Go Back   SaturnFans.com Forums > Categories > General Saturn Discussion
Old 08-24-2011, 09:30 PM   #1
toddsrams
toddsrams is on a distinguished road
Default I need help with my 2000 Saturn SL2 Overheating issues
I have a 2000 Saturn SL2 and it overheats on me. I just replaced the radiator because it overheated and blew the top off the radiator. I also replaced the thremostat and fan motor. Right now the fan still doesn't turn on and the car starts to get hot. Please help, I don't know what else to do
Add to toddsrams's Reputation
Rate the quality of this post and help toddsrams reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
toddsrams is offline   Reply With Quote
Old 08-25-2011, 01:51 PM   #2
Low Saturn
Low Saturn's Avatar
2000 SC2
Default Re: I need help with my 2000 Saturn SL2 Overheating issues
Replace the engine coolant temperature sensor (ECTS) and check the fan realy. Actualy those things should of been done first. Your original thermostat and fan motor were probably fine. I also doubt overheating had anything to do with the radiator failure. They just crack as they get older.
Also post questions like this in the S-Series section. You wont get very many answers in this section.
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2000 SC2
-2001 Chevrolet Suburban
Old 06-13-2016, 11:49 AM   #3
Spetty75r
Spetty75r is on a distinguished road
I also have 2000 sl2 overheating. Changed fan motor ects. And thermostat. Fan is coming on. Ran fine for few months but now overheating again. Any suggestions
Add to Spetty75r's Reputation
Rate the quality of this post and help Spetty75r reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Spetty75r is offline   Reply With Quote
Old 06-13-2016, 04:47 PM   #4
pierrot
pierrot's Avatar
There was a mention of checking the fan relay in post #2 (misspelled as "realy") which might be of use to you as well.
Originally Posted by Low Saturn View Post
Replace the engine coolant temperature sensor (ECTS) and check the fan realy......
I see that you've also made a similar posting in the S Series Tech Forum. That's really the best place to have put up such a thread. Forum etiquette around here is to avoid duplicate threads in differing locations. We can all view every forum available. Good luck!!
Radiator Fan Relay
http://www.rockauto.com/en/catalog/s...fan+relay,3060
327,000 miles - Holy canolli!
A dishonest communist and deep state socialists want to be POTUS.
They'll bring us a bad economy, weak military, increased terrorism and a greater RED CHINA.
Add to pierrot's Reputation
2000 saturn ls2,,overheating problems j4gwig L-Series Tech 5 09-17-2012 10:57 PM
2000 Saturn SC Coupe Overheating issues need help. TDAVENPORT S-Series Tech 8 04-15-2012 10:03 AM
2000 saturn speaker issues dangos L-Series General 2 03-08-2012 03:27 PM
'95 Saturn Overheating Issues *New Saturn Driver! Futter~Butter S-Series General 9 04-14-2010 08:40 AM
Ummm.. gas Mileage issues, 2000 Saturn LW2 V6 3.0L DOHC RZiggyservices L-Series Tech 6 07-30-2007 04:35 PM
