Old 07-23-2018, 04:35 PM   #1
crzyalbo
crzyalbo has a spectacular aura aboutcrzyalbo has a spectacular aura aboutcrzyalbo has a spectacular aura about
2008 Astra XR
Default Automatic Transmission Cooler
I recall someone posting instructions on how to bypass the tranny cooler due to the high frequency of transmission failures as a result of the tranny fluid mixing with the coolant. for the life of me I can't find that post. does anyone recall this posting or I imagining things.
joe
Add to crzyalbo's Reputation
Rate the quality of this post and help crzyalbo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
crzyalbo is offline   Reply With Quote
Old 07-24-2018, 12:56 AM   #2
Default Re: Automatic Transmission Cooler
You're definitely not imagining things. I did some searching using both the Google Custom Search and the Advanced Forum Search features. I did better with the latter search feature in this instance. However, the best thing that I could come up with was that AstraFasta had found a website which discussed the installation of an add-on transmission oil cooler. Unfortunately, the webiste linked on his post is not good any longer.
http://www.saturnfans.com/forums/sho...mission+cooler post #4 has the unusable link
In at least three threads he has mentioned the need to install an add-on transmission cooler and has apparently done so himself, but no instructions were found which discussed the installation of one. It seems like AstraFasta is the one you want to contact to find more information about this.
303,000 miles - Holy canolli!
Add to pierrot's Reputation
Old 07-24-2018, 01:03 PM   #3
AstraFasta
Unfortunately that huge AstraOwnersClub site is closed but doing a search here might help you (or you might need to find a more recent archive)
http://web.archive.org/web/201206221...splay.php?f=10
The transmission shop replaced both the transmission and installed a separate oil cooler circuit. They said the oil cooler was cheap and easy to do
Old 07-25-2018, 07:07 PM   #4
crzyalbo
2008 Astra XR
Not having much luck finding any instructions on the suggested sites. Any chance that you can post a few photos of the cooler so I can get an idea of what needs to be done.
Old 07-25-2018, 11:26 PM   #5
A picture will certainly help in getting an idea as to where one might locate the cooler. Since these items are not application specific (the difference is only in the size of the cooler and adapters required [parts kit]) there is no one specific location to use, only a specific area in which it must be placed. Installation instructions will make that clear.
Take a look at the Hayden websited and you can find installation instructions there > https://www.haydenauto.com/featured%...s/content.aspx >hover mouse over Install Tips>click on Instruction Sheets> read them carefully.
Small transmission fluid leak from radiator transmission cooler line EvanVanVan S-Series Tech 5 10-13-2014 07:55 PM
Automatic Trans Cooler Daveg97 S-Series General 3 08-28-2011 07:37 PM
Transmission cooler: before or after stock cooler? PlasticCarsRock S-Series Tech 15 08-27-2011 06:01 PM
Transmission cooler/radiator replacement when transmission is bad? infinitewisdumb S-Series Tech 2 04-16-2010 09:59 AM
automatic trans cooler emesnarf S-Series Tech 6 04-07-2009 07:08 AM
