Old 03-28-2016, 05:14 PM   #1
MikeBurlison
MikeBurlison is on a distinguished road
Default Torque specs
Anyone have the torque specs for the front brake calipers and mounting brackets? Also, the bolts for the one-piece bearing/hub assemblies. Also again, the axle nut and tire lug nuts. For the 2002 awd Vue. 3.0. Non-abs. Thanks
MikeBurlison is offline   Reply With Quote
Old 03-28-2016, 10:36 PM   #2
far2grumpy
far2grumpy's Avatar
Default Re: Torque specs
Lug nuts are 100 pd ft and other stuff should be in following extracts.
Old 03-29-2016, 12:03 AM   #3
MikeBurlison
Thanks!
Torque Specs FINCH Vue Tech 1 10-04-2013 09:48 AM
torque specs???? Drew Fiedler S-Series Tech 1 06-05-2007 04:45 PM
Nut Torque Specs for 1999 SL2 Torque Axis Mount todd8 S-Series General 3 05-01-2005 01:34 AM
torque specs. steved350 Miscellaneous Tech 1 08-22-2004 09:04 PM
Tie Rod Torque Specs? Flyguy405 S-Series Tech 1 12-06-2003 06:58 PM
