Old 08-20-2018, 04:46 PM   #1
hudypete1
2007 ION-3 Sedan
2008 VUE 2.4L
Default Adding side curtain airbags to 2007 Ion 3
The local u-pull just got a 2004 Ion 3 with side curtain airbags.
I am thinking of pulling them to put in my 2007 Ion 3 which doesn't have them.
Possible?
Anything I need to know?
Where do they pull their power? Sensor?
Peter
Peter
CURRENT:
08 Vue XE Black 2.4L
07 Ion 3 Savannah Green Metallic 2.4L
04 Ion 2 Berry Red 2.2
PREVIOUS:
99 SL2 Silver Plum
99 SL2 Dark Blue
95 SL2 Lilac Metallic
94 SW2 White
Old 08-20-2018, 09:22 PM   #2
Default Re: Adding side curtain airbags to 2007 Ion 3
There's a reason why your '07 doesn't have side curtain airbags. I don't know why '03's have them and '07's don't. Unless someone more knowledgeable has info, you're left to guess and research. The '04 Ion Coupe is shown below with sensors and airbag locations. There's quite a bit of sophistication with airbags with many never deploying from drivers going thru life avoiding the once in a lifetime collision where airbags can save a life. Personally, I don't assume adding airbags as plug n' play.
Old 08-22-2018, 02:18 PM   #3
hudypete1
2007 ION-3 Sedan
2008 VUE 2.4L
I have seen 06 Ion 3s with the side curtain bags, but they also had the leather interior and the tweeters on the side mirror covers.
Given that, I was just assuming that the side-curtain airbags were one of luxury Ion 3 options.
About being plug-n-play, I can see that it would NOT be (and I probably shouldn't try to install them, just for safety reasons) because I know the wiring harness from the luxury Ion 3s was different than the standard Ion 3s' since it didn't have the connector for the tweeters. I will look closer this time, I am just excited to have found an Ion 3 with all the leather bells & whistles in my color (beige interior).
Peter
CURRENT:
PREVIOUS:
99 SL2 Silver Plum
99 SL2 Dark Blue
94 SW2 White
Old 08-23-2018, 05:55 PM   #4
onefunkar
onefunkar's Avatar
2008 Outlook XR
2007 AURA XR
Side curtain airbags were an option on all year ions.
Old 08-24-2018, 01:16 PM   #5
satlite440
2001 SL2
you could add it but will need the side impact discrimanatin sensors and make a harness to connect them..and possably a new sdm and connecter..then the issue would be pinning the connecter right for the yr you are going to use..after those hurdles you would need to find someone with access to an mdi&tis2web and attenmpt to program it and sync the sdm/bcm/ecm and set up the primary key..most dealers will be out like a trout due to if they do it and it fails or your in a wreck and they fail to deploy that dealer will be ****ed and probably loose their franchise..you might find someone like me maby..but again I personaly wouldn't want the liability...it can be done.it's a question of time and money...how much do you want to spend..if the answer is up to 2 or 4 k then go for it and evan then it might not work as you are in uncharted territory.. good luck
Old 08-31-2018, 12:23 PM   #6
Citation84
Citation84 has a spectacular aura aboutCitation84 has a spectacular aura about
Citation84's Avatar
2005 ION-1 Sedan
And didn't increase passenger protection very much according to IIHS and NHTSA.
Went form "poor" to marginal", IIRC.
Citation84 is offline   Reply With Quote
Old 09-01-2018, 02:50 PM   #7
onefunkar
onefunkar's Avatar
2008 Outlook XR
2007 AURA XR
Crazy it had optional side curtain head airbags but na was side seat airbags to protect body. Today allvehicle have side body and head protection.
air bags, airbags, safety
Side Curtain Airbags brian74 S-Series General 6 10-31-2014 04:07 PM
Side Curtain Air Bags beaverplt S-Series Tech 2 02-06-2014 06:57 PM
Headliner and Side Curtain Airbags JTav8r L-Series Tech 0 05-25-2007 12:03 PM
Side Curtain Air Bags Kev Vue General 3 11-18-2003 09:58 AM
Head Curtain Airbags - QED Skotter General Saturn Discussion 6 07-27-2000 03:36 PM
