Old 03-02-2017, 11:05 AM   #1
MisterAustin
MisterAustin is on a distinguished road
Default Best Speed to Drive the Astra 5 speed
Okay, so just before winter hit I bought myself a lil 3 door 5 speed Saturn Astra. I love this car but it is so high revving that I don't know what speed to drive at to save gas (posted 80). on the freeway I have the car revving at 3500 rpm because that is the only speed that it's decent on fuel on. So anybody have a 5 speed Astra let me know what you think. Thank you in advance.
MisterAustin is offline   Reply With Quote
Old 03-02-2017, 09:57 PM   #2
maschinenbauer
maschinenbauer will become famous soon enoughmaschinenbauer will become famous soon enough
maschinenbauer's Avatar
2008 Astra XE
Default Re: Best Speed to Drive the Astra 5 speed
Most cars in general get the best gas mileage at or under 55 mph. Fast enough to get somewhere, slow enough for aerodynamics to not have much of an effect. Generally once you're in top gear, the faster you go the more fuel you consume to overcome drag. Engines do have "sweet spots" in the RPM range where they burn less fuel per hp, but generally slower is more efficient because it requires less hp since there is less drag.
'08 Astra XE 5-speed
'72 Chevrolet El Camino
'31 Ford Model A pickup
maschinenbauer is offline   Reply With Quote
Old 03-04-2017, 05:36 PM   #3
PaulR
PaulR will become famous soon enough
Between about 55 -60 mph is the best fuel economy that I have found. This is usually fast enough for two lane roads to keep up and be safe, but you still could die from boredom. At speeds greater than 65 -70 mph these cars really suck gas. When I drive home from work late at night I go about 65 mph in a 70 mph zone, owning the right lane, just to save a little gas. But that's just me.
PaulR
2008 XR3 5 speed, heated seats, leather, premium sound , 18" wheels, center armrest
2008 XE5 CEL Special Edition, 5 speed, heated seats, panoramic moonroof
PaulR is offline   Reply With Quote
Old 03-13-2017, 05:15 PM   #4
David R
David R is on a distinguished road
2009 Astra XE
1997 SW2
Going to take a slightly different approach. I find between about 2500 and 3000 RPM in 4th or 5th for most conditions. For me that's between 95 and 100 KPH on the highway. Not much penalty going up to 105 KPH, but above that I can see my numbers falling. I do find the noise level at 3500 and above quite objectionable. Below 95 my consumption rises, and down around 80 KPH (2000), I'm not at all impressed with what I'm seeing. In the city I do find that getting into the higher gears quickly does help. Getting into 4th or 5th for 50 to 60 KPH (1500) really helps, just don't try and accelerate. I'm stuck with the instantaneous fuel economy showing, so I'm constantly reminded of my fuel economy.
~I'm not an authority on anything~
2009 Astra XE 5sp 225K km
2000 Honda Civic SI 5sp 172K km, AKA EX Coupe - Gone
1997 SW2 DOHC Auto 330K km - Parked, waiting for the value of scrape to go up
David R is offline   Reply With Quote
Old 03-15-2017, 10:36 AM   #5
C152
C152 is on a distinguished road
C152's Avatar
2008 Astra XE
2008 Astra XR
Hello everyone,
Yeah, noticed that on the test drive. Would've liked a sixth gear. As it is, I drive at the speed where my inst. fuel consumption is 6.9 l/100km (34 mpg.) That turns out to be about 100 km/hr. If that helps.
Kind Regards,
C152
2008 Saturn 5dr XE (Opelized) Astra
2008 Saturn 3dr XR (to be Opelized)
C152 is offline   Reply With Quote
Old 03-15-2017, 04:43 PM   #6
tackepj
tackepj will become famous soon enough
tackepj's Avatar
2008 Astra XE
I've averaged 31-33 mpg year in and year out since I bought the car new in 2009. For highway driving (speed limit withstanding, of course) I set it at 70 mph, which I believe is about 3250 rpm. That keeps the instantaneous mpg around 33-34, which is fine with me. Sometimes I get passed like I'm standing still.
This car begs for a taller top gear. I suspect that GM supplied one manual gearbox for all the engine options, and anything taller than this one made the smaller engines available in other markets struggle. Too bad for us in the NA market with only the 1800 engine available. I would be more than willing to have to occasionally drop a gear to maintain speed on hilly terrain if it meant a less boomy engine note for long highway trips...
It's amazing the progress that's been made even over the past 10 years or so. I can achieve similar highway mpg out of a 310 hp Mustang at a higher average speed, and close to 40 mpg from a mid-size, automatic trans sedan.
Former: 2005 L300, 2007 VUE Green Line
Current: 2008 Astra XE
tackepj is offline   Reply With Quote
Tags
astra, manual, opel, saturn astra, vauxhall
Removing the Speed Limiter: Disconnecting the Input and Output Speed Sensors AlexofNazareth S-Series Mods 35 11-19-2010 07:21 PM
Break in for Astra XR 5 speed jared myers Astra General 3 09-27-2008 09:43 AM
More Six-Speed Automatics Coming as GM Announces Plan to Close 4-Speed Transmission P Charlie General Saturn Discussion 1 05-13-2008 08:49 AM
Danger: High speed thread! Top speed on L300V6 and 2.2 -ecotec? 2k3L300HID L-Series General 64 03-10-2005 11:53 PM
RE: 5-speed ION drive paramour Ion General 2 10-23-2002 09:32 PM
