Old 08-12-2006, 10:53 PM   #1
dw97sc1
dw97sc1 is on a distinguished road
Default Wires dealing with ignition.
What wires deal with the Sc1 starting coming from the firewall to the UHJB? Having a starting issue, I turn the key and nothing happens. But if I shake the wire set, the car starts.
Add to dw97sc1's Reputation
Rate the quality of this post and help dw97sc1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dw97sc1 is offline   Reply With Quote
Old 08-13-2006, 08:51 PM   #2
dw97sc1
Default Re: Wires dealing with ignition.
I should have added that this problem has been ongoing for a long time. People have suggested in the past the Neutral Safety Switch, but seems unrelated. Condensation somehow. Damp days/rainy days.
Thanks for your help in advance.
Old 08-13-2006, 10:37 PM   #3
SaturnFreek
SaturnFreek is on a distinguished road
1992 SL1
Rephrase that question with more explanation. Try cleaning your Ignition coils/module. I can't figure out what your speaking of.
Add to SaturnFreek's Reputation
Rate the quality of this post and help SaturnFreek reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SaturnFreek is offline   Reply With Quote
Old 08-13-2006, 11:09 PM   #4
dw97sc1
There is a cluster of wires coming out of the firewall, by the master cylinder. The cluster leads to the underhood junction box. I have had a problem with my not turning over or even tring to when I turn the key. If I shake the cluster of wires that I mentioned, the car will start? Other wise all I get is dash lights. Any ideas??
Thanks again.
Old 08-14-2006, 12:28 AM   #5
SaturnFreek
1992 SL1
There is a ground there. Make sure that bolt is not all coroded up/grounded well. Also check the ground to the battery.
Ignition wires, again Tom of Detroit S-Series Tech 4 11-16-2009 09:52 PM
Ignition Wires? richpor S-Series Tech 4 06-22-2007 07:41 PM
ignition, plugs and wires 97sleeper S-Series Mods 43 09-19-2006 05:14 PM
Question about ignition wires JrDave2324 Mods and Performance 6 06-16-2002 07:26 PM
ignition wires chulo Mods and Performance 1 05-14-2001 10:12 PM
