Old 01-11-2020, 05:52 PM   #1
johnpatrick
johnpatrick is a jewel in the roughjohnpatrick is a jewel in the roughjohnpatrick is a jewel in the rough
Default new tire recommendations?
I've started looking to get new tires for a '99 SL1 with OE Saturn 14" rims.
I've always bought Michelins, but they seem to be no longer making any 175/70/r14 size tires.
What would be your recommendations on good quality, readily available, not-too-costly tires?
Add to johnpatrick's Reputation
Rate the quality of this post and help johnpatrick reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
johnpatrick is offline   Reply With Quote
Old 01-11-2020, 06:10 PM   #2
SRGW
1997 SL1
Post Re: new tire recommendations?
GENERAL ALTIMAX RT43
Good in wet and snow I use them on my 1997 SL1
1995 SL1 236,300 2005>2018
1997 SL1 81,081 2014>????
CHECK YOUR OIL!!
Add to SRGW's Reputation
Rate the quality of this post and help SRGW reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 01-11-2020, 07:18 PM   #3
onlinebiker
Default Re: new tire recommendations?
Evert time I buy a car it seems to come with decent tires...
I haven't bought a new tire in years..
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
01 SC2 x 2 yellow
02 SC2
02 SL2
parts
2 94 SC2 parted out
2 96 SC2
Old 01-11-2020, 09:30 PM   #4
Waiex191
Waiex191 is a jewel in the roughWaiex191 is a jewel in the roughWaiex191 is a jewel in the roughWaiex191 is a jewel in the rough
Waiex191's Avatar
I've put these tires on my 2006 Dodge Ram, my 2000 Buick Century, and I like them. Cheap, good wet and snow traction.
https://www.tiresplus.com/tires/bran...llseason/11694
I'll be putting them on the sl2 this spring.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 01-11-2020, 09:41 PM   #5
454cid
I put GT Radial Champiro Icepro 3's on my SL2 in November. I'll have to get something else when it gets warm out.
I've got the 15" rims, Though.
1999 Chevy K3500
Add to 454cid's Reputation
Rate the quality of this post and help 454cid reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 01-11-2020, 11:47 PM   #6
toggenburg
toggenburg's Avatar
For $114 each, Walmart has the michelin defenders in a 185/70/r14 if you can fit it in.
https://www.walmart.com/ip/Michelin-...-88H/767831692
Old 01-12-2020, 03:20 AM   #7
Macgyver
Get the 185/65 14 Defenders. I've been running them for years. Saturn changed the 14" steel wheels to this tire size for the 3rd gen S series even though the wheel is the same size from 91-02.
Add to Macgyver's Reputation
Old 01-13-2020, 08:29 AM   #8
dummo
dummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of light
dummo's Avatar
1997 SW2
What is the difference in circumference between a 175 and 185? It may be enough to change the accuracy of your odometer/speedometer?
If you drive mildly like myself, any tire they sell is good enough. The cheaper the better if you don’t care about the name embossed on the sidewall.
• 1997 SW2 used 12/29/2011 with 124,200 -27 mpg
• 2004 Ion3 new 11/2003 (totaled) 11/2011 -23 mpg
• 1994 SL1 new traded
• 1992 SL2 new traded for above
Add to dummo's Reputation
Old 01-13-2020, 08:33 AM   #9
454cid
Here is what I use to figure how tires sizes may change things.
http://www.miata.net/garage/tirecalc.html
1999 Chevy K3500
Old 01-13-2020, 01:21 PM   #10
Highmile
Highmile's Avatar
or do what I did and dump the 14's and pick up a set of used 15" steels and covers. So many more choices of tires.
Highmile
'95 SL1 699k and counting
Add to Highmile's Reputation
Old 01-15-2020, 11:58 PM   #11
A2Saturn
A2Saturn is on a distinguished road
A2Saturn's Avatar
1994 SL1
+1 on General Altimax RT43. These are a top pick at Consumers Report. I bought a set last spring and have been pleased with them. Keep an eye on rebates. I would get 80-90k miles on the Michelin's I previously used. Last set were Defenders, and they just didn't seem to stay balanced. Fortunately, they were covered with lifetime balance at NTB.
Add to A2Saturn's Reputation
Rate the quality of this post and help A2Saturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
A2Saturn is offline   Reply With Quote
Old 01-16-2020, 04:04 PM   #12
trottida
trottida's Avatar
+2 General Altimax RT43. I've ran them for a couple years now and I'm pretty happy with the performance and quietness.
2012 Ford Focus SEL HB MT
2011 Suburban LT
Past Saturns
2001 SL1 MT (438,500 km 11y)
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Add to trottida's Reputation
Tire Recommendations? bjaspud Aura General 27 01-13-2014 10:06 PM
VUE Tire Recommendations Uzzy Vue General 11 01-22-2010 11:06 AM
Tire Recommendations Layoira Astra General 39 09-08-2009 08:57 PM
tire recommendations texan Vue General 67 11-09-2004 07:00 PM
Tire Recommendations blackandwhite Ion General 18 06-26-2002 11:50 PM
