Old 01-07-2020, 01:30 AM   #1
SL1Noob
SL1Noob is a jewel in the roughSL1Noob is a jewel in the roughSL1Noob is a jewel in the rough
Default buying orginal 1996 SL2 passenger motor mount and dogbone.
If have some or know where I can get some let me know.
Tried after market and they died within a year.
Just got my exaughst all fixed up I don't want to ruin it with my shakey engine.
Add to SL1Noob's Reputation
Rate the quality of this post and help SL1Noob reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SL1Noob is offline   Reply With Quote
Old 01-07-2020, 09:18 AM   #2
toggenburg
toggenburg's Avatar
Default Re: buying orginal 1996 SL2 passenger motor mount and dogbone.
I can no longer locate the Ebay seller who had probably the last original top mount (he was ~$150), but this one appears ok, and has a 5-year warranty (if you don't mind redoing it under warranty every year or less!).
Seriously, for $18.10 delivered, how good could it really be?
https://www.ebay.com/itm/Engine-Moto...kAAOSwbl9dHFkG
Old 01-07-2020, 09:44 AM   #3
Just get the solid style mount or fill the frowny style with 3M WindowWeld.
Helps to fill the transmission mount as well and swap the dogbone inserts with Prothane 7510's (if your current ones have the swappable insert style dogbones).
Old 01-07-2020, 11:48 AM   #4
Zeebins
Zeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to behold
Zeebins's Avatar
Unless someone finds another batch of OE passenger side mounts, they are gone forever. I’ve heard Westar or DEA to be at least a decent replacement. I personally have no experience with either though. Westar does have a longer warranty though (1 year vs 6 months). You’re gonna be replacingg passenger mounts more often though once you go aftermarket so it may be more worth it to find one locally with a lifetime warranty. Advanced auto carries Anchor mounts with a lifetime warranty, but there unfortunately the frowny design.
97 SL2, auto, 117K miles
Powered by Plastic
Add to Zeebins's Reputation
Rate the quality of this post and help Zeebins reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 01-11-2020, 12:47 PM   #5
SL1Noob
Thank you all for the replies, I have been busy job hunting and this has been not the top of my priority as it should be. I will take all your advice to heart. It's sad to see that the originals are all gone.
Are junkyards still a possible option or are they probably just as bad or worse than mine???
Old 01-11-2020, 01:33 PM   #6
Zeebins
Zeebins's Avatar
You can try the junkyard. There’s a way to test if a mount is good or not with a pen. The after market mounts look pretty much identical to the OE ones though so you’d probably be better off just getting a new after market one.
Powered by Plastic
Old 01-11-2020, 02:29 PM   #7
focusofheart
focusofheart is a jewel in the roughfocusofheart is a jewel in the roughfocusofheart is a jewel in the rough
DEA/MARMON RIDE CONTROL A2827HD
Front Right; 1st Design (use the 'point to zoom' to look at all sides of the motor mount on the link)
https://www.rockauto.com/en/moreinfo...1266971&jsn=12
I will shortly be installing an original top mount, purchased off ebay, and I can tell you that the DEA on Rock Auto (link above) looks the same, except DEA provides the bolts along with the motor mount - if that is of any help.
The original, 1st design motor mount my 98SL2 Saturn had, lasted about 15 years.
Saturn 1998 - SL2 automatic
Singer 1952 - 301A knee driven
Add to focusofheart's Reputation
Rate the quality of this post and help focusofheart reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 01-11-2020, 05:26 PM   #8
toggenburg
toggenburg's Avatar
Has anyone tried Fetchitfido's 3M Window Weld product on their own worn out original Saturn top engine mount to see it the stuff will 'repair' their own ??
Old 01-12-2020, 12:01 AM   #9
me.theuser
me.theuser is on a distinguished road
2002 SL1
2001 SL2
the WESTAR 1st design mount I bought lasted nearly two years the rubber blew out it almost looked like it was liquid when it had ruptured
I have the DEA 1st design mount now we'll see how it lasts
$8-$10 per year or bi-yearly isn't a big deal though
Add to me.theuser's Reputation
Rate the quality of this post and help me.theuser reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
me.theuser is offline   Reply With Quote
Old 01-12-2020, 01:26 PM   #10
Good info - has anyone else here experienced Westar mount failures?
Usually people are posting good experiences wehn the mounts are new.
(mostly bumping p2 threads to push the spam threads to p2)
Looking for all 4 orginal motor / trans mounts 1998 SL2 SL1Noob S-Series General 2 02-04-2019 04:34 PM
Replaced front passenger motor mount Silverblu02SL2 S-Series General 8 01-29-2019 12:46 PM
This is def broke right? (lower dogbone mount + Upper engine mount).... PresarioSaturn S-Series Tech 6 02-16-2011 09:55 AM
Does the motor actually rest on the passenger side "dogbone"? SinistrV6 S-Series Tech 2 11-01-2008 07:14 PM
Dogbone engine mount questions - 1996 SL2 Civic&Saturn S-Series Tech 5 07-27-2005 02:30 PM
