Old 03-14-2018, 09:50 PM   #1
saturnsctwo
Default oil useage
i noticed my car is starting to use some oil. I go through a half quart per month. I drive about 25-30 miles per day normal. does that seem high for the mileage? I wonder if I can cut it down with that oil soak.... I don't remember having to add that much oil between oil changes. I wonder if the cold weather has something to do with it as I don't remember the usage in hot weather.
if anything I would think it would be just the opposite....
Old 03-14-2018, 10:00 PM   #2
Waiex191
Waiex191's Avatar
Default Re: oil useage
That is 1800 miles per quart. Very good! Before my rebuild my consumption was more than a quart every 1000 miles.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Old 03-14-2018, 10:12 PM   #3
saturnsctwo
ya it's really not much but I hope it doesn't get worse, but it is a Saturn. i changed my gasket around the cam cover & spark plug holes a few years ago & the engine has been bone dry there, but recently this winter I noticed a little dried up oil near the corner of the engine near the upper rad hose. it's hard to tell where's it is coming from. are those cam cover bolts known to loosen over time? I should check it out.....
Old 03-15-2018, 02:32 AM   #4
Saturn Night
Your oil control rings are starting to seize up. The pistons have insufficient flow, for removing the oil, and it cooks into a varnish.
At your consumption rate, try switching to synthetic Mobil-1 5w-30.
You may also try the MMO soak, which the longer you let the pistons soak in that stuff, the better it seems to work.
Here is a YouTube video, that explains the issue and how to permanently correct the problem:
https://m.youtube.com/watch?v=UrnblJ8VZtY
And I just did a teardown/head gasket-top end recondition on a junkyard 1.9L DOHC. These engines are actually VERY EASY to tear apart and put back together.
I will post a link, with my video of the run test on my SC2, as soon as I get it uploaded to my YouTube account.
Old 03-15-2018, 02:36 AM   #5
Saturn Night
The plastic valve covers are prone to warping, a few thousandths of an inch, at the corners.
Torque being applied to the bolts will actually worsen the warpage.
You can try a Fel-Pro PermaDry gasket, but usually once they warp, you have to replace them with a brand new one. Last time I priced one, from a GM dealer, the plastic valve cover was $400+. Aluminum covers are discontinued, and can only be used up to the 1998 model year.
Old 03-15-2018, 10:13 AM   #6
saturnsctwo
I use Valvoline syntech full synthetic & also mobil one too. in the spring/summer I will try the soak I guess I had it coming. my car has low mileage for it's year so I think the engine is still tight. no visible leakage or smoking at all, not even the slightest smoke visible other than cold weather steam when first started.
Old 03-15-2018, 10:15 AM   #7
saturnsctwo
I use Valvoline syntech full synthetic & also mobil one too. I have been using it for the last around 40.000 miles I estimate. in the spring/summer I will try the soak I guess I had it coming. my car has low mileage for it's year so I think the engine is still tight. no visible leakage or smoking at all, not even the slightest smoke visible other than cold weather steam when first started. I replaced the cam cover gasket a few years ago & it's been bone dry around the cover since, but recently this winter I seen some dry oil debris in the corner of the engine near the upper rad hose. it almost doesn't look like it's coming from the gasket, but I wonder if that cover bolt come loose in that area, will check it out when I get the car back from the shop....
Old 03-15-2018, 10:20 AM   #8
saturnsctwo
the cover my year are less prone to warp I understand. the oil leakage three is very slight only a little dirty debris from time to time nothing to be concerned about. maybe the cover bolt got loose in that corner. I used that fel pro gasket. if my cover is warping I will replace it. are these available new still? I checked my cover for straightness when the gasket was replaced. if it's warped I couldn't see it....
there's really no leakage as far as oil running down, just some dirty debris probably from less than a drop. i'll keep an eye on this to see if it gets worse. cover is clean around the rest of it though...
Old 03-15-2018, 11:06 AM   #9
RobertGary1
1996 SC2
I didnít Think anyone still recommended the mmo soak. I donít think anyone has reported decreased oil consumption after trying it. Most of us found it did nothing. The b-12 soak seems to be working for people though.
-Robert
Old 03-15-2018, 11:33 AM   #10
Saturn Night
They won't start smoking, until you get down to about 1qt/500mi or less. Just keep an eye on your oil level and don't run it more than 2-3 diamonds below the FULL line. It isn't your fault. It if a flawed piston design.
Old 03-15-2018, 12:33 PM   #11
saturnsctwo
-Robert
i read a lot of people with mixed results doing the mmo soak. what's a b-12 soak? is it something else you pour in the cylinders?
Old 03-15-2018, 12:34 PM   #12
saturnsctwo
I've been checking it once a month, more if it shows an increase in consumption. my car is in excellent condition & I would consider a change to drilled pistons if it comes to that. the car's worth it.
Old 03-15-2018, 12:37 PM   #13
saturnsctwo
these soaks do you just pour in the recommended solvents let it soak for about 24 hours & then just re-install the plugs & start the car? does this foul the plugs? my plugs are pretty new as the wires. I assume the solvent works it's way past the piston rings after a while?
Old 03-15-2018, 12:40 PM   #14
saturnsctwo
does extreme cold or heat effect oil usage? there's questions all over the net regarding this. no really concrete answers....
Old 03-15-2018, 12:42 PM   #15
saturnsctwo
do people who had their pistons drilled did that make a difference with oil usage? complete stop it for good? I wonder what the cost would be having this done...
Old 03-15-2018, 12:57 PM   #16
saturnsctwo
just was on the net and there's many web pages regarding cold weather oil usage. I wonder if there's truth to this as I don't remember the last time it was warm my engine using any oil. time will tell when it does get warmer here if it ever does. we'll see.... I don't understand the connection between cold weather & oil usage myself....
Old 03-15-2018, 01:05 PM   #17
Saturn Night
Advance Auto Parts can get the drilled pistons, from Sealed Power, for $33.99/piston. As long as they aren't oversized, it is not a "Special Order", so you don't get charged shipping.
Fortunately, the excessive oil consumption tends to save the wear on the cylinder sleeves, which means you can get away with a re-ring/ball honing job amd not have to over bore the cylinder by .030"
Old 03-15-2018, 01:08 PM   #18
Saturn Night
Talk to Highmile. He rebuilt his SL1 engine, at like 450,000 miles, and used drilled pistons. He is currently at 650,000+ miles on his SL1. He can tell you mpre about the results of oil consumption and drilled pistons.
Old 03-15-2018, 01:13 PM   #19
Saturn Night
I have owned almost 20 different models, of automobiles, in my 20 years of driving. I have never seen hot/cold weather male a noticeable difference, really.
Depending on WHAT is causing oil consumption, would determine how weather could affect consumption.
Bad Rings or Bad Valve Seals = Additional Oil consumption in cold weather, because the engine idles longer to warm up. The consumption is not so much the weather, but because the engine is running for a longer period of time.
Gasket Leaks = Possibly affected by the weather. Only gaskets, that are sealing oil when the engine is OFF(such as the drain bolt or pan gasket) would be affected. In THIS case, the consumption would be LESS, because the oil is thicker due to colder temperatures making it more dense.
Now, gaskets that are under pressure will be the OPPOSITE, as pressure will be HIGHER with colder oil.
In any case, the more a damaged engine runs with oil consumption will always have a more noticeable effect on oil consumption, than the weather will ever truly cause by itself.
Old 03-15-2018, 01:42 PM   #20
Waiex191
Waiex191's Avatar
I spent about $1400 at the machine shop for oversize pistons and machining. No more oil consumption!
Bryan Cotton
Oil useage yahoo General Saturn Discussion 1 11-05-2000 10:50 PM
Oil useage yahoo General Saturn Discussion 3 11-05-2000 10:40 PM
