Old 03-23-2018, 10:34 PM   #1
Jonasan308
Jonasan308's Avatar
1999 SC1
Default Removing Top engine mount without jack
If the junkyard doesnt allow jacks on the yard, how can you remove the top engine mount without jacking up the motor by the oil pan?
1999 SL1-129k at purchase(may 2016)-139k when wrecked(September 2016)
1999 SC1-156K at purchase(oct 2016)-215k(Oct 2019)
1996 SL2-116k- (oct 2019)
Old 03-23-2018, 11:46 PM   #2
Default Re: Removing Top engine mount without jack
Shove a 2x4 between the cradle and the engine. 2x4 might be too thick, might need to be a 1x2.
Old 03-24-2018, 12:11 PM   #3
I've never used anything removing the top mount, just loosen the nuts and let the engine drop down the inch or so. Going back, I pull/pry with a big screwdriver through the top lifting tab/eye.
Old 03-25-2018, 01:21 PM   #4
TomM96
I believe a block, dimensions 1" X 1" OR 1-1/4" X 1-1/4" will fit between bottom engine-side dogbone mount and cradle, which will hold UP engine as release nuts securing top mount to the timing cover (or mount to framerail nuts).
Old 03-25-2018, 05:28 PM   #5
Saturn Night
You may want to take a 2nd person, with a prybar(NOT a crowbar).
Have the second person use the prybar, on the lower dogbone, and as you loosen the nuts to the aluminum bracket-to-head area, it will slowly add weight. Since they already have the prybar between the cradle and the lower mount, they merely just need to apply pressure to prevent the engine from moving. The longer the prybar, the better, because less strength is needed the further you move away from the point of contact with the engine mount.
Old 03-25-2018, 09:08 PM   #6
Low Saturn
Low Saturn's Avatar
2007 AURA XR
If I've ever needed a jack while at the junkyard, I'd just check to see if the car I was pulling parts from still had its jack. If not, I'd look in another car.
I miss the good old days when I'd pull a S-Series engine at Pick-N-Pull using nothing but a saw-zall and a few hand tools.
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2001 Chevrolet Suburban
-2007 Saturn Aura XR
Old 03-25-2018, 09:40 PM   #7
Saturn Night
Considering you have to remove the damper pulley and have an automatic transmission to gain the clearance required to pull an engine out the top(manuals can only come out the top while still bolted to the transmission due to the clutch & pressure plate), I would be hard pressed to see anyone pull these engine with less than a cherry picker.
Fully assembled DOHCs weigh around 220lbs. SOHCs aren't much less than that, either.
Old 03-25-2018, 09:55 PM   #8
Low Saturn
Low Saturn's Avatar
2007 AURA XR
The pick-n-pulls here have the cars sitting up on stands. It's pretty easy to drop the engines to the ground while still bolted to the cradle and slide them out from under the car.
At home, I use an engine hoist and load leveler.
Mike
-1991 Turbo SL2.
Old 03-28-2018, 12:07 PM   #9
Jonasan308
Jonasan308's Avatar
1999 SC1
Ive seen your past posts about making things slightly easier. Im assuming its unbolting the mounts and any sensors needed and cutting off the hoses and whatnot?
Also, how do you drop the engine safely?
The junkyards here have the cars sitting on old rims. I suppose you could put some heavy blanket under the engine before dropping it to avoid damage.
I found a 93 sl1 at the yard with a nice looking mount but besides it being older, i also didnt seem to have a 15mm deep well with me.
Old 03-28-2018, 12:11 PM   #10
Jonasan308
Jonasan308's Avatar
1999 SC1
By lifting tab, what do you mean? The black piece of steel on the same side that seems to be used for lifting the engine?
Old 03-28-2018, 05:47 PM   #11
Jonasan308
Jonasan308's Avatar
1999 SC1
I successfully removed the top engine mount out the 1993 SL1 and installed it into my car.
The engine did drop some, i started with the 3 on top first and then took off the 2 others on the bottom. My old mount, i could fit my first knuckle into. With this one, i cant. It seems to have made a difference.
Old 03-28-2018, 05:57 PM   #12
"The black piece of steel on the same side that seems to be used for lifting the engine?"
Yep, it seems like it would be great for lifting the engine, so... that's what I use it for! (And consider it to be a "lifting tab")
Old 03-28-2018, 06:06 PM   #13
Low Saturn
Low Saturn's Avatar
2007 AURA XR
I just let it fall to the ground and drag it out still attached to the cradle. Or what's left of it after cutting it free of the car.
Mike
-1991 Turbo SL2.
how to support engine while removing the upper mount bobbyrae S-Series General 5 08-03-2012 10:39 PM
Can't jack up tranny to replace mount... please help! PlasticCarsRock S-Series Tech 10 08-21-2010 01:13 PM
Changing Motor Mount, Jack Question Kal S-Series Tech 8 07-08-2008 12:24 PM
Where do I put the floor jack when changing a tranny mount? fixit4mywife S-Series Tech 3 06-04-2008 05:53 AM
Removing spare and jack? alkemyst Mods and Performance 6 01-23-2003 08:28 PM
