Old 02-12-2006, 11:26 AM   #1
rickystarshine
rickystarshine has a spectacular aura aboutrickystarshine has a spectacular aura about
rickystarshine's Avatar
2005 ION-2 Sedan
Default Ignition switch/Lock Cylinder question
Hello! this morning I noticed an electrical problem, when driving down bumpy roads, my dome light would blink on, then fade off. it would even do this when I flipped my Hi-beams on(not always, but a few times).
I noticed that this problem was very easy to duplicate by jigling my keys in the lock cylinder while driving down the road( I do not have alot of keys on my ring).
My question is, does this sound like a faulty ignition switch OR a bad lock cylinder?
Oh, the car is a 2001 sl1 automatic w/145,000 highway miles.
Thanks, these forums are great!
Add to rickystarshine's Reputation
Rate the quality of this post and help rickystarshine reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rickystarshine is offline   Reply With Quote
Old 02-12-2006, 08:19 PM   #2
rickystarshine
2005 ION-2 Sedan
Default Re: Ignition switch/Lock Cylinder question
when I got home tonight, I took the covers off of the steering column to try to figure this out.
What I've found is if I bang on the knee panel beneath the steering column, I could duplicate the problem, If I pull with moderate force on the wiring, I could duplicate the problem. If I wiggle the keys in the ignition I could very easily duplicate the problem, whether the car was running, or not( acc, run)
The dome light even blinked on momentarily when I turned on my headlamps.
Again, is this indicative of a bad switch or cylinder, or both? Anybody? Hello?
Rick
Ignition lock cylinder removal question.... rickystarshine S-Series Tech 10 04-23-2017 08:28 PM
Ignition Lock Cylinder or Ignition Switch? jzambon S-Series General 12 03-26-2017 04:30 PM
Radio Swap and Ignition Lock Cylinder Question... New Vue Owner 03zq8 Vue Tech 1 08-11-2007 02:42 PM
ignition switch or lock cylinder? kaseyskar S-Series Tech 11 09-26-2006 09:30 PM
'94-SL1 - ignition key in switch chime - ignition switch bezel question wrchism S-Series Tech 1 01-24-2005 02:09 AM
