Old 03-20-2013, 02:21 PM   #1
eljefino
eljefino will become famous soon enough
eljefino's Avatar
1995 SW1
2000 SL1
Default I put a 94 TBI SOHC head on a 98
It was easy.
Most of these resources involve fitting DOHC heads. Too rich for my blood! I had a spare engine from a car I junked that donated the head. Had been sitting for two years so it was hard to find a car to stick it in. Snagged a 98 SW1 that just passed a state inspection and is otherwise nice... body and interior wise. Anyhow...
What came out:
This was actually after a cascade + fresh water rinse
The virgin 94 head's intake ports, without injector notches/ eyebrows/ whatever you call them
The cracked 98 head's eyebrows for reference
MPFI gasket on new head, not yet molested. (I did use a new felpro intake gasket.)
Starting work. Paper towel stuffed in there to catch shavings
Mid-job. Flash froze the die grinder while it was spinning.
what I wound up with. Note, it's not as huge a cut as the stock 98 but I didn't want to cut into any water jackets or other drama in the head, not that I expected to find any. Similarly I wanted a good intake gasket seal, no vacuum leaks etc.
Other notes: The SOHC EGR valve sits entirely on the intake manifold which of course I switched over. No adapters needed. The injectors sit entirely within the manifold so, plausibly, I could have stuffed it on without grinding. I figure they cut the notches so the fuel stream atomizes into a better pattern over a longer period of time mixing with air, and doesn't splash at a 45 degree angle when it hits the razor edge. Simply roundng and smoothing it probably did all of what I needed it to do.
BTW it runs good, idles smooth, revs freely, though I haven't taken it up the road yet.
eljefino is offline   Reply With Quote
1.9 SOHC Cylinder Head/Head Gasket..... Coolant Leak BRIAN41920 S-Series Tech 12 01-21-2014 03:40 PM
SOHC Alternator bracket oil puddle - head or head gasket? comanche S-Series Tech 10 09-28-2009 05:42 PM
twin-cam head vs. SOHC head Campchair S-Series Tech 10 05-22-2008 08:56 PM
1.9 SOHC Scarred head cam and head.. help? csavard S-Series Tech 8 05-16-2008 06:08 PM
95 s sohc head and head gasket questions bman S-Series Tech 16 01-07-2008 07:52 PM
