Old 04-09-2020, 07:01 PM   #1
ddemier7
ddemier7 will become famous soon enoughddemier7 will become famous soon enough
ddemier7's Avatar
2004 ION-1 Sedan
Sad Help! Passanger front power window not rolling up?????
2007 Ion 2 sedan: front passanger window rolls down but not up. All other windows work fine.
I swapped front passanger regulator for a good used one and same thing.
I swapped front passanger switch with rear window switch and same thing. (Switches are the same)
I even swapped front passanger door wire harness with a good used harness and same thing.
I jumped power from spare battery at front passanger window switch terminal to roll window up. It rolled up.
Whats going on here? Any ideas
ddemier7 is offline   Reply With Quote
Old 04-09-2020, 09:22 PM   #2
ddemier7
ddemier7's Avatar
2004 ION-1 Sedan
Dizzy Re: Help! Passanger front power window not rolling up?????
You think it could be a broken wire in the drivers door where the rubber boot is by the hinges? Passanger window switches run oof from the master switch on the drivers side door. ? Just a thought.
Old 04-09-2020, 10:31 PM   #3
ruley73
ruley73's Avatar
2007 ION-2 Quad Coupe
Default Re: Help! Passanger front power window not rolling up?????
Yes, you could have a broken wire in either of the front two door jambs.
Here's a link to a wiring diagram for the power windows.
2007 Chevy Equinox LT 195K miles
2018 Chrysler Pacifica Touring L 50K miles
Old 04-10-2020, 04:30 AM   #4
ddemier7
ddemier7's Avatar
2004 ION-1 Sedan
I did notice drivers master switch does not roll passanger side window down. Could the master switch be causing the passanger side window switch to working erratic?
Old 04-10-2020, 09:54 AM   #5
ruley73
ruley73's Avatar
It's possible, but it's more likely to be broken wires going to/from the switches. If you look at the wiring diagram, the power wires go to the master switch before they go to the passenger's side switch.
You'll need to check both door jambs though because a broken wire in either side will have the same effect with both switches.
Old 04-10-2020, 10:56 AM   #6
ddemier7
ddemier7's Avatar
2004 ION-1 Sedan
Is there an easy way to check the OHM resistance in the master switch?
Old 04-11-2020, 12:55 PM   #7
ddemier7
ddemier7's Avatar
2004 ION-1 Sedan
Drivers side door flex boot is my problem. Broken wires see picture.
Grrrrrr
File Type: jpg Screenshot_20200411-115712_Gallery.jpg (133.3 KB, 7 views)
Old 04-26-2020, 06:36 PM   #8
VentureForth
VentureForth has a spectacular aura aboutVentureForth has a spectacular aura aboutVentureForth has a spectacular aura about
VentureForth's Avatar
2006 ION-3 Sedan
OK... Update. I grabbed a junk harness from a cash and carry. It worked for about 24 hours and then went right back to the same error.
I'll check driver side next.
Infuriating.
VentureForth is offline   Reply With Quote
Old 04-26-2020, 09:59 PM   #9
ddemier7
ddemier7's Avatar
2004 ION-1 Sedan
Thumbs Up Re: Help! Passanger front power window not rolling up?????
Keep me posted
car rolling after being put in park puglover Aura General 5 05-01-2012 02:35 AM
window getting stuck while rolling down whosyadadie01 S-Series General 0 05-16-2010 11:39 PM
Manually Rolling up a power window REEFAR S-Series General 1 05-21-2006 05:28 PM
Loud Creaking Noise When Rolling Up Window Red_Forman Ion General 11 06-13-2005 03:02 PM
Power window going "clunk", not rolling up all the way CPL0341 S-Series Tech 3 05-05-2005 11:35 PM
