Old 01-30-2012, 11:11 PM   #1
Spacepope
Spacepope is on a distinguished road
Spacepope's Avatar
2007 AURA XE
2003 ION-2 Sedan
Default Oil leak puzzler
While doing something in the garage tonight I noticed a few drops of oil on the floor where the wife parks the Aura.
After she got home tonight, I checked the engine compartment for anything out of the ordinary. Bone dry on the topside, but when I went underneath the car, the bottom of the engine was covered in oil.
I'm pretty sure the guys that changed the oil last just left the oil filter loose, but I'm not sure. Where is it located, and should I take it to another mechanic first for diagnosis before heading back to the oil change place demanding a fix, fill and another oil change (done right)?
2008 Acura MDX 109k
2007 Aura XE 80k "Betty"
2003 Silver Blue ION 2, 46k Traded "Manni"
1998 SL 63K RIP "Bewm"
Add to Spacepope's Reputation
Rate the quality of this post and help Spacepope reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Spacepope is offline   Reply With Quote
Old 01-30-2012, 11:18 PM   #2
Spacepope
Spacepope's Avatar
2007 AURA XE
2003 ION-2 Sedan
Default Re: Oil leak puzzler
OK just checked again. Oil filter area is bone dry too. Leaking heavier on the passenger side.
2008 Acura MDX 109k
Old 01-31-2012, 11:11 AM   #3
Spacepope
Spacepope's Avatar
2007 AURA XE
2003 ION-2 Sedan
At the dealer now. Front crank seal. Covered under warranty.
2008 Acura MDX 109k
Old 01-31-2012, 11:15 AM   #4
golftango
golftango will become famous soon enough
golftango's Avatar
Hey Spacepope, is this the 3.5 or 2.4?
2017 Sport SE 6MT in San Marino Red
2012 Pilot EX-L w/ NAV (family truckster)
http://www.flickr.com/photos/golftango
https://500px.com/golftango
https://www.instagram.com/golftango
Add to golftango's Reputation
Rate the quality of this post and help golftango reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
golftango is offline   Reply With Quote
Old 01-31-2012, 03:38 PM   #5
Spacepope
Spacepope's Avatar
2007 AURA XE
2003 ION-2 Sedan
It's the 3.5. Surprised to see the oil coming out, but the dealer had me in, fixed and out in less than 2 hours, without an appointment.
Here's a pic of what told me something was wrong. Note oil filter area is dry.
2008 Acura MDX 109k
Old 01-31-2012, 03:41 PM   #6
unkle bik
unkle bik is a jewel in the roughunkle bik is a jewel in the roughunkle bik is a jewel in the roughunkle bik is a jewel in the rough
unkle bik's Avatar
2007 AURA XR
2008 Astra XE
So what ended up being the problem?
93 SW2
96 SL2
01 SL2
02 L200
08 Astra Xe
07 Aura XR
Complacency leads to mediocrity.
Mediocrity leads to our demise.
Add to unkle bik's Reputation
Rate the quality of this post and help unkle bik reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
unkle bik is offline   Reply With Quote
Old 01-31-2012, 03:46 PM   #7
Spacepope
Spacepope's Avatar
2007 AURA XE
2003 ION-2 Sedan
Faulty "Front Crank Seal". Whatever that is. I'd like to know more about these seals.
Has anyone else had this issue yet?
Will all that oil eventually wash off the underside of the engine?
2008 Acura MDX 109k
Old 02-01-2012, 03:09 PM   #8
greenman
2009 AURA XE
On a cold engine, use engine cleaning spray & a hose to clean off residual oil.
__________________________________________________ __________
Sorry, the pictures are stripped out in the conversion:
Service Information 2007 Saturn AURA | AURA, BAS Hybrid (VIN Z) Service Manual | Document ID: 2042661
#07-06-01-023: 60 Degree V6 Engine Oil Leak at Crankshaft Front Oil Seal (Use New Crankshaft Front Oil Seal Installer Tool EN-48869) - (Dec 5, 2007)
Subject: 60 Degree V6 Engine Oil Leak at Crankshaft Front Oil Seal (Use New Crankshaft Front Oil Seal Installer Tool EN-48869)
Models: 1986-2008 GM Passenger Cars and Light Duty Trucks (including Saturn)
with 2.8L, 3.1L, 3.4L, 3.5L or 3.9L 60 Degree V6 Engine
(VINs D, E, F, J, K, L, M, N, R, S, T, V, W, X, Z, 1, 3, 8, 9, W, R --
RPOs LG6, LA1, LNJ, LG8, LL1 or LX9, L82, LL2, LB8, LHO, LG5, LB6, LE2 or LQ1, LH7, LC1, L44, LZ4, LZE, LZ9, LGD, LZ8, LZG)
Important: This bulletin does not apply to 2004-2007 Saturn VUE models with 3.5L DOHC V6 Engine (VIN 4 - RPO L66) or 2005-2008 Cadillac CTS with 2.8L HFV6 Engine (VIN T - RPO LP1).
Important: This bulletin only applies to 60 degree V6 engines. Some of the discontinued 60 degree V6 engine VINs and RPOs may have carried over to other new model year engines and may no longer be a 60 degree V6 engine. So this bulletin may not apply. It is very important to verify that the following information is correct before using this bulletin:
Year of vehicle (e.g. N = 1992)
V6 Engine Liter size (e.g. 3.4L)
VIN CODE (e.g. X)
RPO (e.g. LQ1)
If ALL the information from the vehicle (year, size, VIN Code, RPO) you're working on can be found under the models listed above, then this bulletin applies to that engine. If one or more of the vehicle's information can NOT be found under the models listed above, then this bulletin does NOT apply.
Condition
Some customers may comment on external oil leakage.
Correction
Important: Before replacement of the crankshaft front oil seal, be sure the PCV system is operating correctly.
Tools Required
Important: TOOLS WERE SHIPPED TO YOUR DEALERSHIPS. IF YOU HAVE NOT RECEIVED THEM OR THEY ARE LOST, PLEASE CALL GM SPECIAL SERVICE TOOLS AT 1-800-GM-TOOLS.
The EN-48869 has a unique design to allow the technician to easily install the front crankshaft seal squarely to the correct depth and direction. Before proceeding with installation, review the illustration below to become familiar with the tool.
EN-48869 Crankshaft Front Oil Seal Installation Tool
Installer Body
Bearing
Washer
Drive Nut
Force Screw
Removal Procedure
Remove the crankshaft balancer. Refer to Crankshaft Balancer Replacement in SI.
Important: Use care not to damage the engine front cover or nick the crankshaft.
Remove the crankshaft front oil seal (1) using a suitable tool.
Installation Procedure
Lubricate the inside of the crankshaft front oil seal (1) with clean engine oil. Then install the seal to the installer body (2).
Align the oil seal and installer body (1) with the engine front cover and crankshaft.
Important: Before installing the force screw, apply a small amount of the Extreme Pressure Lubricant J 23444-A, provided in the tool kit, to the force screw.
Install the drive nut (4) onto the threaded force screw shaft (5), washer (3), and bearing (2). Then install to the installer body (1) and tighten the force screw to the crankshaft by hand.
Using a wrench, turn the drive nut on the threaded force screw shaft (2), this will push the seal into the engine front cover.
Continue to turn the drive nut (2) with the wrench until the installer body (1) is snug and flush against the engine front cover.
Loosen and remove the drive nut from the threaded force screw shaft, washer, bearing, and installer body. Verify that the seal has seated properly, flush against front cover flange (1).
Install the crankshaft balancer. Refer to Crankshaft Balancer Replacement in SI.
Inspect for proper fluid levels.
Inspect for leaks.
Parts Information
Part Number
Description
Qty
10243247
Seal, Crankshaft Front Oil
1
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
J0750
Seal, Timing Cover Oil Replace
Use Published Labor Operation Time
GM bulletins are intended for use by professional technicians, NOT a ""do-it-yourselfer"". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
2012 General Motors Corporation. All rights reserved.
Add to greenman's Reputation
Old 02-01-2012, 09:59 PM   #9
Spacepope
Spacepope's Avatar
2007 AURA XE
2003 ION-2 Sedan
Thanks for posting that info, greenman!
2008 Acura MDX 109k
Colant Leak - Small leak turned into a big one Raysp30 S-Series Tech 3 03-02-2009 07:25 PM
Puzzler: Ignition Switch/Cylinder Problem hholbein S-Series Tech 5 09-14-2008 03:41 PM
SaturnTalk Puzzler David Jameson S-Series General 8 04-29-2008 02:06 AM
Driver side leak & sunroof leak-common? Miss Holly S-Series Tech 3 01-06-2008 02:01 AM
evaporator core leak -- opinions on 'stop leak' products? brenspin S-Series Tech 12 01-31-2006 12:29 AM
