Old 07-14-2005, 01:05 AM   #1
s69
s69 is on a distinguished road
Default Question about headliner
Hey i was just wondering if any1 could help me with information on removing and reinstalling the headliner on my 1995 SL1, i need to install dynamat across my roof and im having some problems getting it off, any help would be greatly appreciated.
-sean
s69 is offline   Reply With Quote
Old 07-14-2005, 01:12 AM   #2
RalliArt16
RalliArt16 is on a distinguished road
RalliArt16's Avatar
1996 SC1
Default Re: Question about headliner
From what i believe, simply unclip all of the upperplastic trim along the edges of the headliner. Remove sun visor and and light in the headliner. Should simply come right off after that. You may have to bend it a bit to get it out of the car.
Sorry for lack of specifics, maybe some other member can be of more help its late and i'm tired lol
RalliArt16 is offline   Reply With Quote
Old 07-14-2005, 01:38 AM   #3
LowSC2
LowSC2 is on a distinguished road
LowSC2's Avatar
1999 SC1
1991 SL2
Pretty much what he said. Just remove all the plastic pieces and the headliner should come out. You'll need to remove the handle things too.
Jeff Silva ~ 91 SL2 - 11.809 @ 116.488mph
•Chilton & Haynes manuals are junk
•Changing the ECTS doesn't fix everything
LowSC2 is offline   Reply With Quote
Old 07-14-2005, 02:52 AM   #4
edbama2
edbama2 is on a distinguished road
edbama2's Avatar
1993 SC2
1994 SC2
You do have to put the passenger seat all the way foward and tilt the back all the way back. It comes out the passenger door the easiest. You do have to bend it but, be very careful because it will fold on you. That's not good. Good Luck!
When is Saturn going to make an SC2 Truck?
New 05 Dodge Ram Quad Hemi Thunder Road Package
edbama2 is offline   Reply With Quote
Old 07-14-2005, 01:19 PM   #5
sps SOHC
sps SOHC is on a distinguished road
sps SOHC's Avatar
I assume that it's easier for a coupe since the doors are bigger? I need to replace my headliner... it doesn't have any on it but the sun roof! (and that's coming off)
Will I have to bend it even slightly to get it in? Cuz I had some ideas about fiberglass resin on it.
-96 SC2 gets 35 mpg mix city/hw.
sps SOHC is offline   Reply With Quote
Old 07-15-2005, 02:02 AM   #6
edbama2
edbama2's Avatar
1993 SC2
1994 SC2
Yes, that is correct sps. The area that will tend to fold on you will be right where the whole for the map light sunroof switch. That is where you need to be the most careful.
Old 07-15-2005, 03:27 PM   #7
sps SOHC
sps SOHC's Avatar
So you are saying I DON'T have to bend it to remove it?
I was going to:
remove it
scrub brush old paint (it's painted black) and extra crud off
do a coat of fiberglass resin and let it dry completely
sand it smooth and buff it a little
paint it black with a clearcoat
reinstall
Obviously I won't be able to bend it or it will crack. Does this sound like a cool idea? It would make the ceiling look very smooth and sleak. I was thinking about doing this to the center console as well.
Old 07-15-2005, 04:10 PM   #8
edbama2
edbama2's Avatar
1993 SC2
1994 SC2
It is very fragile and you will have to bend it slightly to get it out. After you get the glue off of the surface it will be a little rough. It has a fiberglass texture to it. It might work with several coats of paint and trimming the little ends that might pop up. When you get it out and cleaned up you will be able to judge better on how you feel. I went and got the 3M glue from a clothing store that is meant for headliners and chose some purplish material to match the car. I haven't had time to finish it due to rain and hurricane preperations. When you get it out, let me know what you think.
Headliner question pimpin88 S-Series General 3 12-15-2009 05:40 PM
Redoing headliner - question(s)! droveavolvoonce S-Series Tech 17 07-09-2009 10:28 PM
Headliner question -- again! JerryHughes S-Series General 11 07-09-2009 05:44 PM
Headliner question myolbug S-Series General 3 09-25-2007 02:30 AM
Headliner Question leadfootny S-Series Mods 5 05-14-2006 12:46 AM
