Old 11-28-2019, 11:22 AM   #1
am3gross
am3gross is on a distinguished road
Default 2002 reverse lights in an automatic
i am trying to get the reverse lights to wrok and i cant remember the part name for the piece to fix it, i believe it to be the part on the back of the trans. can some one help me with the part name so i can research it?
also, Happy Thanksgiving!
Michael
Add to am3gross's Reputation
Rate the quality of this post and help am3gross reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
am3gross is offline   Reply With Quote
Old 11-28-2019, 11:47 AM   #2
454cid
Default Re: 2002 reverse lights in an automatic
Michael
Neutral Safety Switch / Range Sensor?
1999 Chevy K3500
Add to 454cid's Reputation
Rate the quality of this post and help 454cid reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 11-28-2019, 12:12 PM   #3
am3gross
Neutral Safety Switch / Range Sensor is what i was thinking, if this switch was bad would it prevent my back up lights from coming on?
originally i thought yes, but after watching a few videos i am doubting myself.
thanks,
Michael
Old 11-28-2019, 12:31 PM   #4
trottida
trottida's Avatar
Here is the backup light switch for the manual transmission. Not sure if your are manual or automatic. It is located on the transmission as you stated.
https://www.autozone.com/electrical-...030/124145_0_0
https://www.rockauto.com/en/catalog/...mp+switch,4240
Edit: The automatic uses a different part. The Neutral Safety Switch / Range Sensor as you mentioned.
2012 Ford Focus SEL HB MT
2011 Suburban LT
Past Saturns
2001 SL1 MT (438,500 km 11y)
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Add to trottida's Reputation
Old 11-28-2019, 12:40 PM   #5
454cid
Um, check the thread title
1999 Chevy K3500
Old 11-28-2019, 12:41 PM   #6
am3gross
[QUOTE=trottida;2310818]Here is the backup light switch for the manual transmission. Not sure if your are manual or automatic. It is located on the transmission as you stated.
it is an automatic
Old 11-28-2019, 12:48 PM   #7
trottida
trottida's Avatar
Right! I never look there for some reason. I always look to the left side bar or the signature.
2011 Suburban LT
Past Saturns
1993 SW2 AT (10y)
1992 SL2 MT (5y)
:canada:
Old 11-30-2019, 02:09 AM   #8
PrestonIII
PrestonIII has a spectacular aura aboutPrestonIII has a spectacular aura aboutPrestonIII has a spectacular aura about
It could be the switch on the transmission, but don't discount the easy stuff first. It could be a fuse, or even a broken wire in the trunk or behind one of the tail lights. It wouldn't hurt to check the bulbs too.
It could be an adjustment issue on the switch as well.
Add to PrestonIII's Reputation
Rate the quality of this post and help PrestonIII reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
PrestonIII is offline   Reply With Quote
Old 11-30-2019, 03:01 AM   #9
TomM96
I forget the proper term on these cars for the PRINDL /NSS /Trans Selector SW.
/ range SW...
sorry
Add to TomM96's Reputation
Old 12-02-2019, 06:10 PM   #10
am3gross
thanks everyone for the responses, i will be looking into this more this weekend, i have checked the bulbs wiring and fuses. i have not tried any adjustments yet, so i will try that and see if i can adj it.
again thanks for the replies!
Old 12-04-2019, 11:40 PM   #11
TomM96
Sometimes if car not driven much the contacts in SW might get dirty.
So can put IgSW in ACC, then move the NSS/range selector forward/back several times (like 25 to be sure).
You can check the switch by 'jumping' the requisite wires/terminals, then see if lights work. If lights NG then, follow the trail.
@RockAuto>
SATURN > 2002 > SL SEDAN > 1.9L L4 DOHC > Electrical-Switch & Relay > Neutral Safety Switch / Range Sensor
STANDARD MOTOR PRODUCTS NS118 {#21022303} Info
Automatic trans. $40.79
Delco a little more; WDV a little less$.
Sometimes the sockets fail, more often the bulb-filaments go out.
There is a rear 'ground pack' (left side trunk in '97 & 2000 SW)
but that also grounds the other rear lamps, as brakes.
Old 12-15-2019, 03:45 PM   #12
am3gross
ok, here is a little up date.
i ordered and changed the neutral safety switch. my reverse lights now have power going to them, one works and the other the wires were pulled from the plug, so i will have to order a new plug and get a new bulb and that side will work as well. i checked for power there and it is present so no issues there.
however my new problem is that i am not getting a code P1816.
quick search tells me that the line pressure is to high or to low. correct me if i am wrong but that is the valve body in the trans, which i have already changed just a few months ago with a rebuilt unit. someone tell me if i am wrong!
thanks, Mike
2002 Saturn Sl1 Automatic with P0732, P0733, P0783, and reverse bang SaturnMass S-Series Tech 2 01-14-2018 09:08 PM
2002 SL1 - manual - reverse lights don't come on properly. bizcas84 S-Series Tech 4 05-16-2011 08:50 AM
2005 AWD V6 Automatic Reverse lights not working jabroni1m Vue Tech 5 03-29-2010 10:01 AM
2002 SL1 Reverse Lights Not Working lausch1973 S-Series Tech 2 04-16-2009 12:40 PM
Accidentally burned out instrument panel lights and reverse lights on '99 Saturn Sc1 tjohnny42 S-Series Tech 19 07-09-2008 10:40 PM
