Old 11-22-2019, 10:18 PM   #1
Low Saturn
Low Saturn's Avatar
2007 AURA XR
Default No reverse after valve body replacement.
Just got done doing a valve body replacement on my son's 2001 Limited Edition SC2.
Two weeks ago it started with the reverse slam followed by harsh shifts in forward gears. Within a couple days it almost completely lost reverse. It would struggle in reverse on flat ground and not able to drive in reverse up the driveway or up hill. All signs pointed to a bad valve body.
Ordered the recommended valve body on eBay. Install went smoothly with no issues.
Did some driving around the neighborhood. After a few firms forward shifts accelerating from a stop, everything began to smooth out. Nice, smooth forward shifts that you can barely feel. Stopped on the side of the road to try reverse. Nothing. Won't even engage. Just sits there like it's in neutral. Its actually worse than it was prior to the valve body replacement.
I'm very open to suggestions to what my next step should be. I'm really bummed about this since it's my son's car. His first one. He just got his license and is now able to drive himself the last few months of his senior year. I wouldn't be as upset if it were my car. If I can't fix it, I may put the transmission from my 2000 SC2 in his car and just scrap mine. Luckily for now he can drive my mother's 2002 Tahoe.
Thank you.......
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2001 Chevrolet Suburban
-2007 Saturn Aura XR
Old 11-23-2019, 01:27 AM   #2
Default Re: No reverse after valve body replacement.
Loss of R is often due to a loosened ISN. That is caused by the VB but cannot be fixed by replacing the VB.
Old 11-23-2019, 12:52 PM   #3
edlee
edlee will become famous soon enoughedlee will become famous soon enough
1999 SL1
Bill means that the input shaft nut might be loose. You might need a kit like this:
https://www.ebay.com/itm/Saturn-S-Se...UAAOSw9zxbTMYl
You can search on eBay for, "TAAT kit".
edlee is offline   Reply With Quote
Old 11-23-2019, 04:02 PM   #4
Quit fooling around with eBay unknowns.
Recommended valve body suppliers:
Contact Special Forces by PM here
Ken Partin here: http://www.ebay.com/itm/KEN-PARTIN-C...item2c80fd9280 Call him, don't just order a VB.
Or call these people (Donny IIRC) and mention Saturnfans: http://centralvalvebodies.com/
You have 3 choices and what they supply and what mods are used by each are slightly different as well is your cost. So depending on how long you want the VB to last is a consideration. As an estimate the OEM brand new VB should last 75,000 100,000 miles if the periodic filter and fluid changes are performed.
Central Valve bodies and buy the entire package of mods. These work and last.
Old 11-23-2019, 04:36 PM   #5
Low Saturn
Low Saturn's Avatar
2007 AURA XR
That's the exact one I bought. I believe I followed a link you posted in one of your how tos.
Mike
-1991 Turbo SL2.
Old 11-23-2019, 04:37 PM   #6
Low Saturn
Low Saturn's Avatar
2007 AURA XR
Pulled the end cover to take a look at the nut.
My discovery:
https://youtu.be/y7aISNGpR-Q
Mike
-1991 Turbo SL2.
Old 11-23-2019, 08:26 PM   #7
Mark_b
Mark_b is a jewel in the roughMark_b is a jewel in the roughMark_b is a jewel in the rough
1996 SC2
1999 SC2
That is exactly what you wanted to find. Tighten it up and you'll have reverse again.
Mark_b is offline   Reply With Quote
Old 11-23-2019, 10:01 PM   #8
I only recommend Central Valve Bodies. Others (like Partin or Special Forces) don't do both the main Sonnax upgrades.
Old 11-24-2019, 08:22 PM   #9
Low Saturn
Low Saturn's Avatar
2007 AURA XR
We retorqued the input shaft nut and we have reverse back. There is some harsh shifting between fist and second gear now. But I'm hoping that's because of the new valve body and will start to smooth out. We'll eventually replace the nut if everything seems well over the next few days. The cover will need a new gasket too. I wasn't going to throw any more money at it if retorqing the nut didn't work. Not that it seems to have worked, we'll redo the repair with new parts.
Also worked on my Suburban this weekend. Replaced the oil pick up tube seal. They tend to crack over time, starving the engine of oil. Overall a pretty productive weekend.
Mike
-1991 Turbo SL2.
New valve body now no reverse! Kylerjohnson S-Series General 86 10-13-2017 10:24 PM
New valve body, no 4th or reverse rx79gez8gundam S-Series Tech 6 09-21-2013 11:35 PM
Reverse Slam Valve Body replacement Reverse Fork MichelleG S-Series Tech 16 04-06-2009 06:48 PM
Had Reverse-Slam did Valve Body Replacement lcd60 S-Series Tech 1 12-13-2006 07:59 PM
new valve body-no reverse Nowhere Man S-Series Tech 29 08-02-2006 10:28 PM
