Old 09-10-2014, 01:20 PM   #1
skydiveboy
skydiveboy is on a distinguished road
1999 SL1
Default code P0401 on SL1 99
Hi, I have error code P0401 Exhaust gas circulation and I have to pas the smog test in california, so I changed the EGR valve for a new one and clean the holes the best I could but the code is still there, if I delete the code with the scanner it comes back again and again after some miles, does anyone have any other suggestion ? this model does NOT have inverter valve so I can not change that, besides, does anyboy knows how to open the throttle body to clean the inside throttle body conducts ? I have no idea what else should I do, I already accelerate several times without the EGR valve to try to take out some carbon deposits but it did not make any change
skydiveboy is offline   Reply With Quote
Old 09-10-2014, 01:59 PM   #2
skydiveboy
1999 SL1
Default Re: code P0401 on SL1 99
actually what I was trying to say is how to remove the block that contains the EGR Passageway conducts to try to see if its clogged by carbon deposits, I do not have any idea how to remove to clean that EGR Passageway conducts, the point is to remove the code P0401 and I already changed the EGR valve but I still got the code
Old 09-10-2014, 03:43 PM   #3
"Passageway conducts"? If you mean 'conduit(s)' as in passages, refrain from using "conducts" as its being used incorrectly here. Passages or passageways are better terms.
Your first post is difficult to read and understand so don't expect replies without some effort in proof reading/editing before posting anything.
If you left the egr valve off the engine and started the engine, the engine should have revved immediately to programmed rev limits, 4k-4500 rpm. If this did not occur, the intake passage port is blocked and most likely clogged with exhaust deposits. Try searching richpin videos for egr valve cleaning and troubleshooting for blocked/clogged egr valve ports.
Old 09-11-2014, 12:29 AM   #4
skydiveboy
1999 SL1
Thanks fdryer, yes I meant conduits or ducts or EGR Passageway conduits or EGR passages, sorry for my spelling and terms, I am learning
and sorry again but I did not understand what do you mean by " the engine should have "revved" immediately to programmed rev limits, 4k-4500 rpm. If this did not occur......"
what does it mean ? and do you think that the opening of the EGR Passageway block is difficult for a beginner like me ? because I could not find any info or video about that, this is a saturn SL1 99, thank you all
Old 09-11-2014, 02:53 AM   #5
When an egr valve is removed, two ports are exposed - one is the intake side to the intake manifold, the other is the exhaust side that goes to the exhaust manifold. The egr valve controls exhaust gases fed into the vacuum intake port for recycling some of the exhaust gases for emissions control. Leaving the egr valve off the engine with the exhaust and intake ports open allows the engine to suck in more air into the open intake port - this causes a runaway engine to rev up to programmed limits otherwise the engine would rev all the way above redline and if allowed, instant engine damage. The engine computer limits revving to 4k or 4,500 rpm. By seeing/hearing the engine rev automatically, the intake port is unblocked (as it should be). Not seeing the engine rev high means the intake port/passageway is clogged. Search for richpin youtube videos.
Old 09-12-2014, 02:53 PM   #6
skydiveboy
1999 SL1
actually the car CAN reach more than 4000 rev when I accelerate, so does it mean that the intake port may NOT be blocked ? and that may not be the reason of the P0401 ?
Old 09-12-2014, 04:07 PM   #7
You are misinterpreting information. Revving while driving is not the same as the engine freely revving while parked with the egr valve removed. Do not use your reasoning for two totally separate topics, driving at speed or having the engine idling, parked and the egr valve removed. Your unfamiliarity with engines and how they operate is confusing you and will not help here.
Old 07-12-2019, 07:18 AM   #8
outlawtorn
outlawtorn is on a distinguished road
Question Re: code P0401 on SL1 99
I also am having problems with p0401 code.
I took the EGR off and ran the car and it only idled at 1,000 rpm. But the intake port under the EGR was sucking air in. Is it possible the intake port is clogged bad enough to make the car idle that low but still pull enough air to suck your finger in? Im going to take the intake off this weekend and clean the port. If that doesn't work what is my next move?
outlawtorn is offline   Reply With Quote
egr, exhaust gas recirculation, p0401, throttle body
98 SL1, P0401 code. kryten S-Series Tech 22 12-24-2013 02:18 PM
A series p0401 code agman477 Canadian Saturn Owners 32 11-08-2013 06:18 AM
P0401 error code hipster35 S-Series Tech 17 06-28-2013 11:25 PM
P0401 code question leicaman S-Series Tech 2 04-25-2010 08:15 PM
Trouble Code P0401 EGR Satman53 S-Series Tech 2 05-21-2008 06:59 AM
