Old 08-31-2005, 12:14 AM   #1
pawils3
pawils3 is on a distinguished road
Default Rear Bumper Cover
Considering buying a rear bumper cover, because I read in a poll that it was a good accessory to purchase. My question: Is it hard to install? And how is it installed?
pawils3 is offline   Reply With Quote
Old 08-31-2005, 07:07 AM   #2
Dave44
Dave44 is on a distinguished road
Default Re: Rear Bumper Cover
very simple--you get some rubbing alcohol and clean the area where the 2 sided tape is and carefully take tape strip off and attach. seemed a little cheesey, but really holds well. you just have to get it lined up 1st and once you attach it there is no moving it. Think I payed about
25$ for it.found the web site here for the cheapest $$ .
sorry cant rember it right now,you could do a search for a thread i started about 3 weeks ago.
Dave44 is offline   Reply With Quote
Old 08-31-2005, 07:55 AM   #3
2004NJVue
2004NJVue is on a distinguished road
2004NJVue's Avatar
2004 VUE 3.5L
I have to echo that opinion, it was extremely simple to install. I let my girlfriend tell me if I was centered and such before I stuck it down. She has better eyes for that kinda stuff than I do. I payed about the same, 25-30 bucks. I dont remember exactly. It was definately well worth the investment. The bumper (without the pad) scratches so easily from loading stuff into the Vue. The bumper guard keeps it looking new. When clean, it also adds a nice contrast in color to the bumper since it is shiny black. I think it should have been standard. It also makes it less slipery to stand on the bumper when puting items up top. Only negative I can find with it is it holds the dirt (and probably snow - have not had it on for a winter yet) much more than the stock bumper. You can probably see some shots of it in some of my photos (clean and dirty).
Current: 2004 Saturn Vue V6 Awd (purchased new November 04) >130,000 Miles
1996 Saturn SL2 - 300,000 miles
Past Saturns: Ask me
Only live once, enjoy it!
2004NJVue is offline   Reply With Quote
Old 08-31-2005, 07:59 AM   #4
mikec
mikec will become famous soon enough
mikec's Avatar
I got mine from saturnaccessories.com . Paid about the same price. Easy to install. Mine was off about an eighth of an inch but it is not that noticable. It definitely helps hide the scuffs on top of the bumper. The only thing I don't like about it was that my bumpers had faded and the cover was black. They didn't match initially but are now starting to blend in as the same color.
mikec is offline   Reply With Quote
Old 08-31-2005, 06:11 PM   #5
bboyd
bboyd is on a distinguished road
bboyd's Avatar
2004 L-Series 2.2L Sedan
I also got mine at www.saturnaccessories.com for about $30 shipped.
On another note I recommend the splash guards. They run about $65 and really add to the appearance of your VUE.
LIFE is drawing without an eraser!
Semper Fi
bboyd is offline   Reply With Quote
Old 08-31-2005, 06:44 PM   #6
stew32
stew32 is on a distinguished road
2004 VUE 3.5L
I got one from saturnaccessories.com too. I think it makes the bumper look more finished. Don't have to worry about scratches loading/unloading. It does hold snow more than no cover, but you just brush it off. Easy install- use rubbing alcohol to clean the bumper, check alignment, remove the tape and stick it down.
stew32 is offline   Reply With Quote
Old 08-31-2005, 10:01 PM   #7
2004NJVue
2004NJVue's Avatar
2004 VUE 3.5L
Mine came with those...they are great for wet roads, dry roads, dirt roads, and very light offroad (no rocks - just mud). However, if you plan to take it over any curbs, rocks, or heavier off road you will probably crack or lose a mudflap. I cracked one and loosened one. I was able to tighten the one back up though. And in snow, I find they collect too much of the snow in the wheel wells and cause the vue to vibrate a little. I also find that backing up in deep snow can result in a bent mudflap (I saw another car (RAV-4) do that once.
Old 08-31-2005, 10:03 PM   #8
runerx
runerx is on a distinguished road
runerx's Avatar
2003 VUE 2.2L
The only trouble I have with mine and i believe I've heard the same from others is that The lower edge of the lift gate especially in the corners can rub and begin to rust. I paint mine every so often because I cant find a cure with out removing some of the plastic. Otherwise I love the cover and would definately recomend it.
DJ
runerx is offline   Reply With Quote
Old 08-31-2005, 10:19 PM   #9
2004NJVue
2004NJVue's Avatar
2004 VUE 3.5L
DJ
I gotta check that out...I never noticed any rubbing...will let you know tomorow if mine does.
Old 08-31-2005, 11:02 PM   #10
BlkVue1
BlkVue1 is on a distinguished road
Thumbs Up Re: Rear Bumper Cover
Installed mine in March no rubbing on mine.
BlkVue1 is offline   Reply With Quote
Old 08-31-2005, 11:59 PM   #11
runerx
runerx's Avatar
2003 VUE 2.2L
I looked at mine after others had posted about it and sure enough it was.
It was very minor but stil rubbed through the paint.
No biggie just gotta keep after it.
Old 09-01-2005, 03:02 PM   #12
2004NJVue
2004NJVue's Avatar
2004 VUE 3.5L
I checked...and sure enough, no rubbing. I did notice it was close, but no rubbing. When I closed it the first time I did get a cloud of dust in my face. Then I opened and closed it slowly...and no rubbing. So I cleaned the bottom of the hatch and had no scratches whatsoever. Mine has also only been installed for about 2 or 3 months. I dont know when you installed yours, but maybe they changed the design slightly. I will keep checking it though to make sure.
Oh, on second thought, I do have a new bumper from when I was rear ended at a stoplight. Maybe they installed the new one improperly...just enough to make it slightly lower. Oh well.
Old 09-01-2005, 11:11 PM   #13
Dave44
I found my packing slip-was going to order everything form saturnaccessories but found this place was cheaper for the same parts autowebaccessories.com
mud flaps were 50$ for all of them,roof rails were
113$/pair, rear bumper pad was 24$, they were just cheaper across the board, oem parts,fast shipping, wouldnt hesitate to buy from them again.........
Old 09-02-2005, 10:00 AM   #14
joeftpierce
joeftpierce is on a distinguished road
2004 VUE 3.5L
Got mine from Saturn dealer. I have a large dog that rides in the back and if no cover, the bumper would have been destroyed.
joeftpierce is offline   Reply With Quote
Old 09-02-2005, 11:52 AM   #15
SLAPSHOT
SLAPSHOT is on a distinguished road
SLAPSHOT's Avatar
"Not so fast my friend". I priced the grill gaurd, side step rails, and mud gaurds at both sites. autowebaccessories was cheaper than saturnaccessories on the list price, but when I added shipping at both sites, autowebaccessories was $5 to $10 more expensive than saturnaccessories. Another good place to get accessories from is eBay seller "saturn_of_tallahassee". I picked up a couple of bug shields for our VUE's for $62 each....shipped.
//SLAPSHOT//
05 VUE 2.2L 5 Speed
SLAPSHOT is offline   Reply With Quote
Old 09-02-2005, 11:30 PM   #16
Dave44
true-- with shipping included I still saved about 40$ on
the order, was 311$ total, I think saturnacc was over 350
Old 09-02-2005, 11:56 PM   #17
SLAPSHOT
SLAPSHOT's Avatar
I just placed an order with saturnaccessories.com, and here's what I ordered:
1) All weather floor mats, front & rear
2) "Saturn" windshield sunshade
Total of order including shipping: $94.85
The exact same order at autowebaccessories.com was going to be $96.58 including shipping. I only saved $1.73, but that's a couple of cokes at work. I have found this to be the case with every item I've checked on....saturnaccessories.com is always cheaper. Maybe you live closer to the autowebaccessories warehouse than I do, thus you get a better deal with them. I must live closer to Georgia than you do, thus I do better with saturnaccessories.com. Then again, who really cares?
//SLAPSHOT//
05 VUE 2.2L 5 Speed
Old 09-03-2005, 08:10 PM   #18
Dave44
found my receipt
autoweb saturnacc
1. cargo mat 31.88 45
2.molded splash
guards 50.10 57
3.roof crossbars 113.85 125
4.hood air deflec 49.34 69
5.rear bumper pad 25.05 35
shipping 41 FREE
total 311.22 331
was only 20 bucks diff. but hey I can put that in the tank
Old 09-03-2005, 10:05 PM   #19
sschumann
sschumann is on a distinguished road
sschumann's Avatar
My recommendations are the bumper guard, mud flaps and hood deflector. All protect the truck very well. Got them all from Saturnaccessories.com and I'm extremely pleased with their support and service.
sschumann is offline   Reply With Quote
Rear Bumper Cover gpkarr Outlook General 0 11-08-2007 02:24 PM
Rear bumper cover removal? froggy81500 Ion Tech 5 09-12-2007 11:45 AM
looking for rear bumper cover base Eedie Vue Tech 5 11-22-2005 07:24 PM
Need a rear bumper cover headcase650 Ion General 3 08-02-2005 12:37 PM
Looking for rear bumper cover stomli1 Classifieds 0 01-10-2003 03:31 PM
