Old 04-25-2020, 05:12 PM   #6521
Default Re: What did you do to your S-Series today...
JoAnn fabrics finally opened for curbside pickup. I bought a couple yards of headliner fabric, plus a couple yards of felt as an underneath layer as my headboard is in poor shape. Got an email that part of my order was cancelled. Called the store and they would not investigate. So I found they sold me the 2 yards of felt, and one yard of headliner, which is useless. Grrrr. So much for supporting local stores. Off to Amazon. I'll return the 1 yard after I calm down.
Old 04-25-2020, 09:20 PM   #6522
Goggles Pisano
Goggles Pisano is on a distinguished road
Goggles Pisano's Avatar
1999 SL1
On Thursday, I got a set of General Evertrek 195/60R15 all-seasons mounted on the rims I got last summer from a former Saturnfans poster who is now into Hondas and Mercury Marauders. Why have fifteen inch wheels on an SL1?
Lowers the revolutions per mile which improves mileage slightly and markedly decreases engine wear. Allows operating in the 1500-2500 RPM range instead of the 2200-3200 RPM range. As long as you are not trying to be a winner at every stop light grand prix it is not an issue.
Goggles Pisano is offline   Reply With Quote
Old 04-25-2020, 10:27 PM   #6523
Zeebins
Zeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to behold
Zeebins's Avatar
Got the sound deadening down on the floor and doors today. Next weekend I'll tackle the trunk. It was supposed to all go back together today too but after fighting with a door handle for a good 30 minutes, I decided to call it quits for the night.
97 SL2, auto, 119K miles
Old 04-26-2020, 09:22 AM   #6524
bumpdraft
bumpdraft's Avatar
1998 SW2
Looks good.
If you wrap the console ductwork with reflective foil, the car will theoretically warm-up inside quicker in the coldest part of winter. Use silicone tape to seal the joints in the ductwork to prevent un-filtered gritty road air from grinding in the center console shift mechanism.
I use long thin pliers, from an electronics store, to hold the lock mechanism linkage for the purpose of reinstalling the plastic clips.
Old 04-26-2020, 04:55 PM   #6525
Oil change.
It's a bit early but staying at home means the car is just sitting. Last change at about 152k miles using the inexpensive (after rebate) Rotella gas truck synthetic oil, currently at about 154k miles.
Started a couple of days ago, warmed up engine, let it cool about 10 minutes, pulled plugs. Poured in 3 oz of MMO in each cylinder, rotated by hand, covered holes and let sit overnight. All cylinders drained in morning except #2 which was down to about 1/4" of MMO.
Added 3 oz again to all cylinders but just 2 oz to #2, rotated cylinders by hand, let sit overnight. All cylinders looked dry in the morning, pulled PCM-B fuse and cranked, nothing came out. Replaced PCM-B, reinstalled plugs, fired it up and backed it out of the garage, let it idle in the driveway until the smoke stopped.
Pulled back in, let the engine cool a bit, pulled the oil drain plug and cracked the oil filter a bit and let drain overnight. Installed M1-209 filter and Mobil 1 Extended 5w30 oil. Both say they are good for 15k miles so I don't plan on changing oil until next year. I figure I will have about 10k~12k miles on it by this time next year.
Old 04-26-2020, 11:20 PM   #6526
Zeebins
Zeebins's Avatar
Originally Posted by bumpdraft View Post
Looks good.
Those clips actually weren't what was giving me trouble, I've gotten pretty good at getting those on. For some reason on the front passenger door I couldn't get it to slide into place enough to be able to screw it in. As far as I could tell, there wasn't anything in the way that would be causing it to not fit, it just didn't want to go it. I haven't had a chance to look at it today since I'm an "essential" worker, but tomorrow I'll see if the swapping it with the rear door handle will work.
Old 05-03-2020, 01:39 PM   #6527
jpags729
jpags729 is on a distinguished road
jpags729's Avatar
Went for a 30 mile ride yesterday and gave her a wash. Also spray painted the rusty wiper arms so now they look nicer. Hope everyone is staying safe!
Current:
1999 Saturn SL2 1.9 "Sophia Loren 2"
2008 Honda Accord EX-L 2.4
1993 Chevy Camaro Z28 5.7
Previous:
2007 Chevy Malibu LS 2.2
2003 Nissan Altima SE 3.5
jpags729 is offline   Reply With Quote
Old 05-03-2020, 05:04 PM   #6528
dummo
dummo is a name known to alldummo is a name known to alldummo is a name known to alldummo is a name known to alldummo is a name known to alldummo is a name known to all
dummo's Avatar
Went for a drive to pick up a Mother’s day gift for the wife. A local winery that is doing curbside service put a case of my wife’s favorite wine in the hatch. You have to think outside the box these days to come up with a decent gift since running to the mall Saturday night is probably going to be out of the question.
I know I should’ve gotten a case of the real good stuff (Charmin Extra Soft).
• 1997 SW2 used 12/29/2011 with 124,200 -27 mpg
• 2004 Ion3 new 11/2003 (totaled) 11/2011 -23 mpg
• 1994 SL1 new traded
• 1992 SL2 new traded for above
Old 05-04-2020, 06:09 PM   #6529
Zeebins
Zeebins's Avatar
Had time to put down the sound deadening in the trunk today. Between the floor, doors, trunk and trunk lid, I used about 70 sq/ft of sound deadening. Probably added a good 25-30 pounds to the car too. Was definitely worth it though. It's so much nicer on the highway than it was before. There's more tire noise than anything now. (and even that isn't very bad, lol)
Old 05-09-2020, 01:39 PM   #6530
Zeebins
Zeebins's Avatar
I noticed a few weeks ago that the drivers side door grab was starting to crack. I looked online to see if anyone had NOS, but I couldn't find anything. I figured I would just grab one next time I went to the junkyard. I knew there was a SL2 with a black interior there, so I had the idea to just switch all the door grabs to black. Saturn already liked to mismatch their black and tan trim pieces, so I didn't think it would look that out of place.
They where all pretty dirty, but they cleaned up well. Magic eraser works great for getting out the finer scratches that have developed over the years.
Both front door grabs had broken where it gets screwed down. The drivers side also had a big crack down the middle of it. When I was looking for a NOS door grab, the only one I could find for any door was the front drivers side in black. That's exactly what I need here, so I'll be using that instead of trying to repair it.
As for the passenger side, I super glued the screw post to hold it in place. Once dry, JB weld was added around it for strength. It worked great given how little I had to work with. I unfortunately glued it in the completely wrong spot. One new hole in the door card later and that problem was taken care of.
I can't really say for sure weather I like that black more than the tan, but it's defiantly unique to any other S-Series now
That concludes this months mostly pointless but still fun to do project, lol
Old 05-09-2020, 11:11 PM   #6531
Hiisi
Hiisi is on a distinguished road
Hiisi's Avatar
I'm rebuilding the suspension. Front and rear. Have finished the front today and the car is finally on the wheels again! Also, I have changed the oil.
File Type: jpg IMG_20200509_193331117_BURST000_COVER_TOP.jpg (210.6 KB, 12 views)
Hiisi is offline   Reply With Quote
Old 05-10-2020, 10:04 PM   #6532
NWSaturn247
NWSaturn247 will become famous soon enoughNWSaturn247 will become famous soon enough
NWSaturn247's Avatar
Checked oil. 480 miles since oil change. Early, but looking good! My supplies for this short OCI is 4 quarts Delvac Super 15w-40, 1 quart Rislone Engine Treatment and one ~10 ounce can Liquimoly mos2. FL-400S. I have remaining for top-off about 1.125 quarts.
I am hoping for 2000 miles per quart!
1999 SL2 A4 -89k miles
Currently sipping Mobil Delvac 1300, Rislone & LiquiMoly mos2
TCW3 dosed fuel
https://www.ls1.com/forums/f48/been-testing-oil-91206/
1993 SL2 SOLD @189k
NWSaturn247 is offline   Reply With Quote
Old 05-11-2020, 11:40 AM   #6533
bumpdraft
bumpdraft's Avatar
1998 SW2
Today, I took it on a non-essential drive as a non-essential worker. I noticed there were a-holes pushing 15 mph over the posted limit. Things are getting back to normal. Let’s hope for the best
Old 05-12-2020, 04:41 PM   #6534
dummo
dummo's Avatar
That’s a very nicely composed photo! I kid you not. Was that taken with an iphone? That belongs in a Saturn Car Club of North America calendar.
Private Message me with name and address to get your 4” round weatherproof SCCNA sticker which you just WON in my ‘Photograph Your Dipstick’ photo contest.
Old 05-12-2020, 04:48 PM   #6535
NWSaturn247
Thanks! I used my Samsung Galaxy S7. Just set the focus on the dipstick.
Looks like all my chemical efforts are showing results now. I purchased this car @77k miles. Probably did not get great care as it had original thermostat AND!!! original ECTS running 1200 rpm warm idle.
PS I loved those episodes you costarred with Jon Cryer on 2 and a Half Men
TCW3 dosed fuel
1993 SL2 SOLD @189k
Old 05-13-2020, 10:43 AM   #6536
Nekomimi
Nekomimi is on a distinguished road
Nekomimi's Avatar
1996 SL1
I Just about finished up the cabin floor, the MLV layer for the back well's came out fantastic. Still fighting the carpet, it's fairly acceptable, but there's still strong discoloration.
'96 SL1 Originally the family car, passed on to me as my first. "Hellcat" 240,000+ miles and purring smooth.
My Mug is filled with the lost souls of imports.
Nekomimi is offline   Reply With Quote
Old 05-14-2020, 11:23 PM   #6537
Hiisi
Hiisi's Avatar
I have finished the rear suspension today.
Old 05-15-2020, 07:50 PM   #6538
I drove it to LKQ. Felt good to drive. Didn't realize the center brake light or the inside mirror cover was different on the coupe so I struck out there. Does anybody else feel bad leaving a car like this?
I've already converted my '98 but Gen 1 cars seem to be getting rare.
Also I found a tire gauge in that car and took a picture of this alternative door lock.
Old 05-15-2020, 08:02 PM   #6539
Zeebins
Zeebins's Avatar
I just threw a trash bag over the head when I grabbed mine. 1st gens don't usually last very long at this junkyard anyway though so It's not like it really mattered...That car is long gone now.
That lock also doesn't seem very effective, unless the key is a 7mm socket. Then I suppose it's working as designed
Old 05-15-2020, 08:22 PM   #6540
MetallicWheat
MetallicWheat is on a distinguished road
MetallicWheat's Avatar
1995 SW2
It's extremely sad to think that there is probably an equal amount of 1st Gen's in junkyards as on the road. At least where I live.
MetallicWheat is offline   Reply With Quote
Anyone see the "Judge Judy" episode with the 96 S series today? dave.sl S-Series General 23 02-20-2014 04:56 AM
The S Series would be a great car for the lineup today VTHokie00SL2 S-Series General 46 10-01-2012 08:26 AM
Got the L series recall letter today for rear lights Garciavision L-Series General 27 12-22-2005 02:29 PM
REDLINE Series Announced Today D C Vue Red Line 6 04-10-2003 08:14 PM
Saw the L series DVD system today Jeff P L-Series General 1 11-09-2001 09:03 PM
