Old 05-27-2020, 08:24 PM   #1
onefellswoop
onefellswoop is on a distinguished road
Default Broken Stud Top Motor Mount to Frame/Bracket
not sure to go with this one, forgot to remove the jack from under the oil pan before torquing down this bolt and it's snapped off
onefellswoop is offline   Reply With Quote
Old 05-27-2020, 10:01 PM   #2
Zeebins
Zeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to behold
Zeebins's Avatar
Default Re: Broken Stud Top Motor Mount to Frame/Bracket
I have a feeling your only option if to grab another mount bracket from the junkyard. Number 4 in the diagram. Someone else may have a better idea though
97 SL2, auto, 119K miles
Old 05-27-2020, 10:03 PM   #3
Zeebins
Zeebins's Avatar
Or alternatively, this new old stock from ebay.
https://www.ebay.com/itm/1992-2002-S...-/312636312925
Old 05-27-2020, 10:19 PM   #4
billr
That broken stud should be easy to fix, I sure wouldn't spend $50 for a new bracket (or make a JY visit).
Old 05-27-2020, 10:48 PM   #5
onefellswoop
thanks everyone for your replies
how would you go about fixing it? I don't own a torch/grinder/welding machine
Old 05-27-2020, 10:59 PM   #6
Zeebins
Zeebins's Avatar
If the stud can be threaded out like the 3 on the timing cover, they yes it would be an easy fix. I'm pretty sure that the studs are part of the bracket though and can't be removed separately. I may be wrong on that though as I have never had to replace one. Looking at the part diagram I just assumed they couldn't be
Old 05-27-2020, 11:32 PM   #7
Waiex191
Waiex191's Avatar
I haven't looked closely at that part in a while but I think the stud is welded on. You may be able to drill it out and use a bolt & nut, but I bet that would be a pain. A junkyard is a good option.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Old 05-28-2020, 12:20 AM   #8
billr
Yeah, I think they are welded; would need to be drilled out. I also think a screw and nut could work, but agree it would not be as easy to change that mount. How many times is it done, though? I have only changed one in the entire time I have had my SL2s (about 500K miles combined).
If the OP can drill it out, then taking it by a muffler shop to have a screw welded in as new stud would be mychoice. Easier, and probably cheaper in the long-run, than a JY. Of course, if the OP does not have good drilling capability, then this is all moot.
OP, where are you located? Maybe some kind soul is nearby with the tools to help you do this.
Old 05-28-2020, 06:45 AM   #9
onlinebiker
Remove bracket from body.
Drill out the bolt - to size.
Put in a bolt - and tack weld a corner or two of the bolt to the bracket.
Easy peasy.
93 SC2
96 SC2
97 SL2
99 SC2
01 SC2 x 2 yellow
02 SC2
02 SL2
parts
2 94 SC2 parted out
2 96 SC2
Old 05-28-2020, 09:48 AM   #10
onefellswoop
thanks again everyone, going to try a junkyard today as this is my only vehicle.
motor mount bracket broken spellman1989 S-Series Tech 43 04-14-2017 12:02 PM
Motor mount stud size Bamper S-Series Tech 4 02-21-2014 01:48 PM
Top Motor Mount Stud Nuts Stuck Saturn1998SL1 S-Series Tech 4 11-08-2009 10:31 PM
loose tranny mount bracket (frame side) 93SC2'in S-Series Tech 5 08-16-2009 07:40 PM
mount bracket stud puer liber S-Series Tech 4 07-20-2007 06:19 PM
