Old 05-11-2007, 11:33 PM   #1
Dro
Dro is on a distinguished road
Default Intakes
Is there any difference between those really cheap intakes on ebay and put a good filter on it from the whole aem intake?
1999 Saturn SL
Young Dro!
Add to Dro's Reputation
Rate the quality of this post and help Dro reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Dro is offline   Reply With Quote
Old 05-11-2007, 11:43 PM   #2
Pythonidae
Pythonidae is on a distinguished road
Pythonidae's Avatar
Default Re: Intakes
AEM ones flow alittle better, but I suggest fabricating your own
Add to Pythonidae's Reputation
Rate the quality of this post and help Pythonidae reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Pythonidae is offline   Reply With Quote
Old 05-11-2007, 11:44 PM   #3
Dro
Default Re: Intakes
whats the difference if its just a pipe???? isn`t the only real difference the filter??
1999 Saturn SL
Young Dro!
Old 05-12-2007, 04:32 PM   #4
wolfman
wolfman's Avatar
Default Re: Intakes
Although those who have purchased aftermarket intakes will insist that their "seat of the pants dyno" indicates otherwise, NO. You can accomplish 90% if not more, of the same effect by simply using a better flowing airfilter and the OEM piping.
Add to wolfman's Reputation
Old 05-12-2007, 10:54 PM   #5
nitsua y zarc
nitsua y zarc is on a distinguished road
nitsua y zarc's Avatar
2001 SC1
Default Re: Intakes
Yeah, but OEM isint SHINEY! But really, I did it for the sound and minimalist gain in performance. Emphases on minimal...
Add to nitsua y zarc's Reputation
Rate the quality of this post and help nitsua y zarc reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
nitsua y zarc is offline   Reply With Quote
Old 05-13-2007, 02:23 AM   #6
quiksc2
quiksc2 has a spectacular aura aboutquiksc2 has a spectacular aura aboutquiksc2 has a spectacular aura about
quiksc2's Avatar
2002 L-Series 3.0L Sedan
Default Re: Intakes
I did it for the few more hp I was told it would provide. Plus it only cost me $20 for everything.
If I wanted ride quality, I would drive a Cadillac. If I wanted to be a sheep, I would drive something that says Vtec on the side of it...
DCS
Add to quiksc2's Reputation
Rate the quality of this post and help quiksc2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
quiksc2 is offline   Reply With Quote
Old 05-13-2007, 06:22 AM   #7
mattbur
mattbur is on a distinguished road
2001 SL
Default Re: Intakes
I went for a cheap one off of ebay. I had to drill the pipe for the sensor, and make a set of mounting brackets that actually worked. Also i used a better filter than the one provided. Other than that, it was a nice addition when it was finally finished.
2001 SL
5 - speed
Add to mattbur's Reputation
Rate the quality of this post and help mattbur reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mattbur is offline   Reply With Quote
Old 05-13-2007, 11:55 AM   #8
Dro
Default Re: Intakes
will a SL2 intake fit a 1999 sl???
http://cgi.ebay.com/ebaymotors/BZ-91...14503612QQrdZ1
1999 Saturn SL
Young Dro!
Old 05-13-2007, 10:02 PM   #9
eRic 02sc2
eRic 02sc2's Avatar
Wrench Re: Intakes
the difference is AEM made sure their product fits on a Saturn and AEM has published dyno results and installation instructions for a Saturn. AEM includes everything you need including a bracket and the hole with a grommet for the air temperature sensor. my AEM SRS installed in about 15-20 minutes or so.
Installation Instructions
http://www.aempower.com/images/products/22631.pdf
Performance Data
http://www.aempower.com/images/products/22631_hp.pdf
http://www.aempower.com/images/products/22631_tq.pdf
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 05-13-2007, 10:47 PM   #10
hit_n_run
hit_n_run is on a distinguished road
Default Re: Intakes
Yes, it will fit. I wondered that same thing. I used to have a 2000 SL1 with that same Ebay intake. Now I have a 99 SL2 and guess what... that SAME intake fits.
Add to hit_n_run's Reputation
Rate the quality of this post and help hit_n_run reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hit_n_run is offline   Reply With Quote
another noob question(difference between pre 95 intakes and post 95 intakes) Sohc_dreamer S-Series Mods 18 10-03-2007 12:01 AM
3.0 intakes Solareklypz Vue Mods 2 07-09-2007 11:13 PM
Intakes HAAS07 S-Series Mods 17 04-18-2007 11:09 AM
intakes quiksc2 S-Series Mods 181 02-09-2007 11:32 AM
Intakes Space-Boy '97SL2m S-Series Tech 9 03-27-2000 04:28 PM
