Old 12-21-2011, 02:23 PM   #1
golftango
golftango will become famous soon enough
golftango's Avatar
Default Pressing lock/unlock buttons together - TPMS programming?
According to the TPMS, the PSI for my right front tire was not budging even after adding air repeatedly.
So the dealer looked at it and the service writer got in the car and turned the car to "on" and on the key fob, pressed both the lock/unblock buttons simultaneously. Then the other service writer went around to each tire with a gauge. They said the TPMS was not switched back after the tires were rotated, so it was reading the incorrect tire's pressure.
Can someone explain the key fob thing? I love programming Easter eggs!
2017 Sport SE 6MT in San Marino Red
2012 Pilot EX-L w/ NAV (family truckster)
http://www.flickr.com/photos/golftango
https://500px.com/golftango
https://www.instagram.com/golftango
Add to golftango's Reputation
Rate the quality of this post and help golftango reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
golftango is offline   Reply With Quote
Old 12-21-2011, 02:30 PM   #2
golftango
golftango's Avatar
Default Re: Pressing lock/unlock buttons together - TPMS programming?
Found more info. So this is how we reset our TPMS after a tire rotation. You don't need the GM tool.
Turn key to on and depress both the lock/unlock buttons on the keyfob. The car will honk and the display will display LF_____ RF______. This puts the TPMS into "learning" mode.
Go around to each tire with a large magnet (someone mentioned using a speaker magnet) and place it by each stem. The car will honk when the stem is locked in.
Old 12-21-2011, 03:04 PM   #3
onefunkar
onefunkar's Avatar
2008 Outlook XR
2007 AURA XR
after rotate you should do relearn position procedure. thats what they did or it can be done at home. if you dont the low tire pressure monitor will still light up if you have a low tire but it wont know which one. relearn just tells the car which tire is in which position.
Add to onefunkar's Reputation
Old 12-21-2011, 03:59 PM   #4
unkle bik
unkle bik is a jewel in the roughunkle bik is a jewel in the roughunkle bik is a jewel in the roughunkle bik is a jewel in the rough
unkle bik's Avatar
2007 AURA XR
2008 Astra XE
Is the procedure the same for all model years?
IIRC, the 2007 TPMS does not tell which tire is low.
93 SW2
96 SL2
01 SL2
02 L200
08 Astra Xe
07 Aura XR
Complacency leads to mediocrity.
Mediocrity leads to our demise.
Add to unkle bik's Reputation
Rate the quality of this post and help unkle bik reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
unkle bik is offline   Reply With Quote
Old 12-21-2011, 04:23 PM   #5
golftango
golftango's Avatar
Well you can tell by scrolling the menu. Just add air the the lowest PSI reading.
Old 12-21-2011, 04:45 PM   #6
unkle bik
unkle bik's Avatar
2007 AURA XR
2008 Astra XE
Scroll thru what menu?
I get the "check tire pressure" warning light along the symbol illuminated on the dash. I have no way of scrolling thru any menu to get any specific tire info.
This is why I asked if 2007 MY were exempt...
93 SW2
96 SL2
01 SL2
02 L200
08 Astra Xe
07 Aura XR
Old 12-21-2011, 05:14 PM   #7
onefunkar
onefunkar's Avatar
2008 Outlook XR
2007 AURA XR
law says you have tpms but not that you can read it on the dash. for 2007 only the greenlines had readouts on the dash. 08 and 09 had readout. on my 07 i dont do relearn procedure when i rotate. the only reason you would would be if you had a fault code (blinking light) when they pulled a code in may say right front sensor not working but it may not really be right front sensor...
Old 12-21-2011, 09:10 PM   #8
unkle bik
unkle bik's Avatar
2007 AURA XR
2008 Astra XE
Thanx,1funkar.
That's what I thought.
93 SW2
96 SL2
01 SL2
02 L200
08 Astra Xe
07 Aura XR
Old 12-22-2011, 01:38 AM   #9
golftango
golftango's Avatar
Did not know the 07s didn't have the DIC.
Old 12-22-2011, 08:49 AM   #10
unkle bik
unkle bik's Avatar
2007 AURA XR
2008 Astra XE
They do have the DIC. But I am sure it may be different on later models. the display is mounted on the instrument cluster under the speedo. I assume later ones are on the radio display. (like the Malibu)
The one feature I found diff was the low tire pressure one. It will warn of low pressure, but it will not tell you which tire.
93 SW2
96 SL2
01 SL2
02 L200
08 Astra Xe
07 Aura XR
Old 12-22-2011, 10:48 AM   #11
onefunkar
onefunkar's Avatar
2008 Outlook XR
2007 AURA XR
they work in the same place, the same way but in 08 added much more info
Old 12-23-2011, 11:31 AM   #12
Low Saturn
Low Saturn's Avatar
2000 SC2
Heres a post I made a few months ago of the procedure along with a video for the more visual types of people.
http://www.saturnfans.com/forums/sho...52&postcount=1
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2000 SC2
-2001 Chevrolet Suburban
08 Random Lock/Unlock sparky912 Aura General 3 10-24-2011 04:44 PM
98 SL2 Lock/Unlock Light Programming xm1014 S-Series Mods 6 04-14-2008 12:39 AM
Lock/Unlock switch. Picsman S-Series Tech 0 06-30-2007 11:12 AM
Lock/Unlock Button fritzdog Aura General 1 10-09-2006 10:00 AM
Key Fob/ distance to lock/unlock car saturndoug77 Vue General 16 11-19-2003 04:16 PM
