Old 06-05-2018, 01:50 PM   #1
bikeone43
bikeone43 is on a distinguished road
2009 VUE 2.4L
Default 2009 saturn vue a/c problem
with the a/c having a full charge high side at 145 low in a vaccume it would seem that I have a blockage ? I pumped it down and put 22 oz of Freon in the low side went up to 50 but when the car was started it fell into a vaccume any ideas
Add to bikeone43's Reputation
Rate the quality of this post and help bikeone43 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bikeone43 is offline   Reply With Quote
Old 06-05-2018, 02:55 PM   #2
bikeone43
2009 VUE 2.4L
Default Re: 2009 saturn vue a/c problem
I let it set form 1 hr and the readings are hown 45 low side 225 high side outside 98 vent temp 55
Old 06-05-2018, 03:16 PM   #3
Which engine? 2.2L - 1.5 lbs, 3.5L - 1.75 lbs for '05 Vues. What's refrigerant capacity for your '09 Vue? Labeling in the engine bay lists refrigerant and oil amounts. Are vent temps taken while parked? Do vent temps drop once at speed?
Old 06-05-2018, 05:48 PM   #4
bikeone43
2009 VUE 2.4L
I cant find a sticker the vent does drop down at speed without the sticker I'll have to charge by pressure uless someone has the sticker to show the amount pressure are reading 225 high side 30 low side thanks for the replt
Old 06-05-2018, 06:47 PM   #5
Unless this Vue was damaged and poorly maintained, a separate sticker for ac is always somewhere under the hood. Owner's manual? It has the info too. No manual? Go online to; http://www.gm.com/owner-assistance/saturn.html. The last two pressure numbers seem about right. Low side should never go below 25 psi while high side will vary in proportion to outside temps and humidity. Service manuals have temperature/pressure charts I use for accurate info. Alldata or Mitchell subscriptions provide online service manuals.
2009 Vue XR not starting, possible electrical problem - Please help! sadiesmom29 Vue General 0 08-05-2017 10:18 AM
2009 Saturn Vue bfredcoaching Classifieds 2 11-25-2013 09:10 AM
ECM / TCM Saturn Vue 2009 pedro Vue Tech 5 07-20-2012 03:25 PM
Shifter Problem on Some 2009 Aura, Outlook, and Other GM Models Leads to Recall Charlie Outlook General 0 03-17-2009 09:55 PM
Even Better New 2009 Saturn Vue dadavue 2008 Vue 42 01-10-2009 06:03 PM
