Old 05-19-2020, 09:06 PM   #1
DJCharlie
DJCharlie is a jewel in the roughDJCharlie is a jewel in the roughDJCharlie is a jewel in the rough
DJCharlie's Avatar
1996 SC2
1996 SC2
Attention HELP finding massive coolant leak
I have a pretty bad coolant leak and I cant tell where its coming from or how to fix it. Low Coolant light is on after 2 minutes and almost all of it is gone in an hour. I will attach pictures so hopefully someone can point me to what to replace to get it fixed. Pic #1 showed my water pump was leaking so i replaced that hoping the leak would go away but i guess i have multiple leaks.
I have a strong feeling its coming from pic #2. Should I replace my radiator or is it something else?
Pic#1
Pic #2
Pic #3
DJCharlie is offline   Reply With Quote
Old 05-19-2020, 09:11 PM   #2
DJCharlie
DJCharlie's Avatar
1996 SC2
1996 SC2
Default Re: HELP finding massive coolant leak
Also its a 96 SC2 and It seems like the driver side is more wet than the passenger side and that the leak is from a high point in the front of the car and leaking out of the plastic bumper splash panel.
Old 05-19-2020, 10:10 PM   #3
billr
The common place for a radiator failure is near where the upper line from the trans is connected. Look for a crack in that area of the plastic radiator end-tank.
Old 05-20-2020, 12:05 PM   #4
marmitage
marmitage is just really nicemarmitage is just really nicemarmitage is just really nicemarmitage is just really nice
marmitage's Avatar
2003 VUE 3.0L
Have to agree with Billr, Just had to replace my radiator cracked drivers side couple inches down from the top in the area of coolant lines. Sucks but easier to replace than repair.
marmitage
03 Vue Silver, Daughters
97 SL2 Back from the grave
99 Sw2 Daily driver
marmitage is offline   Reply With Quote
Old 05-20-2020, 02:59 PM   #5
DJCharlie
DJCharlie's Avatar
1996 SC2
1996 SC2
Just ordered a new radiator because it does look like its coming from the black plastic part of the radiator. I hope this finally fixes my leak
Old 05-20-2020, 04:48 PM   #6
onlinebiker
In my experience - the radiator is usually the issue.
Only once has it been a radiator hose - and once the return from the intake manifold.
I think I have done at least 6 radiators.
If it's an automatic I would order the tranny cooler lines. I have not had the best luck with those. On two cars the previous "meckanick" had rounded off the fittings for me...
93 SC2
96 SC2
97 SL2
99 SC2
01 SC2 x 2 yellow
02 SC2
02 SL2
parts
2 94 SC2 parted out
2 96 SC2
Old 05-20-2020, 07:34 PM   #7
In snapshot #2, the bulging hose around the clamp indicates its old and should be replaced.
Old 05-20-2020, 08:39 PM   #8
DJCharlie
DJCharlie's Avatar
1996 SC2
1996 SC2
good eye thanks
Old 05-20-2020, 09:26 PM   #9
454cid
I've done 3 between my truck and my Buick.... I don't remember why I needed one for my Buick. It's copper/brass. My truck has broken the tank on the driver's side, twice. I finally decided that it must be the hose bouncing too much and weakening the tank enough to crack it. I had the tank replaced on the original radiator, but eventually the oil cooler inside the tank started leaking oil into the coolant. I seem to get about 8-10 years out of them. The Saturn is something else..... when I saw the upper hose I was a little concerned about it moving around and cracking the tank. the radiator looks to be original. When I did my oil cooler lines I found an age appropriate date code on the radiator for it to be original, so it's 20 years old like the rest of the car.
And get the AC Delco lines, not the Sunsongs on Rockauto. I bought the Sunsong lines and they would not fit into the quick connects. They were just slightly too big.
Rockauto is the best place for the Quick connects.... you'll get two for the price everyone else is asking for one.
May as well do a filter and fluid change for the transmission, and upper/lower radiator hoses, coolant and possibly the thermostat.
1999 Chevy K3500
Old 05-21-2020, 01:39 PM   #10
DJCharlie
DJCharlie's Avatar
1996 SC2
1996 SC2
Thumbs Up Re: HELP finding massive coolant leak
Just ordered the radiator hoses from Amazon (I get an employee discount) and good suggestions but i've already done the transmission and thermostat.
Old 05-21-2020, 04:50 PM   #11
454cid
Good enough then..... I was just thinking of everything connected may as well be done too. I too would skip the thermostat since I recently installed one. I would probably do the transmission filter and fluid again since mine was incredibly old and a lot of ATF stays in torque convertor when the drain plug is pulled.
1999 Chevy K3500
Old 05-22-2020, 12:14 PM   #12
RobertGary1
1996 SC2
BTW: Large leaks are usually pretty self-evident. However small leaks can be almost impossible to find, usually the occasional drop doesn't happen when the car is stopped. In that case a coolant pressure tester is a great tool. I use mine and have found leaks as little as a cup of coolant every 5,000 miles. That turned into a solid drip under pressure. You can borrow such a tool from Autozone or the Harbor Freight one for $100 is pretty good. We don't know what pressure the coolant system normally runs at (the manufacture doesn't tell us), however I usually pressurize to about 10-12psi which seems to generate leaks more than normal driving. You don't want to exceed 15 psi since that is when the cap would normally blow off and therefor beyond what the system is designed for.
-Robert
Old 05-23-2020, 03:53 PM   #13
amgarb
amgarb is on a distinguished road
I was able to use the Sunsongs but I had to file on them for a while to make them fit. No leaks but it was a pain.
amgarb is offline   Reply With Quote
Old 05-23-2020, 04:04 PM   #14
454cid
I considered doing that but figured my filing would not be uniform and it would likely prevent me from getting a refund on them. Rockauto gave me a refund without returning them, so then I ordered the AC Delco..... which reminds me, I might still have some credit.
1999 Chevy K3500
08 Vue 3.6L massive oil leak NACMaverick 2008 Vue 3 01-18-2020 08:02 AM
2000 Saturn L300 massive coolant leak chad h L-Series Tech 15 03-29-2014 09:19 PM
massive oil leak jstephens L-Series Tech 33 11-02-2012 12:15 AM
Proper procedure for finding coolant "leak"? flyhop S-Series Tech 2 04-07-2012 01:03 PM
Massive oil leak mechanic380 L-Series Tech 3 02-29-2012 08:44 PM
