Old 10-15-2015, 02:38 PM   #1
CaptainMouse64
CaptainMouse64 is on a distinguished road
CaptainMouse64's Avatar
2002 SL1
Question Front wheels squeaking when turning right or left
Hey guys, an issue has come up with the old 2002 SL-1. When I steer right or left, a very audible "squeak, squeak,squeak" sound chirps up from the front wheels. Both the right and left, but each has a different "squeak time" between when the "squeak" happens. Both are dependant on the speed of the turn, and the degree of the turn of the wheel.
It does not happen as much when I am backing up and then turn the wheel, like when I backup out of my driveway.
A friend claims it could be the brake rotors or some other brake part rubbing against the hub at a specific time during the revolution of the wheel, which makes sense.
But for it to happen on both wheels, right around the same time?
Any ideas, and any ideas how to check and correct this issue?
Thanks in advance guys and gals!
- A different kind of company, a different kind of car.
CaptainMouse64 is offline   Reply With Quote
Old 10-16-2015, 08:01 AM   #2
toggenburg
toggenburg's Avatar
Default Re: Front wheels squeaking when turning right or left
IDK but it might be the struts are squeaking in their lower mounts.
Old 10-16-2015, 09:13 AM   #3
floridasl22002
There is another thread on General with someone having a squeak issue at the front end. He found his dog bone bolts were loose.
Old 10-16-2015, 01:23 PM   #4
Steve44
Steve44 is just really niceSteve44 is just really niceSteve44 is just really niceSteve44 is just really nice
Steve44's Avatar
1999 SL1
Your brake pads have warning indicators that make that squeal when your pads are so low that they should be replaced.
Check your front brakes.
The SL1...The Lucky Car
The SL2..The awesome deal.
The #3 Silver SL2 FIVE SPEED!
World's biggest fan of doing it the easy way.
Old 10-26-2015, 02:48 PM   #5
CaptainMouse64
2002 SL1
Hey guys, thanks for the responses. I don't think it's the brakes, it only happens when I am turning, not when braking when going straight. I will try the dogbones and tighten them down. If the struts are squeaking in the lower mounts, what is the fix?
thanks!
Old 10-26-2015, 09:14 PM   #6
billr
Still, checking the brake pads is so easy to do, why not? It could be the indicators squeaking, even while not braking.
Old 10-27-2015, 01:18 PM   #7
Steve44
Steve44's Avatar
1999 SL1
^^^This.
Thinking it's not the brakes is not an option.
Check them.
Old 10-27-2015, 02:31 PM   #8
Special Forces
Special Forces has a spectacular aura aboutSpecial Forces has a spectacular aura aboutSpecial Forces has a spectacular aura about
Special Forces's Avatar
2006 ION Red Line
thanks!
Why do you assume your brake pads don't come in contact with your rotor during a turn? Deflection is a phenomenon typically on higher G-force vehicles such as race cars where the rotor actually becomes positioned at an angle during a turn and pushes the piston back into the caliper ever so slightly (look for race car drivers to tap the pedal with their left foot before entering the next turn, this is them bringing the piston back out). In our cars it may do as much as just lightly touch the rotor to the pad during a turn and give you a slight squeak sound. Typically I get the sound once the pads are worn halfway or a little more every now and then.
/// Need rebuilt valve bodies? PM Me. \\\
//// Why bother with ebay when I'm right here? \\\\\
Valve bodies built to order
Please PM me about valve bodies, do not post a visitor message.
Special Forces is offline   Reply With Quote
Tags
annoying, brakes, noise, sound, squeak
Front passenger qheel squeek wile turning left Dave3 S-Series Tech 5 07-25-2014 06:54 AM
'04 Front End 2 Noises, turning left and while driving skygoing Vue Tech 1 02-27-2013 04:50 PM
Front end noise while driving but goes away when turning to the left scmcketa S-Series Tech 4 04-12-2010 12:17 AM
Loud 'squeaking and grinding' when turning wheels. Help? CaptainMouse64 S-Series Tech 12 03-31-2010 12:58 PM
Noise from left front when turning the wheel tim-4878 S-Series Tech 10 04-16-2008 09:44 PM
