Old 04-14-2016, 11:02 AM   #1
crzyalbo
crzyalbo has a spectacular aura aboutcrzyalbo has a spectacular aura aboutcrzyalbo has a spectacular aura about
2008 Astra XR
Default P0420 Power Catalyst System Efficiency below threshold (Bank 1)
Has anyone had this code before and if so, what is the best way to resolve it. Will changing the Oxygen sensors resolve the issue or is the Cat gone at this stage.
BTW: Power is strong with no apparent performance issues at this time.
Add to crzyalbo's Reputation
Rate the quality of this post and help crzyalbo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
crzyalbo is offline   Reply With Quote
Old 04-14-2016, 11:28 AM   #2
billysvue
Default Re: P0420 Power Catalyst System Efficiency below threshold (Bank 1)
homework:
https://cse.google.com/cse?cx=partne...=P0420%20astra
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Add to billysvue's Reputation
Old 04-14-2016, 01:32 PM   #3
crzyalbo
2008 Astra XR
Sorry. Jumped the gun without doing my due diligence. Lots of good info on the links provided.
Old 04-14-2016, 03:01 PM   #4
From the service manual;
Probable Causes:
1-Sensor or solenoid faulty
2-Connector terminal contact is damaged or corroded
3-Wire harness - Check harness for correct voltage, open, short to ground or short to voltage
4-Update control unit software - Check for the latest control unit update
5-Powertrain or Engine Control Module faulty
6-HO2S sensor contamination/damaged
7-Exhaust leaks or restrictions
8-Catalytic converter damage
9-Catalytic converter improper operation
Cross off 4 and 5, leaving the rest as most likely possibilities. Mileage can help determine whether or not a catalytic converter is worn out besides an obvious exhaust restriction making the engine run strange; no power until the precat O2 sensor is removed to provide an alternate exhaust hole.
Old 04-17-2016, 01:18 PM   #5
emg77
emg77 has a spectacular aura aboutemg77 has a spectacular aura aboutemg77 has a spectacular aura about
emg77's Avatar
2008 Astra XR
Check your flex connector in the exhaust system (just back of the engine). Chances are that is has a hole in it (somewhat common problem). It's a cheap fix (probably about $100-$150) to have an exhaust shop weld on a new one.
Drives: 2014 Volt, 2017 Acadia
Past Cars: 08 Astra, 15 Acadia, 12 Enclave, 09 Traverse, 05 Vue, 04 Grand Prix, 00 Alero, 97 LeSabre, 72 Cutlass S
Add to emg77's Reputation
Rate the quality of this post and help emg77 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
emg77 is offline   Reply With Quote
Old 12-14-2016, 11:18 PM   #6
xdarkxfirex
xdarkxfirex has a spectacular aura aboutxdarkxfirex has a spectacular aura aboutxdarkxfirex has a spectacular aura about
Check for leaks and o2 sensors. More than likely a bad cat. If you dont want to pay an arm and leg to clear the code if it is the cat, use a spark plug fouler on the downstream sensor. It will make the reading and voltage more stable and fool the computer even with no cat.
Add to xdarkxfirex's Reputation
Rate the quality of this post and help xdarkxfirex reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
xdarkxfirex is offline   Reply With Quote
Old 12-15-2016, 09:22 AM   #7
waiter21
2003 VUE 2.2L
Check for any exhaust leaks as this could contribute to the problem. But I suspect you have a bad cat and / or downstream O2 sensor.
You might try the de-fouler trick before getting serious about a cat converter
I added defoulers to mine AND a new O2 sensor because I couldn't get the old one out without destroying it. So I can't say for sure the de-foulers solved it, or the O2 sensor solved it. But I didn't need to replace the Cat converter.
no more P0420 code. I would recommend NOT clearing the codes. Do the mods and then if the problem is solved, the code will clear itself.
http://www.saturnfans.com/forums/sho....php?p=2193404
Add to waiter21's Reputation
Old 05-31-2018, 02:26 PM   #8
ulemon
ulemon has a spectacular aura aboutulemon has a spectacular aura aboutulemon has a spectacular aura about
The Astra has two O2 sensors, right? When you say you replaced the O2 sensor I am guessing you replaced the one behind the cat, right?
EDIT: Dumb question, you guys mentioned downstream sensor like 5 times....
Add to ulemon's Reputation
Rate the quality of this post and help ulemon reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ulemon is offline   Reply With Quote
Old 07-27-2018, 10:46 AM   #9
ulemon
Hey so I had a P0420 code, I bought an O2 sensor and spacer from Amazon. O2 sensor was ACDelco 55565000 and put that in the rear downstream O2 sensor location. I no longer have a P0420 code but I do have new codes that are P0161 and P0141 which is to do with the heater circuit for the sensor. So I guess my question is should I replace the o2 sensor again? Or is the computer confused that my o2 sensors have good data now? I checked live data from rear o2 sensor and its at a nice 430mV all of the time. Front o2 is fluctuating between rich and lean as expected and rear is lean.
Old 07-27-2018, 11:25 AM   #10
ulemon, as you know, the original poster crzyalbo are like many members not following up to report whether or not a solution solved their problem. This leaves many threads open.
I'm not sure why there are two error codes, P0161 and P0141, pointing to the same problem (rear downstream heater in the O2 sensor). The heater, wiring and connections are issues, not the actual sensor itself that you verified by seeing output signals.
P0141 - https://www.obd-codes.com/p0141
P0161 - https://www.obd-codes.com/p0161
Old 07-28-2018, 12:05 AM   #11
ulemon
I would like to add, that I am a little down on gas mileage (usually 26, im at 22 right now) and I am a little down on power but don't ask me how I know that all I will says im down on power by about 10 miles per hour while gunning it
Old 07-30-2018, 10:36 AM   #12
crzyalbo
2008 Astra XR
My bad. i mucked around with things and eventually i changed both Cats. Car performs much better, in terms of mileage and quickness.
p0421 - WARM UP CATALYST LOW EFFICIENCY BANK 1 hufhouse L-Series Tech 2 08-18-2014 11:21 PM
p0430 catalyst efficiency low bank 2 erik@howes Aura General 1 06-23-2014 02:06 PM
Catalyst efficiency? Good cat or bad cat? 38TransAM S-Series General 0 03-05-2014 11:33 AM
Catalyst under efficiency -- new catcon? Do it myself? vtbirch L-Series Tech 2 10-05-2013 12:24 AM
P0420 Catalyst System Low Efficiency xcfmx S-Series Tech 7 01-12-2005 04:34 AM
