Old 09-23-2009, 10:42 AM   #1
DeMAN
DeMAN is on a distinguished road
Default 95 SC2 w/98 DOHC engine with tranny issues
Driving to work yesterday and coolant lights started blinking but soon went away w/o coming on again. On my way home about 3-5 miles into the trip it sounded like I was dragging something. Checked under the car and engine bay. Things looked OK. Drove a little further and same result. The noise presisted off and on on my 45 mile trip and eventually stopped. I went to check the car again after getting home and car would not go in reverse or neutral while idling. I had to cut the car off to roll back out of the driveway. I also tried to throttle up the car under the hood and could not. tried drive up the street and heard a thump and felt like something tried to turn steering to the left. Turn around and came home.
Any clue as to what may have happened and an approx. cost........
On a positive note, I may have messed up the car but it got be home
DeMAN
95 SC2
97 Grand Prix GTP
06 Acura TL
DeMAN is offline   Reply With Quote
Old 09-23-2009, 04:03 PM   #2
DeMAN
Default Re: 95 SC2 w/98 DOHC engine with tranny issues
The tranny is an auto. The tranny fluid was changed about 6 weeks ago by the dealer.
DeMAN
95 SC2
97 Grand Prix GTP
06 Acura TL
Old 09-23-2009, 05:13 PM   #3
wrenchtnr
wrenchtnr is on a distinguished road
1992 SL
Doesn't sound like a known failure.
Jack up the front of the car and spin and shake the wheels. Listen for noise from wheel bearings, CV joint, or a broken axle.
You sure it was coolant light not Battery or brake? Check all fluid levels and serpentine belt tension.
wrenchtnr is offline   Reply With Quote
Old 09-27-2009, 03:34 PM   #4
DeMAN
Brought car to shop. Second and reverse gears are stuck with second winning the fight. (car going forward in all gears)
Looks like I will be going with a used tranny with a years warranty
DeMAN
95 SC2
97 Grand Prix GTP
06 Acura TL
tranny issues- SC2 A-T DOHC swoope S-Series Tech 2 11-15-2009 01:19 PM
95 SC2 w/98 DOHC engine with tranny issues DeMAN S-Series Tech 3 09-27-2009 03:16 PM
Swapped a 2001 SC1 DOHC engine with a 2000 SL2 DOHC now have transmission issues knukklhead S-Series Tech 18 04-13-2009 07:48 PM
Will an 1996 or newer DOhc engine fit in a 95 SC2(dohc)? e dogg S-Series Tech 4 04-05-2008 12:14 AM
93 PCM & Valvebody, 96 tranny DOHC compatability issues tyoungs S-Series Tech 19 11-16-2007 07:44 AM
