Old 01-18-2018, 01:58 PM   #1
Russet
2002 L-Series 3.0L Sedan
Default Hard shift after hard acceleration
I been noticing lately that on my Saturn L300 that after hard acceleration that I get a Service Wrench light. This isn't the same as the 1-2 slamshift but you differently can feel the change when this happens. But isn't limited to 1-2 but also 2-3 and 3-4 range so not sure what might causing this. I did have the 1-2 solenoid repaired and since then worked fine. But during the Slamshift after driving for some time it would come on but the hard drive shift in all range only happens when you done hard acceleration like passing otherwise it never rears it's ugly head. So has anyone had this happening lately. My 03 Saturn L300 is now entering 250K range and the only major tranx was the 1-2 repair.
Add to Russet's Reputation
Old 01-18-2018, 07:26 PM   #2
floridasl22002
Default Re: Hard shift after hard acceleration
It could be the pressure solenoid that needs replacing.
My son has a 2003 L300 which has hard shifting coupled with the wrench light on. We had it checked out by an auto tranny shop. The guy used his Tech 11 and told us that the tranny was compensating by keeping the pressure high. He told us that the condition could stay like that for a long time if the car wasn't used continuously for long journeys (it isn't). The other option was a rebuild at a cost of $2000.00. That's over 12 months since, the car still does it's little party piece, but hasn't gotten worse. If you don't mind cursing a lot and spending the weekend under the car, dropping the tranny down slightly, taking off the side panel and replacing the solenoids will (should) rectify the condition.
My best advice would be get it checked out with the Tech 11, given it's throwing codes with the wrench light coming on and then you can make an informed decision on what to do next.
Old 01-20-2018, 04:15 PM   #3
Russet
Unfortunately I did replace the 1-2 slamshift some time back. And the problem now doesn't exhibit the same problem how it happens. The slamshift for mine happened when normal drives this other problem happens after hard acceleration like passing then it happens no to long after that. But drive normally any other days and nothing happens. I'll have another that does Tranx do a checkup and ask him and see if he can get time to check it out.
Old 01-20-2018, 07:59 PM   #4
soulsurvives
soulsurvives is a name known to allsoulsurvives is a name known to allsoulsurvives is a name known to allsoulsurvives is a name known to allsoulsurvives is a name known to allsoulsurvives is a name known to all
2002 L-Series 2.2L Sedan
You need to get the codes to see for sure. My wife's was doing the hard shifting with the wrench light on and I replaced the pressure control solenoid and it solved the issue. The solenoid cost me about 40 bucks. Some trans fluid and a few hours later it was all good.
Old 01-21-2018, 01:00 PM   #5
Russet
Was this just on normal drives or after doing hard acceleration like passing and then back to normal driving?
Old 01-22-2018, 03:36 PM   #6
soulsurvives
It didn't really matter for the most part.
Old 01-23-2018, 07:55 PM   #7
Russet
I do know it hasn't happened and it does happen after doing 5K rpm passing the problem shows up but been driving regularly and it hasn't shown up.
Old 01-24-2018, 10:10 AM   #8
soulsurvives
You should get the code read. It could be an issue unrelated to the tranny. Perhaps at high rpm the mass air sensor is malfunctioning.
Old 02-07-2018, 07:22 PM   #9
Russet
I know I am trying to get it in but WI Cold doesn't help here. But I also not wonder if low Tranx fluid isn't causing it as well. But I have to get past this WI Cold to the shop so he can take a look.
No A/C after hard acceleration Cougarstang Ion Tech 29 08-24-2015 10:27 AM
SL2 slows down under hard acceleration Brian9720 S-Series Tech 18 02-28-2014 11:49 PM
1997 SL2-Hard shift-reverse hard sdheavymetal S-Series Tech 11 10-06-2012 01:18 AM
Hesitation with hard-acceleration Nickdfresh S-Series General 10 07-27-2006 01:50 PM
94 SL2 stumbles on hard acceleration Lukexzx S-Series General 19 01-03-2005 12:16 PM
