Old 02-22-2010, 07:11 PM   #1
ShawnV
ShawnV is a jewel in the roughShawnV is a jewel in the roughShawnV is a jewel in the roughShawnV is a jewel in the rough
ShawnV's Avatar
2000 SW2
Default How-to Replacing heater core w pictures
Here is a how-to for replacing a heater core in a S-series second generation.
As always, I'd like to thank the saturnfans community and especially KingRex and OldNuc for their help with diagnosing and completing this repair.
Jack up the car high and properly on jack stands.
Remove the heater hoses from under the car:
These were a huge pain but slip-joint pliers worked well to remove the spring clamps then I grabbed the hose with channel locks and twisted it ever so slightly. The hoses slid right off after I tweaked them with the channel locks.
Next, remove the panels on either side of the console and remove a cover on the drivers side (5.5mm).
There are little clips holding the rear of the cover on, but they just pop off.
Remove the screw on the passenger side and remove the cover:
Remove the temperature control cable by lifting up on the little tab where the cable housing is held on, then unhook the loop in the cable:
There is a cover towards the front of the car with one 5.5mm screw. Remove this cover:
Next, remove the panel that’s directly covering the heater core:
Don’t do what I did and remove this cover just to have coolant spill everywhere, place a towel under there first!
Pull that cover out through the drivers side and there is one screw and clip holding the heater core on:
Remove the heater core:
Here’s a pic of the holes in the firewall that the heater core hoses pass through:
Feed the new heater core hoses through those two holes and replace the screw and clip to install the heater core:
Reinstall everything and fill up your radiator.
Some notes:
I didn’t drain my radiator, I just removed the heater core hoses and let the coolant drain.
All the tools I needed were pliers, 5.5mm socket, flathead, and a flashlight.
This repair took me less than 2 hours my first time doing it.
I didn’t have to take the dash or radio apart.
The worst part of this repair was getting the hoses off the heater core at the beginning. Also, cleaning up coolant from my floorboard was a pain.
Add to ShawnV's Reputation
Rate the quality of this post and help ShawnV reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 02-22-2010, 07:20 PM   #2
Default Re: How-to Replacing heater core w pictures
That looks good. Easy job just as long as you like laying half on the floor and the door sill.
Old 02-22-2010, 07:45 PM   #3
richpin06
richpin06 is a jewel in the roughrichpin06 is a jewel in the roughrichpin06 is a jewel in the roughrichpin06 is a jewel in the rough
richpin06's Avatar
Just be grateful you have a Saturn and not a another make of vehicle like this one.
http://www.youtube.com/watch?v=W0qJhyNRHx0
http://www.youtube.com/richpin06a
Add to richpin06's Reputation
Rate the quality of this post and help richpin06 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
richpin06 is offline   Reply With Quote
Old 02-22-2010, 08:01 PM   #4
sdowney717
sdowney717 is a glorious beacon of lightsdowney717 is a glorious beacon of lightsdowney717 is a glorious beacon of lightsdowney717 is a glorious beacon of lightsdowney717 is a glorious beacon of light
thanks for posting that, Now it is just another car I wont buy.
Add to sdowney717's Reputation
Rate the quality of this post and help sdowney717 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sdowney717 is offline   Reply With Quote
Old 02-22-2010, 08:27 PM   #5
ShawnV
ShawnV's Avatar
2000 SW2
I don't understand. You won't buy what car?
Old 02-22-2010, 08:33 PM   #6
rc1488
rc1488 has a spectacular aura aboutrc1488 has a spectacular aura about
rc1488's Avatar
Very niceee
Current: 95 SC2 Man 97 SL2 Auto 98 SL1 Auto 01 SL1 Man 02 SL1 Man
Past: 94 SL2 Man 95 SL2 Man 95 SL2 Man 96 SL2 Auto 97 SL2 Man 98 SL2 Auto 99 SL2 Auto
2010 SCCA Mohud Street Championship-2nd Place
Add to rc1488's Reputation
Rate the quality of this post and help rc1488 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rc1488 is offline   Reply With Quote
Old 02-22-2010, 08:47 PM   #7
richpin06
richpin06's Avatar
He was commenting on the vehicle in my link.Good job on your core replacement.
Old 02-22-2010, 09:13 PM   #8
SLCraig
SLCraig is on a distinguished road
1996 SL2
2000 SW2
MOST cars are that bad... My dad wants to replace the heater core in his Nissan Maxima... Pretty much same idea... remove the car around the heater core. Unbelievable.. Go Saturn!
1996 SL2 5MT
1997 SL1 5MT
2000 SW2 5MT
All gone, but not forgotten.
Add to SLCraig's Reputation
Rate the quality of this post and help SLCraig reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SLCraig is offline   Reply With Quote
Old 02-22-2010, 09:15 PM   #9
KingRex
KingRex will become famous soon enoughKingRex will become famous soon enough
KingRex's Avatar
1994 SL2
Very nice. It may still smell for a week or two cause of residue in the vents.
Enjoy scent free heat!
"The Homecoming King"
Saturns Saved: 18
Saturns Owned: 2
1999 SL2 HCE 175K
1994 SL2 HCE 135K
1999 SL2 Silver 125K
Add to KingRex's Reputation
Rate the quality of this post and help KingRex reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
KingRex is offline   Reply With Quote
Old 02-22-2010, 09:24 PM   #10
madpogue
1996 SW2
Wow, my wife and I must be doubly-blessed. I was actually test-driving some Escort wagons before I bought the SW2 (need "dodged a bullet" smiley here). And she has bought two mid-'90s ("OBS") Ford pickups in the last coupla years. Heater core went out in one about this time last year. We were all set to have the rather mannish young lady freelance mechanic down the street do it, presuming it would be a death sentence to try it in a driveway in February. WRONG; it's actually about the same work as our cars. I had it done before work one morning.
BTW, I *THINK* the '96 Saturn FSM officially calls for removing half the car around the core as mentioned above. This ^^^^^ looks WAAAY better. Now that I know it's just a bunch of covers to pull, I'm tempted to violate the "ain't broke" rule and just swap mine out when I do a coolant / thermostat job in the spring, just 'cuz I once in a blue moon get the faintest coolant smell in the cabin.
Now you've got me curious; gonna check the manual pages tonight.
Add to madpogue's Reputation
Old 02-22-2010, 10:34 PM   #11
The 98 manual has the procedure that ShawnV followed.
Old 02-23-2010, 12:37 PM   #12
dorisSL
dorisSL is on a distinguished road
dorisSL's Avatar
1995 SL
my friend and i got about 98% of the way on a Taurus once. very involved.
1995 SL, born 12/23/94, manual, WAI 190,500, "Doris"
(I'm Ben, the car is Doris)
you can't mulch at those speeds man, that's too fast
Add to dorisSL's Reputation
Rate the quality of this post and help dorisSL reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dorisSL is offline   Reply With Quote
Old 02-23-2010, 06:56 PM   #13
hholbein
Nice how-to on the Saturn replacement! As for the Escort video by richpin, I'm grateful our Escort heater went 185K w/o a problem. If it had died, I'd just take the heater out of the coolant loop and offer it for sale on Craiglist Florida or Arizona...
Add to hholbein's Reputation
Old 03-01-2011, 03:05 PM   #14
raffy
raffy is on a distinguished road
2000 SL
Nice! How much coolant came out of the heater hoses when you removed them? Did you pinch them to keep coolant from coming out? Did you have to add coolant after replacing the core?
Add to raffy's Reputation
Rate the quality of this post and help raffy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
raffy is offline   Reply With Quote
Old 05-02-2011, 09:40 PM   #15
tacticalturkey
tacticalturkey is on a distinguished road
Location: Toward the North end of the Central Valley, CA
1999 SL1
Thanks ShawnV, Awesome Post!! My heater core didn't have a leak...I was tired when I pulled the engine/trans and left a heater hose attached. Thanks again!!
Add to tacticalturkey's Reputation
Rate the quality of this post and help tacticalturkey reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tacticalturkey is offline   Reply With Quote
Old 04-22-2012, 11:05 PM   #16
pocket aces
pocket aces is on a distinguished road
my heater core went bad 1 day after replacing waterpump and serpentine belt.ty for the step by step as i intend to do this myself as i did the pump and belt.also,replacing radiator and driver side spindle.
Add to pocket aces's Reputation
Rate the quality of this post and help pocket aces reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
pocket aces is offline   Reply With Quote
Old 02-22-2010, 09:58 PM   #17
off-track
off-track has a spectacular aura aboutoff-track has a spectacular aura aboutoff-track has a spectacular aura about
off-track's Avatar
Excellent post Shaun! Under two hours on the first shot too. Proving once again why Saturns are great for DYI repairs. I'd say this definitely has a place in the how-to library. PM Charlie to add it.
1997 - SL2, barebones, 161k, Auto - Rebuild complete and.. burnt a valve 20k later Arrgh!
Purchased 114k 10/07
Added OEM CC
Add to off-track's Reputation
Rate the quality of this post and help off-track reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
off-track is offline   Reply With Quote
Old 02-22-2010, 10:30 PM   #18
MikeNW
MikeNW's Avatar
1997 SL
Will have to remember this. Odds are that I will do that to my car before it hits 20 years old But it doesn't look as hard as a lot of other cars.
Good job and great photos.
08 Burgman 400
Add to MikeNW's Reputation
Old 03-03-2010, 05:32 PM   #19
sdowney717
Richpin posted about the escort having to disassemble the entire front of the car to change the heater core.
On the buick roadmaster it simply is remove a plastic bottom drain pan and then unbolt it. What is tricky is some of the heater cores like in a 1991 to 1993 used a weird hose snapon connection. They designed it to make it very hard to push a regular hose over. And to buy the special heater hose is a very expensive dealer only part.
What typically happens is the connector corrodes itself on the pipe and is just about impossible to remove, so you end up destroying the hose getting it apart.
Also the heater core itself is a nice aluminum unit, BUT the tubes coming out of it swivel on a rubber o ring. Well the o-ring eventually shrinks, rots, and leaks. But the core will remain perfect. They did this to save space in shipping it. You can of course jbweld it but you know what, you got to get it out first.
You could likely cut off the offending nub on the hose pipe and jb weld epoxy a ridge into whats left to take a std hose.
Old 03-13-2010, 09:12 PM   #20
cmpcpro
cmpcpro is on a distinguished road
What makes these cores go out? I mean, they are in a little plastic box protecting them, are these a common problem on Saturns? Is there anyway to drain them completely before removing them? I would be really upset if any coolant made it to my carpet..
Christopher May
2002 Saturn SL2 5Spd.
Add to cmpcpro's Reputation
Rate the quality of this post and help cmpcpro reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cmpcpro is offline   Reply With Quote
Replacing Heater Core Glasact L-Series Tech 8 08-19-2010 11:02 PM
Used Heater Core Okay? Burgertime631 S-Series Tech 4 02-21-2007 01:46 PM
Heater core justin_zink S-Series Tech 2 12-08-2006 10:23 PM
Replacing Heater Core Hoses Leadsled Coupe S-Series General 7 09-01-2005 11:56 PM
Replacing heater core hoses ? (1997 SL1) Chris0381 S-Series General 0 05-30-2005 07:22 AM
