Old 05-25-2018, 12:37 PM   #141
Default Re: loose steering column bolts...again
When you can take both halves of the bracket off of the column take a file and remove a couple strokes of metal of the left hand part, both legs. That will cause the clamp to fit the column tight enough so it will not come loose again.
Old 05-25-2018, 01:58 PM   #142
saturnsctwo
actually I was going to just replace the clamp seeing it is still available, but it never loosened again by the time I traded in the car.
Old 05-25-2018, 02:00 PM   #143
saturnsctwo
Originally Posted by alordofchaos View Post
Just a guess, but I'll bet the techs at the dealership buggered something up during the previous times they "fixed" it.
I'd read the whole thread earlier, and the folks who fixed it themselves before anyone else touched it don't seem to ever had a problem with it loosening up again.
My '98 SL2 never developed this problem. My '02 SC2 had the looseness when I bought the car but only recently developed a hard time with turning the key
I fixed it myself, but couldn't keep it tight in the long haul. I did notice that the clamp bottomed out & I could only get it so tight maybe that was the problem....
Old 05-25-2018, 04:59 PM   #144
Mine is still good.
Old 05-25-2018, 05:35 PM   #145
It is a manufacturing tolerance issue, minimum column diameter and maximum clamp full closed diameter. Probably a small slide rule error.
Old 06-01-2018, 02:37 PM   #146
trottida
trottida's Avatar
This is not new information but for visual reference these are the recommended black oxide bolts with thread locker to switch to - it doesn't necessarily need to be from this manufacturer but spec'd the same. You can use low profile as well but it is not necessary.
2012 Ford Focus SEL HB MT
2011 Suburban LT
Past Saturns
2001 SL1 MT (438,500 km 11y)
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Loose steering column BonziBuddy S-Series General 18 08-29-2016 06:07 PM
loose steering column bolts saturnsctwo S-Series General 37 07-11-2008 12:11 PM
Steering column bolts danfman S-Series Tech 3 01-06-2008 07:57 PM
Loose steering column collar tmaugham S-Series General 5 03-31-2006 05:29 PM
SL steering column cover is loose. MrMarty S-Series General 9 10-31-2005 11:00 PM
