Old 09-13-2019, 12:05 PM   #1
Silverblu02SL2
Silverblu02SL2 is a jewel in the roughSilverblu02SL2 is a jewel in the roughSilverblu02SL2 is a jewel in the rough
Default rear creaking noise when braking
While at a stop light, if I let the car roll a foot or 2, then step on the brakes, then let off the brakes, then step on the brakes again at a 1 hertz rate. I hear a pretty loud creaking noise.
The car has only 63k original miles but when I bled the brakes 2 weeks ago, I noticed a lot of rust on the suspension.
I have not crawled under to investigate yet. Any guess as to what is making the noise? Can someone please post a link to the FSM rear suspension diagram?
fdryer?
1/28/2019 2002 SL2 w 62k miles
Add to Silverblu02SL2's Reputation
Rate the quality of this post and help Silverblu02SL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Silverblu02SL2 is offline   Reply With Quote
Old 09-13-2019, 01:17 PM   #2
Default Re: rear creaking noise when braking
I think post 4 has bumpdraft's picture but I cant see it because the site is blocked at work
http://www.saturnfans.com/forums/sho...d.php?t=184941
Should be some pics here (hunt4steve) but again, I cant see them
http://www.saturnfans.com/forums/sho...d.php?t=203651
http://www.wholesalegmpartsonline.co...24ZZ07-001.JPG
Old 09-13-2019, 01:58 PM   #3
It's likely the shoes just need to be lubricated where they slide on the backing plate.
Old 09-14-2019, 10:15 AM   #4
Silverblu02SL2
I'll have to take the drum off to check that out. Do you have the FSM chapter on taking the drum off? I think I have to retract the shoes first by turning a star wheel.
Old 09-14-2019, 10:35 AM   #5
Silverblu02SL2
Thanks! diagram from wholesalegmpartsonline.com is great! I notice many suspension parts are no longer available!
Gotta say Saturn must have used cheap metallurgy in building their cars. The knuckles on my 92 VW Jetta and 83 Mercedes 300 D has a lot less rust than my 02 Saturn SL2!
Old 09-14-2019, 11:39 AM   #6
The FSM literally says release parking brake, remove wheel, then remove drum.
The access hole for the wheel was designed by a dyslexic, it's on the wrong side of the axle center-line on both sides (so the normal tools don't reach it). I don't remember off the top of my head which side spins which way to tighten/loosen the shoes, you may have to experiment with it (spin it a few times, if the wheel doesn't spin that was the wrong direction...when you're done you want it to stop the wheel after 2-3 full turns).
Creaking Noise While Braking sublimefool311 S-Series Tech 9 09-15-2013 12:14 PM
Rear knocking noise when braking tapatia S-Series Tech 10 07-16-2007 11:56 AM
creaking noise in right rear vintagegz Vue General 14 01-04-2007 01:56 PM
Creaking noise from rear wheel well Krusen04 S-Series General 8 04-01-2004 05:36 PM
low brake pedal and noise from right rear upon braking mykidssaturn S-Series Tech 4 10-20-2002 11:22 PM
