Old 11-28-2019, 04:41 AM   #1
454cid
Default idle is low for first second at startup?
2000 SL2 automatic 17X,XXX miles
I've noticed recently that my idle will be low for the first second, or split second, at startup. It makes me think the engine is trying to die, but the PCM quickly makes an adjustment to keep that from happening.
It will often high idle, which I'm assuming is the TPS. Is this momentary low idle at startup also the TPS?
I haven't tried to pull codes recently, and I can do that, but the light isn't on.
1999 Chevy K3500
Add to 454cid's Reputation
Rate the quality of this post and help 454cid reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 11-29-2019, 05:09 PM   #2
454cid
Default Re: idle is low for first second at startup?
No one? Well, I guess I'm going to order the TPS, as I'm pretty sure I need it for the high idle issue any way. Rockauto has it pretty cheap.
1999 Chevy K3500
Old 11-30-2019, 01:19 AM   #3
TomM96
maybe TPS; IAC Valve; fuel pressure Regulator (which in filter) ..?
Add to TomM96's Reputation
Old 11-30-2019, 05:42 PM   #4
I agree, tps or iacv for an initial guess. With startup rpm initially lower than normal idle, this suggests an iacv issue because the lower idle jumping up to idle rpm is the pcm commanding the iacv to retract (initially extended) to allow more airflow thru the bypass air port in front of the throttle plate (supplemental bypass air). The mechanically fixed throttle plate is set for 500-600 rpm with bypass air port blocked. Unblocked, ported air is fed into the intake manifold to raise rpm to programmed values (cold idle around 1200-1500 rpm, warm idle around 650-800 rpm). The pcm commands the idle air control valve to choke/lower or open/raise idle rpm for varying loads and temperatures. It may be sticking and need cleaning or is announcing its demise. The tps has its own unusual characteristics when its wears down.
Under normal conditions, when ignition is turned on, the pcm uses the initial tps signal as 'zero' as a reference to all other tps positions. When the flat carbon resistor wears out from years of wiper action, the resistor value becomes compromised. This gives distinct symptoms of random high idling, corrected when the engine is shut off and restarted, the zero reference was lost leading to random idle fluctuations. Once diagnosed as a worn out tps, its replaced.
Old 11-30-2019, 07:08 PM   #5
454cid
Thanks for the explanation. I do have the TPS issue you mention, but had no idea how that worked.
Maybe I can get away with just cleaning the IAC, as it does not happen every startup... more when it's cold.
1999 Chevy K3500
Old 11-30-2019, 11:26 PM   #6
When a worn tps is diagnosed and verified by restarting the engine when it randomly high idles, the restart is the pcm relearning the tps home position as a voltage signal to let the pcm restore idle back to normal. This can be repeated as many times to confirm a worn out tps.
Fast idle on startup sisjake S-Series Tech 1 11-26-2010 09:35 PM
High idle at startup... most likely culprit?... Hackster S-Series Tech 4 07-21-2007 11:09 PM
Rough idle on startup Imagyne S-Series Tech 4 08-17-2005 04:21 PM
rough idle at startup OldGeezer Ion General 16 07-30-2003 10:56 PM
Rough Idle at Startup Steve96SL2m Miscellaneous Tech 10 03-10-2002 01:44 PM
