Old 07-03-2018, 09:55 AM   #1
Havenmess
Havenmess is on a distinguished road
Default Oil Leak 2007 Vue FWD V6
Hello All,
I have 2007 Vue, FWD, V6 which recently developed any oil leek, from the middle of the car toward the front (about 2-3 feet from front bumper).
It is about the size of a quarter every few days. I put it up on ramps to check to see if I could see where it was coming from. The oil plug is dry. I think I did found where I think it is coming from and took a picture. Can any one identify what this area is (almost directly under the front console/cup holders)? I have attached a photo. Thanks!
Add to Havenmess's Reputation
Rate the quality of this post and help Havenmess reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Havenmess is offline   Reply With Quote
Old 07-03-2018, 10:29 AM   #2
Vue6
Vue6's Avatar
2006 VUE Red Line
Default Re: Oil Leak 2007 Vue FWD V6
...COVER PLATE FOR ACCESS TO FLYWHEEL BOLTS, IT IS PROBABLY YOUR REAR MAIN SEAL LEAKING , HOPE THAT HELPS, DC.
Add to Vue6's Reputation
Old 07-03-2018, 09:37 PM   #3
mkez1
mkez1 is on a distinguished road
We have the same leak on a Vue with 345k miles. There were some posts here suggesting either the main seal or the oil pan seal, I've been hoping it's just the oil pan.
Add to mkez1's Reputation
Rate the quality of this post and help mkez1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mkez1 is offline   Reply With Quote
Old 07-04-2018, 01:06 AM   #4
Mr Toad
Mr Toad has a spectacular aura aboutMr Toad has a spectacular aura about
Mr Toad's Avatar
I had the same leak. I changed my oil with Valvoline MaxLife High Mileage oil and in 2 weeks, No more leak.
2005 Saturn Vue
Front Wheel Drive
3.5L V6 Engine
5AT Automatic Transmission
160,000+ miles
Add to Mr Toad's Reputation
Rate the quality of this post and help Mr Toad reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Mr Toad is offline   Reply With Quote
Old 07-04-2018, 10:39 AM   #5
atikovi
Most 10+ year old vehicles will leak some fluids. If that's all you have, not worth fixing unless you are replacing the transmission because you have to take it out to get to the seal. You can try what the frog said, or some additive specifically made for leaking oil seals.
Add to atikovi's Reputation
Old 07-04-2018, 11:36 AM   #6
JosephN79
JosephN79 is on a distinguished road
JosephN79's Avatar
2004 VUE Red Line
Toad, did you use any additives? Or just oil and filter change?
Add to JosephN79's Reputation
Rate the quality of this post and help JosephN79 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
JosephN79 is offline   Reply With Quote
Old 07-04-2018, 02:37 PM   #7
RobertGary1
Itís your variable timing actuator. Itís a figure 8 seal right behind the crank on the firewall side of the engine. Not too difficult to replace.
-Robert
Old 07-04-2018, 02:41 PM   #8
RobertGary1
Common issue for small leaks on his engine
-Robert
File Type: jpg AA988B4C-557A-41F6-9576-5AA52B9DCD0D.jpg (74.1 KB, 25 views)
Old 07-04-2018, 06:33 PM   #9
JosephN79
JosephN79's Avatar
2004 VUE Red Line
Gary... is this something that could be mistaken for rear main seal? I do have a lot of oil at the inspection plate and to the back?
Old 07-05-2018, 04:14 AM   #10
VUEmaniac
VUEmaniac is a jewel in the roughVUEmaniac is a jewel in the roughVUEmaniac is a jewel in the roughVUEmaniac is a jewel in the rough
-Robert
I have seen that leak, but it's nowhere near where he's seeing the oil drip. It's almost certainly the rear main seal. I'd switch to a high mileage oil formulation which should slightly swell the seal and may stop the leak since it's so small.
Best,
Don't blame a clown for acting like a clown. Ask yourself why YOU keep going to the circus.
Add to VUEmaniac's Reputation
Rate the quality of this post and help VUEmaniac reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
VUEmaniac is offline   Reply With Quote
2007 vue fuel leak Jcainsprint00 Vue General 13 11-15-2016 03:40 PM
2007 Ion Fuel Leak Dan_G Ion Tech 6 09-07-2016 08:51 PM
2007 Ion-2 Gas Tank Leak cbrian Ion General 2 05-16-2016 09:56 PM
Radiator Leak on 2007? Surovich Vue Tech 4 05-15-2011 07:56 PM
2007 Ion, Evap Leak... windblownmonkey Ion General 19 10-20-2009 04:38 PM
