Old 01-24-2018, 06:14 AM   #1
MikeGlosta
MikeGlosta is on a distinguished road
Question LW300 idle rpm @ idle
I've had to replace Engine Coolant Sensor on 2003 LW300:
Idle is up a bit, approx 800+-, lower before the change.
Can't find recommended rpm in manual. Do you know what the parameters are for this car?
Thanks
Add to MikeGlosta's Reputation
Rate the quality of this post and help MikeGlosta reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
MikeGlosta is offline   Reply With Quote
Old 01-24-2018, 11:34 AM   #2
Default Re: LW300 idle rpm @ idle
650 rpm. Why did you replace the coolant sensor? Mileage, maintenance done, parts replaced? Throttle cleaned? Performed a throttle calibration? (turn on ignition, no pedal and wait one minute while throttle calibration from a program in the ECM occurs, cycle ignition off)
Surging idle in park and when started, flux idle in drive terminal89 S-Series Tech 2 06-07-2017 09:19 AM
04 2.2 5spd rough idle, stumbling, squeeking and rattling sound at idle tsdfab Vue Tech 2 06-04-2015 05:23 PM
2003 LW300 rough idle issues StephenMartinez L-Series Tech 6 07-21-2013 02:46 PM
01 LW300 3.0 stalling on idle Zummo L-Series Tech 2 11-21-2010 06:05 PM
idle idle idle idle idle idle (dead) nocolourblue S-Series Tech 23 12-29-2006 03:08 PM
