Old 10-22-2019, 11:31 PM   #21
Haybale
Haybale is a jewel in the roughHaybale is a jewel in the roughHaybale is a jewel in the rough
Haybale's Avatar
2000 SW2
Default Re: Oil drain plug gasket
Originally Posted by 454cid View Post
Interesting idea. I may look into that.
Have you tried it yet?
Ryan
97 SL2 Mack Charcoal 5 speed, 238k miles, bought 11/18/15
98 SL2 Pearl White auto, 190k miles, 11/7/15 RIP
S-series Shop Manual: http://www.saturnfans.com/forums/showthread.php?t=177672
Haybale is offline   Reply With Quote
Old 10-23-2019, 12:42 AM   #22
NWSaturn247
NWSaturn247 will become famous soon enoughNWSaturn247 will become famous soon enough
NWSaturn247's Avatar
^^^ I am all set when I next change my oil. I am going to use a torque wrench for the first time on an oil change too, why not?
My current oil change consisted of ~2.8 quart Mobil 1 Turbo Diesel Truck 5w-40 + 1 quart Mobil 1 High Mileage 5w-20 + ~7 ounce LiquiMoly mos2 + Wix 51516
Top off for this OCI will be 1 quart 5w-40 TDT then 1 quart Mobil 1 Truck & SUV 5w-30, then 1 quart of Rislone Engine Treatment, then the last .2 quart of TDT I poured into the LiquiMoly can.
So the next oil change will be in 2020.
Stupid Wix filter seems to be leaking but still the burn rate is not bad at what appears to be approximately 1500 miles per quart.
1999 SL2 A4 -89k miles
Currently sipping Mobil Delvac 1300, Rislone & LiquiMoly mos2
TCW3 dosed fuel
https://www.ls1.com/forums/f48/been-testing-oil-91206/
1993 SL2 SOLD @189k
NWSaturn247 is offline   Reply With Quote
Old 10-23-2019, 02:13 PM   #23
454cid
No, I have not.
1999 Chevy K3500
Old 10-23-2019, 02:39 PM   #24
Haybale
Haybale's Avatar
2000 SW2
Originally Posted by NWSaturn247 View Post
Wix 51516
Go to Oreilies, ask for a case of filters, pn# 116MP, they are just plain white label filters labeled ProTec brand, made by WIX, and $32 for a case of 12, if they ask if you are a mechanic/shop they are $22/case.
Ryan
Old 10-23-2019, 07:29 PM   #25
NWSaturn247
^^^Good price there but I am well stocked with clearance filters like the Tough Guard that is rated 99% @ 20 microns.
If those jobber filters are the same as the MicroGard made by Wix, it is 95% @ 29 microns.
TCW3 dosed fuel
1993 SL2 SOLD @189k
Old 10-23-2019, 07:47 PM   #26
slapshot 11
slapshot 11 has a spectacular aura aboutslapshot 11 has a spectacular aura aboutslapshot 11 has a spectacular aura about
1999 SL1
I've used the garden hose gasket and it worked for me...
slapshot 11 is offline   Reply With Quote
Old 10-25-2019, 10:08 PM   #27
MiSaturn
MiSaturn is on a distinguished road
2002 SL
1993 SL2
That's the beauty of installing a Fumoto valve - haven't needed a new drainplug gasket for over 300,000 miles.
MiSaturn is offline   Reply With Quote
Old 10-26-2019, 12:48 PM   #28
Haybale
Haybale's Avatar
2000 SW2
How much is that?
Does it drain the same as stock?
Ryan
Old 10-26-2019, 09:53 PM   #29
MiSaturn
2002 SL
1993 SL2
Fumoto drain valves are around $25, if I remember correctly. They insert like a regular drain plug, but have a spring loaded lever which turns a ball valve. Have installed on multiple vehicles without experiencing any leaks or issues.
Since the threaded portion of valve is similar to the OE drain plug, I'm going to assume it drains as much oil as before. As I change my oil every 2500 or less, not really concerned with a minimal amount of oil that might remain.
Old 10-31-2019, 11:10 PM   #30
TomM96
I've noticed that my leak with the Dorman rubber gasket gradually tapered off.
It may be because I failed to lubricate the new gasket before installation, thus causing it to be pinched/distorted, causing leak. I get to do another oil change soon; i'll try again and monitor.
If it fails a second time... will follow jpags729 suggestion (post #17) for the Cavalier setup {Dorman 097-117 & Dorman 090-091.1; gasket, plug}.
Nylon has been my preference over the years,,,.
Will mull over the garden hose option!
Old 11-06-2019, 03:53 PM   #31
NWSaturn247
Torque wrenches are on special at Harbor Freight Nov 8-11
TCW3 dosed fuel
1993 SL2 SOLD @189k
Old 01-14-2020, 05:18 PM   #32
NWSaturn247
I will probably change the oil in March, using a garden hose gasket. Will be performing another Chemtool flush, then fill with a combo of Delvac Super 1300 and Rislone Engine Treatment part number 100QR with FL400-S
Just a quick OCI until a quart of top off, then a Mobil 1 OCI
TCW3 dosed fuel
1993 SL2 SOLD @189k
Old 01-15-2020, 09:28 AM   #33
mattwithcats
mattwithcats has a spectacular aura aboutmattwithcats has a spectacular aura aboutmattwithcats has a spectacular aura about
Fumoto drain valves have been improved.
F107SX, is shorter, and drain is to the side...
http://www.fumotousa.com/parts.php?partnumber=107
Remember to use a torque wrench, 15 foot pounds...
The elbow adapter is also good to ave...
http://www.fumotousa.com/parts.php?partnumber=102
Gaskets for the original drain plug can be found on RockAuto...
https://www.rockauto.com/en/catalog/...ug+gasket,5428
https://www.rockauto.com/en/tools/en...ug+gasket,5428
Pennzoil Maximum Power 0W-30, Champion COS3600...
NGK BKR6E-11 spark plugs
Old 04-19-2020, 09:06 PM   #34
NWSaturn247
I changed the oil Friday. I used the garden hose washer. It does not fit in the recess of my Dorman magnetic plug, so I got the OEM plug out of storage and the washer worked like a charm. Put over 150 miles since the oil change, no leaks. Will use a fresh garden hose washer with each oil change.
TCW3 dosed fuel
1993 SL2 SOLD @189k
Old 04-20-2020, 06:50 PM   #35
TomM96
Thanks for the links- Mattwithcats,
and discussion, NWSaturn247 !!
Old 05-26-2020, 04:38 PM   #36
NWSaturn247
Yesterday I got on my back to check the drain bolt. It was a bit loose. So, if you use a garden hose washer it would be wise to check the bolt periodically.
Good news is my consumption appears to be north of 2000 miles per quart.
TCW3 dosed fuel
1993 SL2 SOLD @189k
Transmission Drain Plug Gasket Wray Vue General 2 07-11-2014 10:41 PM
Drain Plug Gasket Size MattBarszcz S-Series General 2 10-12-2011 11:30 PM
Oil drain plug gasket bez S-Series Tech 8 03-09-2009 08:18 PM
Oil drain plug gasket 93goldsl2 S-Series Tech 6 07-13-2007 11:24 PM
Need advice on oil drain plug gasket... Tiger S-Series Tech 20 06-17-2005 08:49 PM
