Old 02-20-2013, 02:49 PM   #1
Stupidusernames
Stupidusernames is on a distinguished road
Default Metal gasket between wheel hub and Steering knuckle
What's the deal with this thing?
I have heard conflicting information. Some say just remove it, some say it's needed for proper functioning of the wheel bearing.
What is the consensus and what are thoughts on just reusing the old one?
Stupidusernames is offline   Reply With Quote
Old 02-21-2013, 01:17 AM   #2
wolfman
wolfman's Avatar
Default Re: Metal gasket between wheel hub and Steering knuckle
It's there to ensure the bearing is "square" in the base of the hub when torqued to spec. In short, it allows the precision machined bearing to mount "evenly" ( for lack of a better word ) in the hardly at all machined ( not precise by any measure of the imagination ) cast hub. Of note: Not all Vues have them, they seemed to have been added as an afterthought... perhaps to try to reduce run-out related bearing and/ or brake rotor failures.
If you have them... I'd replace them...OR, as an alternate, reuse them ensuring they go back on orientated EXACTLY as they came off.
Old 02-21-2013, 12:51 PM   #3
Stupidusernames
Awesome info! Thanks!
I ended up re-using it and putting it back on the way it was. I don't think the passenger side has one on. Maybe I'll just order two of em put them on.
Steering knuckle Rand0m0sityxX S-Series Tech 6 05-19-2010 10:42 PM
Steering knuckle jam12 Ion Tech 6 08-01-2008 10:39 AM
Wheel Bearing with steering knuckle assembly fleedermouse S-Series Tech 3 05-14-2008 02:20 PM
P/S Steering Knuckle... DevilDogMech S-Series Tech 16 08-07-2007 02:00 PM
'93 sl2 steering knuckle daddio S-Series General 13 03-03-2005 07:53 PM
