Old 12-09-2005, 12:13 AM   #1
Brendo613
Brendo613 will become famous soon enough
Brendo613's Avatar
Wrench Two-Horn Setup Help: '96 SW2, Relay Pins 85, 86, 87, 30 ...
Mighty confused! I bought two horns, a low F and a high A for an interesting major-triad harmonization . The old horn used to be able to be wiggled to make it work, but now it just doesn't work at all, despite constant 12VDC on the orange, constant ground on the right, and the proper ground appearance when the switch is depressed on the center wire.
If anybody knows, I would greatly appreciate knowing ...
  • how to hook up the relay (pins 85, 86, 87, 30) to the fuse box
  • how to send that signal to horn one (as well as the second), and
  • how to integrate the switch.
I know that the relay should have positive in, negative in, switch in, and positive out, I believe, but which numbers are those hookups?
Please help, I don't feel safe not being able to warn somebody who doesn't see me, nor to warn the deer to get off of the shoulder of the road as they were today !
=Brendan
Add to Brendo613's Reputation
Rate the quality of this post and help Brendo613 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Brendo613 is offline   Reply With Quote
Old 12-09-2005, 08:50 AM   #2
Brendo613
Brendo613's Avatar
Happy Hmm
Looks like I found my answer to the pin / terminal problems:I still don't know where the 12v source will come from yet, nor how to get inside this relay / fuse box. I see how to take the cover off and read the fuses, but getting underneath it is the part I still need to figure out how to do.
Help for getting undnerneath the fuse / relay box?
=Brendan
Old 12-09-2005, 10:29 AM   #3
eljefino
eljefino's Avatar
1995 SW1
Default Re: Hmm
Carefully measure the leads heading to the saturn horn. The saturn horn has an integral relay, and, iirc, gets constant +12v with a switched ground.
Find the two wires that signal your saturn horn and hook them to the coil terminals of the relay. Whether its positive switched or ground switched doesn't really matter if you use both wires.
Run a 12 gauge wire from the + terminal at the head of the underhood fusebox (strut tower side) to the third relay terminal, and the fourth goes off to the horn(s). Ground the horn and you're done.
Add to eljefino's Reputation
Old 12-09-2005, 12:13 PM   #4
Low Saturn
Low Saturn's Avatar
2000 SC2
Default Re: Hmm
You dont need to get under the fuse box to get a 12V+ source. Remove to cover of the fuse box go gain access to the fuses. Towards the top left hand side you'll see a 7mm bolt attaching a positive terminal that runs to the battery. This is where you can get your 12V+ source.
Now wire it to your relay like this.
Terminal 87: To 12V+ source.
Terminal 85: To ground trigger on stock horn (just tap into the wire at the horn connector)
Terminal 30: To positive wire on new horns
Terminal 86: Also to 12V+ source
Old 12-09-2005, 12:31 PM   #5
Brendo613
Brendo613's Avatar
Idea All Righty
I've already measured the leads, so I know which ones give what power, so that's all set. I could just hook it all up like that, but I was wondering how to integrate the relay into the relay and fuse box, instead of just having it somewhere underneath the hood. With the relay plugged into the unused spot of the fuse / relay box, how do I hook up the wires underneath the box to the proper spots? That's the part I'm confused about, how to take apart the box.
Also, since I'm running two horns (both horns not being polarity conscious), I'm thinking of hooking them up in series: positive to terminal A of horn 1 and terminal A of horn 2, then terminal B of horn 1 and terminal B of horn 2 to ground.
Sound okay?
=Brendan
Old 12-09-2005, 02:02 PM   #6
Brendo613
Brendo613's Avatar
Default Fuses, too
Also, wiring as instructed two posts up, I won't be using the 10A fuse to protect the horn in case of a surge; that's another reason I want to incude the fuse / relay box with the new horn.
=Brendan
Old 12-09-2005, 02:10 PM   #7
BarnOwl
BarnOwl's Avatar
Default Re: All Righty
Sound okay?
I would recommend wiring them in parallel, but reading this again, I think that may be what you are describing.
Add to BarnOwl's Reputation
Old 12-09-2005, 02:42 PM   #8
Brendo613
Brendo613's Avatar
Default Re: Two-Horn Setup Help: '96 SW2, Relay Pins 85, 86, 87, 30 ...
Yeah, I did mean parallel back there ... I started typing out series, but then realized that didn't really make sense, so I changed the end of the sentence but not the beginning.
I'll have to edit that
=Brendan
Old 12-09-2005, 03:26 PM   #9
eljefino
eljefino's Avatar
1995 SW1
you're going to want more than 10 amps for the horn fuse
Old 12-10-2005, 12:58 PM   #10
Brendo613
Brendo613's Avatar
Thumbs Up Toot toot
Well, horns work I soldered on those slide connectors, the crimping felt anemic. Physical connections never really thrill me when they could be soldered (even though that's physical, too ... eh, whatever). Interesting mix, now people will hear me and my horn will work. Yay for horns
=Brendan
horn relay Dro S-Series Tech 3 01-06-2008 12:43 PM
DRL Relay Pins dshivers Vue Tech 3 07-02-2007 06:49 PM
Dual horn setup blue98sl2 S-Series Tech 4 04-07-2006 04:52 PM
bad horn relay? abadonazure S-Series General 8 07-20-2003 12:11 PM
horn relay verbose Miscellaneous Tech 1 06-13-2000 08:26 PM
