Old 04-07-2020, 07:53 PM   #1
Bentley8
Bentley8 has a spectacular aura aboutBentley8 has a spectacular aura aboutBentley8 has a spectacular aura about
Default Any way to test an axle out of the car?
Heavy sigh.
I had a friend help me clean out my workshop this weekend. I had pulled three great condition axles out of the local junk yard like 10 years ago and have been holding on to them as spares.
Well, he was moving them, and not knowing anything, just pulled them up by the ends and accordioned the boots, so the shafts separated. It was only for a moment, though. Boots are fine. As I understand it, the tiny pins could have moved inside, making the CV unusable.
Is there any way to test them and see if they're still good?
Thanks
1999 Saturn SL2 -- 2000 Saturn SW2 -- 2001 Saturn SC1
Bentley8 is offline   Reply With Quote
Old 04-07-2020, 09:42 PM   #2
bumpdraft
bumpdraft's Avatar
1998 SW2
Default Re: Any way to test an axle out of the car?
There is a correct way to test them.
Here is an incorrect way that I found useful:
Hold the axle horizontally with both hands, one on either side of the boot. Hold the short side at the threads. Hold the “long side” at the balance point so that all parts of the axle are horizontal. Now, listen and feel for rattles by shaking the axle up and down like you’re doing fast, small 1” weightlifting curls.
Maybe it’s just the lack of grease in them, but I’ve identified some suspect, high-mileage axles by getting them to rattle.
Old 04-08-2020, 05:06 PM   #3
Posts 5 and 7 by OldNuc have info
http://www.saturnfans.com/forums/sho...d.php?t=137511
OldNuc was last on in March 23, 2020, was a but worried as I hadnt seen any posts for a while
OBDII failed self test smog test failed craigar S-Series Tech 23 08-21-2017 04:46 PM
Replace Axle Seal While Replacing Axle? Keblar S-Series Tech 1 10-18-2012 03:35 PM
ABS axle on non-ABS car Ramics S-Series Tech 9 04-24-2012 03:06 PM
ignition test vs. CPS test for no start troubleshooting laribel S-Series Tech 1 04-08-2011 04:47 PM
CV Axle RalliArt16 S-Series Tech 6 07-25-2005 04:10 PM
