Old 09-06-2005, 12:14 AM   #1
popp
popp is on a distinguished road
popp's Avatar
2005 VUE Red Line
Default Questions about towing with the RL have been answered!!
This weekend we took the RL out on it's maiden voyage with 1900 lbs trailer in tow. We camped about 80 miles from home. We had an average speed of 70 m\hr and dropping to about 60-65 on big hills. I even hit 85 without breaking a sweat!! There was no problems what so ever......It really didn't feel like I was towing anything. I checked the engine for smells and burns and nothing. We have the AWD V6. What ever the dealer says about lack of air flow is garbage.
Note: KEEP IN MIND I HAVE THE K&N KIT AND A CATBACK MAGNAFLOW EXHAUST INSTALLED.........It does not preform like a stock RL.
I had two options for installing the hitch...........I used the draw-tite class 3 hitch.
1: weld on another receiver tube on existing hitch (lowering the receiver)
2: notch out bumper and use manufactered receiving tube.
After talking to my weld guy and several other welders, they all recomended that I notch a hole as modifying a hitch to pull 2000lbs is not a good idea. Not that the weld wouldn't hold but that the hitch was designed to pull at the level it is not 2" lower. The bolts attaching the hitch to the frame may not hold. So I notched the bumper and mounted rubber trim. Even my bodyman thought it was factory.......you guys judge for yourselves.
Here are some pics......
'05 Vue RL (Some Mods)
'05 VW Passat Wagon TDi (1st @ '08 World Of Wheels)
'93 VW Jetta (1st @ '03-'07 World Of Wheels)
'61 VW Beetle (Resto Project)
popp is offline   Reply With Quote
Old 09-06-2005, 12:15 AM   #2
popp
popp's Avatar
2005 VUE Red Line
Default Re: Questions about towing with the RL have been answered!!
While i'm at it, here are some pics of the smoked tails and front corners
and some sunset & piaa xenon front signal/park lights (HATE orange markers!!)
Old 09-06-2005, 06:50 AM   #3
cleblanc92
cleblanc92 is on a distinguished road
cleblanc92's Avatar
2004 VUE Red Line
Well popp, you have restored my hesitation in hacking into the bumper. It looks great!
What did you use to cut the bumper notch? Dremel?
Thanks for the great pics!
cleblanc92 is offline   Reply With Quote
Old 09-06-2005, 12:58 PM   #4
popp
popp's Avatar
2005 VUE Red Line
Thanks,
I used an air powered cutting tool at work. It's like a dremel but bigger and quicker. A dremel would work fine, but i figured since I have access to a hoist and air tools.......then use it. The rubber trim is from a fender flare kit which we sell. You can buy just the trim at any automotive parts store.
Old 09-06-2005, 02:28 PM   #5
cleblanc92
cleblanc92's Avatar
2004 VUE Red Line
Very cool. What's a good estimate you can give me for your cost on the hitch and extension?
I just want to know how much I'll need to budget for this project.
Old 09-06-2005, 02:28 PM   #6
cleblanc92
cleblanc92's Avatar
2004 VUE Red Line
Thumbs Up Re: Questions about towing with the RL have been answered!!
Old 09-06-2005, 04:29 PM   #7
popp
popp's Avatar
2005 VUE Red Line
I'm in canada, so I don't know your labour costs......but at our shop we charge $214 for the hitch, $50 to install the hitch, $45 for the Wiring package, $50 to install the wiring, $10 for the 7 pin plug and holder, and $35 for the ball mount. Notching the bumper would be about $50 also. So the grand total if you were a regular customer, you'd pay about $485 CAD(including taxes). If the costs are about the same thats about $400 USD.
Now I paid about $105 USD total as I got the hitch for cost, bought the tech lunch to install everything and notched the bumper myself.........
Note: I have the 7 pin plug as my trailor is 7pin and I also ran a dedicated 12v power lead from the battery to charge the trailer batteries while connected.
Draw-tite class 3 part # is DT75195
Old 09-06-2005, 09:34 PM   #8
jrforget
jrforget is on a distinguished road
Hi Popp,
I really enjoyed looking at your pictures and reading your messages about your Vue. I was particularly impressed by your work on the hitch. Our local dealer told me that a hitch could not ne installed on the RL... I am looking for a used Vue 6 cyl AWD (2004 or younger to get the Honda engine) to pull my boat (2700 lb trailer included) on short distances. Any comments?
I am intrigued by your <dedicated 12v power lead from the battery to charge the trailer batteries while connected>. How does that work? Thanks.
jrf in Gatineau Qc
jrforget is offline   Reply With Quote
Old 09-07-2005, 01:38 AM   #9
popp
popp's Avatar
2005 VUE Red Line
Originally Posted by jrforget
Hi Popp,
jrf in Gatineau Qc
Thanks,
As far as i'm concerned, the reason they told you it cant be installed is because of the RL bumber (facia) The engine and drivetrain is the same as a regular v6.......they say that the front bumper doesn't allow as much air to the intake, but if you look at a regular vue and an RL, the RL's bumper opening is way bigger. I can only see the hitch install being a problem. So if your willing to modify your bumper or modify the vue orientated hitch then you shouldn't have a problem. Always make sure they won't void your warrenty if you do decide to install a hitch. (I got mine in writing from the dealership, as long as it was install by a service tech).
If you are pulling 2700lbs, I would at least change to the K&N filter kit as it allows atleast 30%+ more air then the stock box. But with the honda pilot 250hp engine you should be able to tow 3500lbs...........
As for the 12v lead. My trailer is wired for power (7pin) so we put in a 7 pin plug with the direct feed from the battery. Some ppl will attach it to their accessory switch, so that it will only power when the truck is running, but i like to charge while i'm parked if need be. If you talk to any hitch/wiring install shop, they'll know what your talking about. Most 7pins consist of stop, park, left turn, right turn, brakes, 12v power, and an optional extra. Since I don't have trailer brakes I only needed to connect 5 of the 7 but still needed the 7pin receiver outlet. In your case pulling 2700lbs, you'll probably have trailer brakes.
Hope this helps.
Old 09-07-2005, 10:24 AM   #10
SiriusVue
SiriusVue is on a distinguished road
SiriusVue's Avatar
Pics look great. Funny..I just tinted my tails and corners last week. I went a slightly differant rout..I left a small area of amber in the front and a small area of clear for the reverse lights.
I wasn't to happy with the lack of gloss so I have been wet sanding and polishing them. I'll post up some pics later in the week.
Great job!
SiriusVue is offline   Reply With Quote
Old 09-08-2005, 02:02 AM   #11
TXVue04
TXVue04 is on a distinguished road
TXVue04's Avatar
Great job, I like the way you kept everything nice and neat, the hitch is barely noticeable
TXVue04 is offline   Reply With Quote
Old 09-25-2005, 11:32 PM   #12
dogturd21
dogturd21 is on a distinguished road
Good job: I specifically did not buy a RL because I wanted to tow, and I did not know if there was any other differences besides the rear fascia. Too bad I did not know this two months ago, or perhaps I would have gotten a RL instead.
As for buying a hitch, make sure in selecting the hitch vendor that the hitch is V-5 rated, which is a quality standard. It also helps if the company is ISO-9001 certified. If the hitch is a true bolt-on, any shade-tree mechanic or owner could put it on. Draw-Tite and Hidden-Hitch are two good brands.
dogturd21 is offline   Reply With Quote
Old 09-27-2005, 02:12 AM   #13
popp
popp's Avatar
2005 VUE Red Line
draw-tite, reese, and hidden hitch are the same company.......(draw-tite owns them all). It's like gm, saturn, cadillac......all proceeds go into the same guys pocket.
Old 09-27-2005, 02:17 AM   #14
Spazie
Spazie will become famous soon enough
Spazie's Avatar
1993 SC2
There is a hitch made specifically for the Red Line that does not require cutting the bumper. Both fotovue and Dante can give you more information on how to get it - Dante has it installed on his VUE and can tell you how it performs.
13 Chevy Equinox, 46k, built in Spring Hill!
04 VUE 3.5, 196k
99 SL2 Homecoming, 211k
Spazie is offline   Reply With Quote
Old 09-27-2005, 11:45 AM   #15
cleblanc92
cleblanc92's Avatar
2004 VUE Red Line
I'd rather head with what Popp has done. There's no hangin under the bumper that way. I'll bet Dante's custom hitch has left a few marks with his hitch because of how low it is. I admire those guys for working with what they have been given....It's really too bad the stock RL bumper could not have a notch from the factory.
Old 09-27-2005, 09:45 PM   #16
Dante
Dante is on a distinguished road
Dante's Avatar
2004 VUE Red Line
Left a few marks on the concrete at the end of my driveway, yes. On my Vue, no. There's a pretty decent gap between the top of the hitch and the bottom of the facia. I really didn't want to go cutting the bumper, so I deal with having my hitch lower. If I ever get a trailer for my bike for track days, I will have a height adapter neck made for me, but for the time being, my cargo platform works ok, as long as I don't try to drive into driveways.
http://dante.myftp.org/images/vue/20...ight%20014.jpg
http://dante.myftp.org/images/vue/20...itch%20028.jpg
Tupperware cars FTW!!!
Dante is offline   Reply With Quote
Old 09-27-2005, 09:58 PM   #17
popp
popp's Avatar
2005 VUE Red Line
its not made oem for the rl it was modified to work.......I really like the idea of not cutting the facia, however dante's and votovue's is a factory hitch cut and welded. This is all you need if your pulling 500lbs or use it for a bike rack, however in my case i'm pulling a 2000lb trailer and cant take the chance that the lowered/modified/welded hitch will take the weight.
And......i'm lowering the RL atleast another 2" so if i would have went with the modified hitch, I may have run into to many problems with clearance.
Old 09-28-2005, 09:17 PM   #18
Dante
Dante's Avatar
2004 VUE Red Line
Popp -- you are right, we don't really claim that it will hold the 3500 pounds that the (stock) Vue is rated for, but I don't think I would ever need to pull that much, nor would I want to. My dad has a suburban and 2 V8 pickups I can use, I will use his gear before I thrash my tender Honda tranny.
If you lowered my RL another 2", I'd never make it out of the driveway. If you dropped yours 2 inches, you'd probably scrape coming out of my driveway. The bottom of my hitch is exactly 8" off the ground on a flat, level surface with my subs in the hatch and no passengers. I'm sure it drops a couple inches with a full load of people inside (2 up front, 2 in the rear), and it's probably about 4 or 5 inches off the ground with the cargo platform on the back with the mower and stuff loaded. I'll measure that next time I load it up-- that platform itself weighs like 60 pounds!
Like I said, I can see myself buying a small flatbed single bike trailer for my motorcycle at some point, and the weight on that would be under a grand, all told, with bike (400#) and trailer (~500#) and gear (<100#), so I'm not too worried about my "rigged" hitch failing. The welds are really thick, and the guy used good materials. For a ton, I would be less secure about it, though.
BTW, how are you planning on lowering your RL another 2"? The most we've ever seen anyone drop (without baggin' it) is 2", and you supposedly run out of camber adjustment at that point. Are you planning on having some serious negative camber? Where are you going to get the springs?
Old 03-03-2019, 03:31 PM   #19
atikovi
If you're still around, do you have a brand name or part number for the trim? I was thinking door edge molding but don't think it would curve so tight.
Old 07-26-2019, 03:34 PM   #20
JakeBigDog2
JakeBigDog2 is on a distinguished road
Hey POPP, if you still subscribe to this forum, could you please post closer-up pics of the trim cutout for your hitch? How did your radius the corners of the cutout? I may be able to buy an 04 Vue RL with only 64,000 miles for about $4000. Sound like a good buy?
JakeBigDog2 is offline   Reply With Quote
Towing and other questions SL2Ghost42 S-Series Tech 18 08-30-2007 10:36 AM
Towing questions bassman912 Vue General 19 01-20-2007 11:02 AM
I have a question that may have already been answered. VickyJ74 Vue General 13 10-18-2006 12:49 PM
Towing Questions? topgun Vue Red Line 7 05-03-2005 12:17 AM
QC and Some Questions Answered SonataInFSharp Ion General 18 04-30-2003 01:00 PM
