Old 12-05-2009, 05:07 PM   #1
SWDude
SWDude is on a distinguished road
1997 SW2
Default Quick start cold/ slow start warm 1st try, 2nd try quick start
Hey All,
Got a curious issue with my 97 SW2 163K auto.
When engine is cold, it will start up very quickly. If engine is warm however,
First time I turn the key it cranks for 2, 3, 4 seconds before it will starts.
I usually just let it crank for 3 sec and if it doesn't start by then I then stop, Wait a second, crank again and it fires right up.
Anyone else experience this???
Thanks
Add to SWDude's Reputation
Rate the quality of this post and help SWDude reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SWDude is offline   Reply With Quote
Old 12-05-2009, 05:45 PM   #2
adventureoflink
adventureoflink's Avatar
Default Re: Quick start cold/ slow start warm 1st try, 2nd try quick start
Did y'all replace the ECTS and connector? Instructions are in the how to library.
Old 12-05-2009, 11:20 PM   #3
Greg1
Greg1's Avatar
1997 SW2
Originally Posted by SWDude View Post
Hey All,
Thanks
My 97 does the same thing. There is the fuel pump check valve issue for this year allowing fuel pressure to bleed off but it hasn't made sense to me why the problem is only when the engine is warm. Like many people here we have gotten used to putting the key to run while putting on the seat belt allowing time for fuel pressure to build before cranking.
97 SW2 5-Sp 273k -mine
Add to Greg1's Reputation
Rate the quality of this post and help Greg1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 12-05-2009, 11:27 PM   #4
off-track
off-track's Avatar
Actually, VERY common! Supposedly it's the fuel pump check valve but I'm not yet totally convinced, because like you said it's fine cold (like mine). The common suggestion is to turn the key to run (not start) and wait while you buckle the belt (for instance) before starting but, I've found that makes no difference. Like you, I crank it for just a few seconds, back to run, and then start again and it usually fires right up. When I do that, I usually hear a relay click (between starting attempts) in the passenger JB but haven't removed the cover and felt to see which relay it is (I suspect it's the pump relay though)?
Purchased 114k 10/07
Added OEM CC
Add to off-track's Reputation
Problem with engine start and quick stops Danc922 S-Series Tech 2 06-22-2009 01:41 PM
stinky smoke at start and stalled quick, help! batca61 S-Series General 2 02-07-2009 01:08 AM
Quick question about no start mr18436572 S-Series Tech 35 12-20-2008 10:32 AM
Cold start fine, warm start takes a couple of tries FredM S-Series Tech 5 09-05-2008 05:03 PM
95 SW2 Starts hard when cold wont start warm??? manx133 S-Series Tech 3 09-04-2008 06:07 PM
