Old 03-30-2019, 04:28 AM   #1
Hicky69
Hicky69 is on a distinguished road
Default 07 vue AWD driver side power door actuator help pleasw
Hello, I have a 2007 AWD VUE I need to replace my drivers side power door lock actuator it is stuck on lock and will not open with the key or any of the power door switches which all work and unlock all doors but drivers. Have been searching for another Actuator yet every link that says they have one dont have one when i click link they either say they dont have one for my year or they show me actuators for others Saturns or every year but mine. Question is is there an actuator from any other year,make or model vehicle that will work in the 2007 AWD Saturn Vue has the cable not a rod that connects to the inside door latch. Trying not to have to go thru a saturn dealership or oem manufacturer seller and having to pay $129 up to $180for one thanks for any help or links
Add to Hicky69's Reputation
Rate the quality of this post and help Hicky69 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Hicky69 is offline   Reply With Quote
Old 03-30-2019, 10:58 AM   #2
far2grumpy
far2grumpy's Avatar
Default Re: 07 vue AWD driver side power door actuator help pleasw
I suspect door parts are common for 2002 - 2007 Vues.
Ebay lists several latch lock - here's listing for one:
https://www.ebay.com/itm/2003-2007-S...frcectupt=true
A common door lock problem is broken wire in harness at the door/body interconnect.
Locate, wiggle and/or squeeze the rubber accordion covering wires to see if door lock responds and if it does you might be able to repair the broken wire and save a few dollars.
PM email address if you need service manual extracts to identify wire colors or to remove door panels to replace lock actuator.
Drivers side rear door actuator not working......2nd time. ?????? ddemier7 Ion Tech 5 08-17-2016 04:06 AM
Hvac door actuator replacement (Flapping noise on passenger side) Mister_Cee S-Series General 3 09-19-2015 02:41 PM
Power door lock problem 2003 L200 driver side pberku L-Series Tech 6 12-15-2014 05:43 PM
Power Door Actuator laklive Aura General 13 04-28-2011 02:28 PM
Driver's door lock actuator/latch CrackerVUE Vue Tech 3 10-22-2009 12:16 AM
