Old 07-24-2006, 10:31 AM   #1
loly75ddl
loly75ddl is on a distinguished road
Default HELP!! My Saturn Won't Start...
Forgive me for being a dumb girl and this being my first post. I know very little about cars but am Smart other wise. I own a Satrun SL1 - 2002 - that is automatic. I am having problems starting it. It was working fine the other day - then it wouldn't start - I would turn the key and it would make a clicking noise. I thought it might be the battery - but My lights radio all turned on. I had the battery tested and they stated it was good. I had my Friend help me by giving me a jump (meaning she put her jumper cables on her battery and then connected them mine, She started her car, then I started Mine) Then the car ran fine, Once i got home I shut off the car and Tried, starting it again - Same clicking noises. We repeated the jump process and it seems as if this is the only way my car will start - I know Jumping the car is not good to do this all the time. Please Help!!
Add to loly75ddl's Reputation
Rate the quality of this post and help loly75ddl reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
loly75ddl is offline   Reply With Quote
Old 07-24-2006, 10:39 AM   #2
Uzzy
Uzzy's Avatar
2002 SC1
Default Re: HELP!! My Saturn Won't Start...
If jumping the car is working it's most likely you have dirty, or corroded battery terminals. The current of your battery alone isn't always engouh to start it, but more than double the output, and it works. Get a scouring pad, steel wool, S.O.S. pad, or something like that, and remove each wire that goes to the battery one at a time, and clean it. Clean the ones on the battery, at both ends, and on the starter if you can reach them. If that doesn't fix it, I'd say either the battery is bad regardless of the test, or the starter is bad.
P.S. Check around the positive (+, red) terminal for signs of leakage, it's rather common. And you're not a dumb girl, you're smart enough to know who to ask.
Aut viam inveniam aut faciam
Add to Uzzy's Reputation
Old 07-24-2006, 11:04 AM   #3
loly75ddl
Thank you I will try that and see how it goes. I also appreciate the Compliment on not being dumb. I just feel so helpless when it comes to cars!!
Old 07-24-2006, 11:31 AM   #4
Uzzy
Uzzy's Avatar
2002 SC1
That's ok, I feel the same way when it comes to girls Cars are easy to understand. Good Luck!
Old 07-24-2006, 11:43 AM   #5
slowroller
slowroller is on a distinguished road
2008 Astra XR
Idea Re: HELP!! My Saturn Won't Start...
I would also go to an Autozone or some other and have them test your alternator when the car is running. Go there leave the car running or have them jump it it start it and then have them test the alternator while its still in the car if they can. It may have died and not be charging your battery while you are running. Also the ground on the starter may have failed but unlikely if you can jump it. Check the terminals and get the alternator checked. Also even though other things turn on they will not be as bright or as loud. Check to see if thats the case as well, but my thought is that the alternator is dead or dying. Go get it checked for free. Atleast rule it out.
Add to slowroller's Reputation
Rate the quality of this post and help slowroller reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
slowroller is offline   Reply With Quote
Old 07-24-2006, 06:03 PM   #6
Actually, the reason jump-starting works in this case is that the current is flowing thru a different path. If jump-starting works, the two points you've bypassed are the where the two terminals connect to the battery. It basically shows that everything else in the path is most likely okay. So, as Uzzy said, unscrew and clean those connections. Just DON'T do the positive one while the negative one is connected. Do it in this order: disconnect the negative and clean both sides of the connection. Leave it off, disconnect the positive and clean both sides of the connection. Reconnect the positive, THEN reconnect the negative.
+1. You're esp. smarter than even a lot of our "veterans", in that you posted the pertinent info (year, model, tranny) at the TOP of your post.
Add to madpogue's Reputation
Old 07-24-2006, 07:20 PM   #7
Uzzy
Uzzy's Avatar
2002 SC1
That could be true too, more likely in fact. It's probably a leaky positive terminal.
98 Saturn won't start every once in a while HELP shadowfax17 S-Series Tech 22 12-04-2010 08:31 PM
Quick start cold/ slow start warm 1st try, 2nd try quick start SWDude S-Series Tech 3 12-05-2009 11:27 PM
1995 Saturn SL2 Start Porblems- I NEED A SATURN EXPERT! JamesDator S-Series Tech 33 10-30-2007 05:11 PM
Saturn won't start, please help!!! JOakes302 S-Series Tech 3 02-01-2006 11:19 PM
Saturn won't start rudy S-Series Tech 4 12-27-2001 09:50 PM
