Old 12-05-2019, 03:09 PM   #1
DJCharlie
DJCharlie is a jewel in the roughDJCharlie is a jewel in the roughDJCharlie is a jewel in the rough
DJCharlie's Avatar
Question Turn signal bulb not working.
This might sound dumb but I'm having trouble getting my front right turn signal to work in my 96 SC2. I figured the bulb was out so I swapped the bulb but only The DRL part of the bulb is working when I turn the turn signal on nothing happens. All of my other bulbs work. I'm assuming the big bulb functions as the drl bulb and the turn signal. Any idea why it's not working?
Add to DJCharlie's Reputation
Rate the quality of this post and help DJCharlie reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
DJCharlie is offline   Reply With Quote
Old 12-05-2019, 08:17 PM   #2
98_Gold_Uranus
98_Gold_Uranus is a jewel in the rough98_Gold_Uranus is a jewel in the rough98_Gold_Uranus is a jewel in the rough98_Gold_Uranus is a jewel in the rough
98_Gold_Uranus's Avatar
Default Re: Turn signal bulb not working.
When I first got my 98 SL2, I had the same issue. Ended up just being corrosion in the socket for the bulb. I just took a tiny flat head screw driver, stuck it in the socket and carefully scrapped loose any corrosion I could see on the contacts in the socket, blew it out, stuck a bulb back in it, and haven't had a problem since.
98 SL2, 70k miles, kept in the family since new!
Her name is Uranus :)
Add to 98_Gold_Uranus's Reputation
Rate the quality of this post and help 98_Gold_Uranus reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
98_Gold_Uranus is offline   Reply With Quote
Old 12-06-2019, 01:54 AM   #3
TomM96
I think the DRL employs the Headlights.
The 'park' lights, and turn signal share a bulb with two filaments (i think!), located in the extreme edge of the headlamp fixture.
It is often the case that the signal filament fails before the park light.
Sometimes signal filaments fail to illuminate because they require more power, and that increment of power is not available via the common Ground connection.
The relevant ground connection is the forward lamp ground about a foot behind the headlamp assy atop the right frame 'horn' , secured with a M6X1 screw with 10mm hex. This ground is subject to deterioration because its contacts are not sealed from the weather/road-salt; my contacts were badly degraded by corrosion on my 2000 S.
I'd investigate possibility of socket issues as suggested by 98_Gold_Uranus; if socket OK, maybe check ground wire.
Add to TomM96's Reputation
Old 12-06-2019, 09:28 AM   #4
trottida
trottida's Avatar
Keep in mind that the OP has a 96 SC2 with the pop up headlights. The DRL's are not associated with the headlights as they are not exposed in the daytime (when the headlights are off) like the sedan or wagon's would be. As far as I can tell the turn signal, parking light and DRL are one in the same using a 2057 dual filament bulb.
I do think you're on the right track with checking the dual filament bulb 2057, socket and the ground pack/ground wire. You may want to check the fuse as well; perhaps the turn signal has a separate fuse than the DRL.
2012 Ford Focus SEL HB MT
2011 Suburban LT
Past Saturns
2001 SL1 MT (438,500 km 11y)
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Add to trottida's Reputation
Old 12-06-2019, 06:10 PM   #5
DJCharlie
DJCharlie's Avatar
So unplugging the entire side marker bulb assembly and plugging it into my other sc2 the turn signal and everything works but when I plug it into my daily everything but the turn signal works. It has to be farther down the line maybe there's a wire just for the turn signal that's frayed? Not sure but I guess I can live without a front right.
Old 12-07-2019, 07:47 AM   #6
trottida
trottida's Avatar
That was a good move to test the complete assembly ruling out the bulb and socket. The wiring for the turn signal comes from the UHJB following a path on the engine side of the radiator support. I would take a look at the related fuses in the UHJB as well as the test the wire for continuity between the fuse box and the light assembly. You should also look at the ground pack and the black wire that comes from the light assembly going to the ground pack.
2011 Suburban LT
Past Saturns
1993 SW2 AT (10y)
1992 SL2 MT (5y)
:canada:
Old 12-07-2019, 09:30 AM   #7
Signmaster
I had a dead side marker and went through the same.
Check the ground that is on the front passenger side. On my SL1 it's clearly visible from above, but you might have to look a bit harder with those pop up headlights. On mine I cleaned up the ground and all was good again.
Rear turn signal bulb toggenburg L-Series General 17 05-04-2016 11:05 PM
98 SW2 Front Turn Signal Bulb P/N? SW2 Driver S-Series General 11 07-20-2012 09:01 AM
Turn signal bulb onizuka78 Astra General 4 04-16-2012 12:21 PM
Front Turn Signal Bulb ygor Relay Tech 2 01-24-2007 12:28 AM
Turn Signal Bulb Smokey Relay Tech 1 11-07-2006 11:45 PM
