Old 07-28-2016, 02:42 AM   #1
ddemier7
ddemier7 will become famous soon enoughddemier7 will become famous soon enough
ddemier7's Avatar
2004 ION-1 Sedan
Question Drivers side rear door actuator not working......2nd time. ??????
Ok guys I have a 2004 Saturn Ion level 1 and my drivers side rear passenger door will not auto lock or auto un lock . I have to manually lock/unlock it. I purchased a used door lock actuator off Ebay $30.00 and I installed it myself double checking the installation and making sure the connecter was on nice and tight. After I installed it the new/used actuator is not working so im curious if that actuator is faulty or if im not getting power to the rear door? How would I test this out and what wires would I test or which connecter would I send power to test that door actuator? Any ideas or anything im over looking??
ddemier7 is offline   Reply With Quote
Old 08-06-2016, 03:09 AM   #2
ddemier7
ddemier7's Avatar
2004 ION-1 Sedan
Default Re: Drivers side rear door actuator not working......2nd time. ??????
Any ideas?
Old 08-06-2016, 05:43 PM   #3
2006 ion2
2007 ION-2 Sedan
Test for power at the door with a multimeter.
2007 Saturn Ion 2
2003 Chevrolet venture lt
Old 08-06-2016, 09:40 PM   #4
ssicarman
ssicarman's Avatar
Check the wiring harness from the body to the door for broken wires.
Old 08-07-2016, 02:47 AM   #5
FWIW, the same thing happened at my left rear door several years ago. Believing that the actuator had failed, I purchased a new one and following its installation discovered that the door lock still did not work. There was a break in a pair of wires within the wiring harness between the center pillar and the door. Of course, this is where all of the flexing of wires occurs within that harness. Some years later my speakers in that same door lost power for the same reason. The wiring was repaired and worked satisfactorily for some years afterwards. Eventually, however, the repaired segments broke again. Long story short......I went to a wrecking yard and pulled a harness from a donor car and installed it and all is working normally.
334,000 miles - Holy canolli!
A leftist, deep-stater will get the nomination for POTUS. What follows if he gets his way? A bad economy, weak military, increased terrorism and a greater RED CHINA.
Old 08-17-2016, 04:06 AM   #6
ddemier7
ddemier7's Avatar
2004 ION-1 Sedan
Thumbs Up Re: Drivers side rear door actuator not working......2nd time. ??????
I will get a tester and test the wire harness to see if power is makig its way to the acuator. If not then I will inspect that wire harness between the door and pillar. Sounds like a plan.
2006 Vue rear door drivers side passenger door won't open. khelton79 Vue Tech 1 11-03-2014 03:48 PM
What could be wrong with my drivers side rear automatic door lock? 2002SaturnMan S-Series Tech 7 09-01-2013 02:23 PM
Drivers side rear door won't open chevy57 S-Series General 3 10-23-2008 12:12 PM
Drivers door lock actuator + relay clicking kevo420 Vue Tech 3 07-28-2008 05:02 AM
2000 LS1 Rear drivers-side door is stuck in the lock position sjoyce54 L-Series Tech 3 01-08-2008 10:58 PM
