Closed Thread
Old 06-16-2002, 12:44 AM   #1
avni_01SL2
avni_01SL2 is on a distinguished road
Question Cracked Rotors already?
re 2001 SL2 18,600 miles.
First time in many cars that this has happened to me -- I brought my car into a local mechanic for an oil change and tire rotations (18,000 miles)
the tech pointed out on the right front brake rotor, what he said were hairline cracks. Said the rotor is unsafe and should be changed.
So -- the original brake pads were still good. Very hard to believe that the rotors would be cracked before even going through a single pair of pads.
The tires had been rotated by a Saturn dealer at 6K miles. The wheels had not been removed other than that time.
So is this mechanic trying to rip me off to the tune of $240 for new rotors and pads (you don't just change one rotor)?
Or is he right and Saturn put out a car with substandard brake parts?
Or is he right, and this sort of thing just happens now and then?
Opinions?
avni_01SL2 is offline
Old 06-16-2002, 01:13 AM   #2
ssicarman
ssicarman's Avatar
Default Re: Cracked Rotors already?
Opinions?
I don't think that I have EVER seen a Saturn brake rotor cracked. If indeed it is then yes he is trying to rip you off because a cracked rotor should be covered under the warrenty. If nothing else as a safety item and I don't think that any store would argue over that. How does he figure that the OEM Saturn brake parts are substandard??? I think that the only way you might get the rotors to hairline crack would be to get them incredibly hot and then suddenly cool them. Hard to do?
Take the car into Saturn and see what they say.
ssicarman is offline
Old 06-16-2002, 03:47 AM   #3
1320Doc
1320Doc is on a distinguished road
Default
Been with Saturn since 1993, can't recall ever seeing cracked rotors either. Seems unusual.
1320Doc is offline
Old 06-16-2002, 01:34 PM   #4
XtremeGrandAm
XtremeGrandAm is on a distinguished road
Default
hmmm thats really interesting....I dealt with warping but never heard of cracking.
XtremeGrandAm is offline
Old 06-16-2002, 10:36 PM   #5
Mark G
Mark G is on a distinguished road
Default
Regardless of whether or not the rotors are cracked, if he is trying to charge you $240 for new rotors and pads, then he is trying to rip you off in a major way! I recently replaced my front rotors and pads myself for a grand total cost of $65.
Mark G is offline
Old 06-17-2002, 10:07 AM   #6
dieseljack
dieseljack is on a distinguished road
Default
At Auto Zone, good quality rotors are $19.00 each, and pads are $18.00 a set.
dieseljack is offline
Old 06-17-2002, 10:12 AM   #7
ricksLS1
ricksLS1 has a spectacular aura aboutricksLS1 has a spectacular aura about
ricksLS1's Avatar
Default
I think this should be covered under warranty. Ask the service manage and if no results write to Saturn.
ricksLS1 is offline
Old 06-17-2002, 10:23 AM   #8
eRic 02sc2
eRic 02sc2's Avatar
Dazed
last time i checked, saturn factory rotors were about $50 each ($100 pair) and the pads were around $70 a set. so you have about $170 or so in parts. add an hour of labor ($65) and sales tax and there's your $240. when you replace the cracked rotor, do both. never do one side only. btw the only time i've seen cracked rotors on a saturn but they were cross drilled rotors that cracked around the holes.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
eRic 02sc2 is offline
Old 06-17-2002, 11:02 PM   #9
avni_01SL2
Default
OK Thanks for all your replies
I am suspecting now that they were pulling my chain.
It seems so unlikely that the rotors would be cracked at this point.
They showed me some hairline curves in the surface of the rotor -- this is what they said were the cracks. 3 or 4 on the left rotor, and 1 on the right.
time to get a second opinion.
Thanks again
Avni
Old 06-17-2002, 11:27 PM   #10
Plastic Gravity
Guest
Posts: n/a
Default
Thanks again
Avni
Ive seen rotors that have a pockmarked surface, and some small cracks from the vehicle being driven infrequently, or always in wet conditions, but the cracks always came out when the rotor was turned. Youre on the right track...go back to your dealer, if they are genuinely cracked, then you deserve to at least have them turned, or a new set of rotors.
Closed Thread
Cracked Head Jenn07 S-Series Tech 8 09-21-2007 02:18 PM
Cracked Header saturnpowersw2 S-Series General 15 06-12-2006 05:22 PM
cracked, just where you said!!! callmethewander S-Series Tech 3 06-10-2004 11:53 PM
Cracked Windshield KrgION03 Ion General 11 06-09-2004 07:05 PM
Cracked Radiator piratepress S-Series Tech 1 01-17-2003 11:50 AM
