Old 08-28-2013, 12:46 AM   #1
Articwhite2008
Articwhite2008 is on a distinguished road
Articwhite2008's Avatar
2008 Astra XR
Default Fixed Trunk Latch and Flickering License Plate LED light
So I have been having weird electrical issues with the trunk not opening sporadically and my license plate light flickering/going out completely. I removed the inner panel of the trunk and unplugged and replugged everything I could see. The plug that attaches to the lock mechanism seems to have been the culprit. Once I replugged it, everything started working fine again. The license plate doesnt flicker and the trunk opens every time. Weird.
Add to Articwhite2008's Reputation
Rate the quality of this post and help Articwhite2008 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Articwhite2008 is offline   Reply With Quote
Old 08-28-2013, 11:08 AM   #2
Astra La Vista!
Astra La Vista! has a spectacular aura aboutAstra La Vista! has a spectacular aura about
Astra La Vista!'s Avatar
2008 Astra XR
Default Re: Fixed Trunk Latch and Flickering License Plate LED light
If you are a DYIer, you might want to attempt to replace the connector (unlikely to be available from the dealer, so you might have to cut up the harness of a wrecked Astra instead). Sometimes it isn't the contact points between the two connector halves that is the problem, but a bad wire crimp at one of the individual contact pins. It is actually a common problem with exterior bulbs, where the owner replaces what they believe is a burnt out bulb, only to find that the new one doesn't help.
"That's a Hruck Bugbear, manufactured in Eastern Europe in the eighties and imported to the States. People mock it as a poor man's Yugo. I consider it the pinnacle of Cold War Balkan engineering."
Add to Astra La Vista!'s Reputation
Rate the quality of this post and help Astra La Vista! reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Astra La Vista! is offline   Reply With Quote
Old 08-28-2013, 11:45 PM   #3
Articwhite2008
2008 Astra XR
If the problem comes up again then I will give it a try
License Plate Light joshking22 Ion General 5 03-30-2013 06:29 AM
led license plate light Badman Aura General 14 10-17-2011 12:35 PM
License plate light Articwhite2008 Astra General 1 03-09-2010 09:53 PM
License plate light Articwhite2008 Astra General 0 03-08-2010 11:43 PM
Help- License plate light out fotovue Vue Tech 2 03-12-2006 03:06 AM
