Old 02-02-2005, 03:21 PM   #1
HomeBase
HomeBase is on a distinguished road
Default 96 SL2, Used Oil Analysis, Shell Rotella-T 5w-40 Synth
(also posted this at BITOG)
Shell Rotella T 5w-40 Synth
Filter: Amsoil SDF57
Makeup Oil: none
Sample taken, oil not changed, topped with 1 qt of Pennzoil 5w-40 Synth
Fresh PCV at start of OCI
Cleaned the EGR & throttle body plate 1500 miles into interval
Mostly highway driving, a handful of "let 'er warm up by idling" mornings, FP and LC used.
Insolubles are down thanks to a more robust oil filter IMO.
Bottom line: it's running quite rich. I'm going to changed the ECTS. This truly is a Saturn-ism. Hopefully this cures the fuel issue.
Add to HomeBase's Reputation
Rate the quality of this post and help HomeBase reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
HomeBase is offline
Old 02-02-2005, 05:37 PM   #2
spencerb
spencerb will become famous soon enoughspencerb will become famous soon enough
spencerb's Avatar
2008 Astra XR
Default Re: 96 SL2, Used Oil Analysis, Shell Rotella-T 5w-40 Synth
Results look good. I would run the oil until at least 5,000 miles and test it again. The numbers are well within acceptable ranges. Not sure if the flashpoint even matters. IMO viscosity and insolubles are the two key factors. Of course you don't want fuel, coolant, or water in the oil, but it looks like you don't have a problem there.
Past Saturns: 97 SL2, 01 SC2, 04 VUE, 08 Astra, 02 L200.
Add to spencerb's Reputation
Rate the quality of this post and help spencerb reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
spencerb is offline
Old 02-06-2005, 10:43 PM   #3
Tiger
Tiger's Avatar
I replaced my ECTS today before it failed. It had hairline cracks, that when pushed, became fractures. You may want to get that ECTS changed soon. It seems that it is not if, but when it will fail. Also, I go to Bitog and follow all of your UOA's. I want you to get the fuel reading down, so I will have an idea what extended drain intervals are possible with this engine.
Add to Tiger's Reputation
Tiger is offline
Old 02-10-2005, 11:59 AM   #4
HomeBase
Tiger, I appreciate that someone is interested in Saturn data!
I just switched from the RotellaT to Pennzoil 5w-30 dino SM formula. I'm really impressed with this oil! The free-revving spirit has come back just as higher MPG has as well! 30-32MPG for the RotellaT using V-Power and FP, 36.5MPG on the first tank with PZ, Shell V-Power and FP. That's a big difference in my book.
If fuel dilution is an issue, MPG can only go up once I get the dreaded ECTS replaced!
HomeBase is offline
Old 02-10-2005, 01:10 PM   #5
pickardracing
pickardracing is on a distinguished road
pickardracing's Avatar
you guys are seriously using oil thats made for big ass diesels in your cars?
Current: 1994 SL1 Auto (NEW!) - 1993 SC2 Manual
Past: 1993 SC2 Manual - 1993 SL1 Manual - 1991 SC2 Manual
Add to pickardracing's Reputation
Rate the quality of this post and help pickardracing reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
pickardracing is offline
Old 02-10-2005, 05:19 PM   #6
HomeBase
The oil is not only spec'd for diesel engines, it also has the standard passenger car SL rating on the bottle too. Most "diesel" oils such as Delo 400, Delvac 1300 and Pennzoil Long Life are far more robust and last far beyond the "3 months or 3000 mile" mindset.
It's a misconception that "diesel" oils can't be used in passenger cars given their successful SL rating. Honda's preferred oil in Japan is 15w-40! NOT the 5w-20 that's being used in the U.S.
HomeBase is offline
Old 02-10-2005, 05:21 PM   #7
pickardracing
Looks like ive got some research to do.
Old 02-10-2005, 10:22 PM   #8
gdelgrego
gdelgrego is on a distinguished road
2007 AURA XE
1992 SL2
I've run Delo 400 on my '92 SL2 and liked how it performed... but anytime I sent a sample to Blackstone they'd say to stop using diesel oil or risk damaging the catalytic converter.
HomeBase... have they said the same to you? Reading some on BITOG I'm not convinced that it really is a problem or not. I burn about 1 qt oil / 1000 mi or so.
Add to gdelgrego's Reputation
Rate the quality of this post and help gdelgrego reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
gdelgrego is offline
Old 02-10-2005, 10:28 PM   #9
Tiger
Tiger's Avatar
Here is a good place to start:
http://www.bobistheoilguy.com/
Tiger is offline
Old 02-10-2005, 10:57 PM   #10
pickardracing
Not sure i want to use that site as a reference, i know that its filled with Schaeffer's propoganda. But ill give it a look.
Old 02-10-2005, 11:37 PM   #11
Sky King
Sky King's Avatar
Where are the sources for oil analysis and what does it usually cost?
Add to Sky King's Reputation
Rate the quality of this post and help Sky King reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Sky King is offline
Old 02-10-2005, 11:38 PM   #12
HomeBase
I've never used Schaeffer's, but the proof is in the analysis...they're oils are top notch. They're just more costly than others.
HDEO won't kill a cat. I don't buy that at all, although I used to.
Why?
Look at the ZDDP levels of non HDEO oil...SL spec's run around 800-1000ppm. HDEO's run 1000-1300ppm. If you burn a quart of HDEO per 1000 miles or you burn 1.5qts of thinner "regular" oil, what's the difference? Looking at the big picture, it just doesn't add up to me.
And, at what point will at cat be "poisoned"? There's NEVER any documentation on that...just the fear that it will be ruined.
HDEO's will be pressed to reduce ZDDP levels in the near future, much like the SM-based in the passenger car world.
My rant is over.
HomeBase is offline
Old 02-10-2005, 11:43 PM   #13
Razorbak
Razorbak's Avatar
I just used Blackstone Labs for the first time, and I thought they offered a decent product. Fast and informative. The test cost $20 + shipping. Here is the link...
http://www.blackstone-labs.com/
Add to Razorbak's Reputation
Razorbak is offline
Old 02-11-2005, 01:00 AM   #14
Tiger
Tiger's Avatar
Actually, I think the person who started that site, Bob, distributed Schaeffer's products. At least he talked about the products in some posts I have read. But, I have not found a lot of information on Schaeffer's products since I have joined. Many people have had great UOA's using their oil. I live here in St. Louis, so it would be very easy to go to the Schaeffer's and pick-up their products. I am using something called Auto-RX and Fuel Power instead. My cars have never run better. What I have found at BITOG is a lot of information that dispels myths, and scientific evidence of what works and what does not.
Tiger is offline
Old 02-11-2005, 09:51 AM   #15
spencerb
spencerb's Avatar
2008 Astra XR
haha ALL oils last beyond 3/3000. Even the Wal-Mart brand SuperTech I use.
If people woudl READ THEIR OWNER'S MANUAL they would learn that 3/3000 oil changes are largely a thing of the past. Only a handful of driving conditions warrant oil changes that soon.
spencerb is offline
Old 02-11-2005, 11:16 AM   #16
Tiger
Tiger's Avatar
OK, I am reading my OWNER'S MANUAL:
When to Change Engine Oil: See if any one of these is true for you:
-Most trips are less than 5-10 miles (no)
-It is below freezing day and night. (This time of year much of the time)
-Most trips include extensive idling (Definately, well, how do define extensive?)
-You frequently tow a trailer or use a carrier (never)
-You drive in dusty areas (rarely)
-Your Saturn is used for delivery service, police, taxi or other commercial applications (I use it to transport clients?)
I am under warranty, so for now it is 3,000 intervals. The question is how far can you run SuperTech oil unless you do an oil analysis? That is why I am hoping Homebase can get some good data as to what works, and what does not. My only problem with oil analysis is that it is cheaper to do shorter intervals with the 88 cent Havoline oil I purchased. If this car did not have such problems with oil control rings sticking, I would be a little more comfortable with what you are saying Spencerb.
Tiger is offline
A Look at Oil Analysis for 92 SL2 stanleyr S-Series Tech 2 10-30-2007 02:04 PM
A Look at Oil Analysis for 92 Sl2 stanleyr S-Series Tech 2 05-18-2007 09:08 AM
Shell Rotella Recommendation, inquiry Luke S-Series Tech 24 01-19-2007 03:52 PM
A Look at Oil Analysis for 92 SL2 stanleyr S-Series Tech 5 08-26-2006 04:35 AM
Shell Rotella T 5W40 good oil for the saturn 1.9? turbobuick33 S-Series General 25 11-10-2005 08:45 PM
