I was quite gentle) would have caused this. I don't have any lube, so I'm going to have to fiddle with it.
I was hoping a wiring harness had come out or something simple like that but apparently it's more involved. I guess it's my fault for going in and disturbing my SC2's pristine environment.
Anyone have any experience ressurecting stuck window regulators?
I've got to get these door panels back on in the next 30 minutes or I won't get to bed on time.
Old 04-02-2006, 08:23 PM   #9
sunshn1972
sunshn1972's Avatar
You should be able to see the window sash now, with everything off.
The regulator arm snaps into a small black plastic slider, that moves horizontally in the aluminum window sash. See if you can wiggle the regulator arm a little and make the window move with it. If you can, the regulator's probably siezed up. If not, the slider may be stuck in the sash.
Old 04-02-2006, 09:47 PM   #10
UForgotten
UForgotten's Avatar
2007 AURA XR
OK, looks like the regulator assembly is jammed. I have a sneaking suspicion that this was due to a hit-and-run (semi sideswipped into my saturn and kept on going) from years ago. The driver's side was impacted, but most of the damage was done to the front quadrant above the wheel well. I have a feeling that when I pulled the inner door cover off it broke the last remaining piece that was holding it in place.
Pictures of the current situation:
Notice at the top how the bar that attaches to the very top of the frame is hanging down, and it looks like it's missing one of the plastic pegs that holds it in.
It won't budge.
Any suggestions?
Old 04-02-2006, 10:38 PM   #11
sunshn1972
sunshn1972's Avatar
Those pics are HUGE. LOL
It looks like there are three sliders on the front windows, which makes sense given how much more they get used than the rear. The rear windows only have one slider. If it helps, this is the how-to I wrote on replacing the rear window slider.
http://www.saturnfans.com/forums/showthread.php?t=72669
I'm basing this on having replaced the rear window slider as well as your picture. I've never taken the front door apart, so I could be wrong on this.
If you follow the two top arms of the "X" up you should find the plastic sliders on the back side (from outside the car). You should also find one at the rear bottom leg of the "X".
It looks like the horizontal silver bar at the top of the "X" is parallel to the ground and the black metal bar is angled up toward the rear of the car. Can you confirm?
If that's the case, I would think the horizontal aluminum bar (the sash bar) is the window sash and the black bar is part of the door frame. The sash bar is supposed to move up and down as the regulator turns, and it is clipped onto the bottom edge of the window.
  1. Make sure you can feel all three sliders, and that each is in a single piece. When the rear ones fail they literally snap into two pieces that slide independently within the sash bar. Make sure all three can move a little and aren't stuck. If just one was stuck it would stop the entire window.
  2. Make sure the sash bar is not hung up on something. If there was damage it might have bent something so that now it's in the way of the sash bar moving. Given that the regulator motor heats up, it sounds like it's trying to work but getting hung up.
At least the car is still driveable for now without a functional window!
Old 04-02-2006, 11:26 PM   #12
Pictures are to freaking BIG to try and look at never mind find anything on them.
Old 04-03-2006, 12:57 AM   #13
scsomike
i have but one question, in two parts...
what freakin kind of camera did you use for that pic and what was the resolution on it??????
Speaker replacement ksimmons L-Series General 3 11-18-2007 08:57 PM
Speaker Replacement Mikey198282 L-Series Tech 2 12-22-2006 09:17 PM
Speaker Replacement BlueY2K Mods and Performance 5 05-31-2003 03:25 PM
Whats wrong with the L-series Klutz_33 L-Series General 27 02-28-2002 09:36 PM
I was WRONG - L Series GM Credits for 2001 n/a ClapDaddy L-Series General 6 08-31-2000 04:32 PM
