Old 04-10-2019, 06:50 AM   #1
Kgarv2
Kgarv2 is on a distinguished road
Default 2007 Saturn Vue Doors will not open
I have a 2007 Saturn Vue that at times the doors will not open I can get them to open after hitting the door lock button or driving it however Iím looking for suggestions on a permanent fix.
Add to Kgarv2's Reputation
Rate the quality of this post and help Kgarv2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Kgarv2 is offline   Reply With Quote
Old 04-10-2019, 10:56 PM   #2
far2grumpy
far2grumpy's Avatar
Default Re: 2007 Saturn Vue Doors will not open
Locks consistently working only with engine running sounds like a power supply problem.
Door lock/unlock actuators can become "lazy" as years pile up.
Internal wiring resistance should not change but small resistance can develop in connections and relays to decrease voltage reaching actuators.
Lack of lubrication and "slop" in parts and pieces moved by door actuators can also sap actuator power.
My first step toward isolating stubborn actuators would be to verify battery power meets spec.
I'd start by using a digital voltmeter to check for 12.6 volts minimum battery voltage with key and all switchable electrical loads off.
A healthy door actuator will consistently activate with 12.6 voltage so if your voltage is low you should work toward fixing.
2007 Saturn Ion driver side door will not open janderson6381 Ion Tech 0 05-12-2018 07:45 PM
SW2: both rear doors getting hard to open toggenburg S-Series General 7 10-25-2013 01:51 PM
doors are difficult to open bellman246 Astra General 3 04-29-2012 12:48 AM
Saturn Open Road Race Results - 2007 lambdapro General Saturn Discussion 0 10-16-2007 09:21 PM
1999 sl2 saturn doors wont open ewalah L-Series General 2 10-24-2006 03:48 PM
